#2265937 - 03/25/11 03:28 PM
How to change sidemarker bulb
Loc: OH
I can't seem to figure out how to change the sidemarker... Space is real tight. Anyone change the bulbs before?
Sig removed. Read the rules.
#2265941 - 03/25/11 03:39 PM
Re: How to change sidemarker bulb
[Re: Photogchris]
Loc: Washington
I assume you mean the front sidemarker? If I remember correctly, lift your hood, remove the plastic shroud forward of the radiator. Behind, and to the outside of the headlight coming in from the side, you will see a 10 mm nut, take this off, then remove the small screw at the rear of the lens, and the lens should come out. Change the bulb, then reinstall. Might be easier this way.
#2265946 - 03/25/11 03:49 PM
[Re: Photogchris]
Loc: OH
Yes, thank you.
#2265961 - 03/25/11 04:42 PM
[Re: puppy]
Loc: OH
I can't figure out how to get the nut off hardly any room... It's not a 10mm either.
#2265980 - 03/25/11 05:03 PM
[Re: Photogchris]
Loc: Charlotte, NC
It's an 11 MM and you need an extension. I usually use a 3/8 ratchet and you will only get about 3-4 clicks when you turn it, so just loosen it with the ratchet and then remove the ratchet from the extension and loosen it the rest by hand with the extension.
You will understand what i mean when you try it. Then once you remove that bolt, remove the Phillips head screw that is on the outside of the side marker.
2007 Ford Crown Victoria SAP P71 Silver Birch/Dark Charcoal, 137,000 Miles, 1,600 Hours, NCSHP Vehicle #7367 40% Huper Optik Window Tint, DIY Headlight Relay Upgrade, Turn Signal Flash Mod, Trunk Light Mod with Cold Cathodes, Streamlight UltraStinger, Ultra Gauge, Pioneer Head unit, a GlobalSat BU-353, Cobra 29-LX, DVR-207 Dash Camera, and a RAM-VB-106-SW1 No-Drill Laptop Mount.  Proud member of the imaginary S.A.P. Group. You don't see us due to our street appearance.
#2266005 - 03/25/11 05:38 PM
[Re: Photogchris]
Loc: West Bend, WI, USA
Might as well do the "flashing sidemarker mod" as long as you are in there, since the stock sidemarkers DO NOT flash. Here's a link to the Body of Knowledge article written by AKA_Rizzo, https://www.crownvic.net/ubbthreads/ubbthreads.php?ubb=showflat&Number=1762831#Post1762831it even gives directions for removing the sidemarker.
1999 Deep Wedgewood Blue & Rust P71, 21x,xxx miles, full cloth interior, 3L55 RAR, BH1976 Headlight Relay Harness, and a few other mods. Former Chippewa Falls, WI PD car. I'm the 3rd owner of car. Now with Mustang Wheels, Honeycomb Grille, and Ford AM/FM CD player with RDS.  Download your Owner's Manual FREE from the Ford Owner's Site
#2266034 - 03/25/11 06:58 PM
[Re: Tracy]
Loc: OH
Just got done with the sidemarker mod before even reading this. I had to use the extention w/ a u joint to get it undone.
#2266050 - 03/25/11 07:48 PM
[Re: Photogchris]
Loc: Montreal
I've actually successfully changed the sidemarker bulbs while only removing the front headlights. space is really tight, but if you have smallish hands you can do it
Edited by RiceRockets (03/25/11 07:48 PM)
Resident "ricer"
#2266124 - 03/25/11 10:07 PM
[Re: Ponyguy]
Loc: Fla. Cracker in South Conway
Good job! I usually wind up having to remove the rear headlamps...  you know I was wondering where those rear healamps were and where to fill my headlight fluid.
2004 Arizona Beige P-73, gone but never forgotten  2004 P-73,113k+ Performance & Handling: P-71 H-pipe with Flowmaster 50s/Rear Meow delete/ADTR P&P plenum/70mm TB/Marauder swaybars/MZT/BOC tune/J-Mod/ 2006 P-71 rear coils/Gatorback belt/2005 17" Mustang GT Premium rims with Pirellis/ FRPP 3.55's / FRPP Trak-Lok best time, pre-gear change: 15.4 @ 91.6mph
Appearance: Honeycomb color matched grille/lower grille mesh mod/S-55 tail/reverse lights mod/bumper tuck/window chrome and wood dash delete/black reflective rear fascia/side marker mod/15% rear, 35% front tint/Marauder gauge cluster/1999 Lincoln Continental console and floor shift/Marauder gauge pod with "real" Autometer gauges/ Ford Focus driving lights with 5000K HID's wired to Marauder light switch for factory operation/repaired LCM/Marauder corner lights
#2266160 - 03/25/11 11:13 PM
[Re: Photogchris]
Loc: Charlotte, NC
Come on guys, he meant he didn't have to remove the side markers to change the bulb, only the headlights, jeez!!
#2266188 - 03/25/11 11:50 PM
[Re: Photogchris]
Loc: Washington
LMAO! Ahh, sometimes you just gotta read the forums for a good laugh.
#2266333 - 03/26/11 09:26 AM
[Re: Steveboos]
Loc: Montreal
Come on guys, he meant he didn't have to remove the side markers to change the bulb, only the headlights, jeez!! No, I meant I didn't need to remove the rear tail lights kidding haha I wish english was my first language sometimes
Edited by RiceRockets (03/26/11 09:28 AM)
Resident "ricer"
