#2350648 - 08/10/11 10:00 PM 4.6l to 302 5.0l engine swap
Brentoast Offline
Loc: Northern California
My engine block is cracked on my 2000 crown vic and I was wondering if a ford 302 5.0l engine could replace my stock 4.6l SOHC. Also I would put a carb on the engine, how much mpg would I lose.
The 302 is shorter by 3 inches, length is the same, but the width is about 6 inches smaller maybe 9in. I forget. Anyways I wanna know if I can swap out the engines wih relatively no major hassles or complications. I already figure I have to move the motor mounts
If I can do this is it wise to do so? Is there a better alternative? Should I just get a replacment engine from the junkyard. Any help is appreciated
2000 ford crown vic
#2350668 - 08/10/11 10:22 PM Re: 4.6l to 302 5.0l engine swap [Re: Brentoast]
Bangster Offline
There is a place in Kommifornia that you can put in a carbed 5.0 OHV in a 2000?
There are a few examples of earlier whales with SBFs in them on the site. But unless this is a special use vehicle (not your daily driver), or you have the time, tools, skills, and the engine/transmission already, it would be cheaper to find a 96+ engine and swap around anything that is different depending on the year off your old engine.
#2350702 - 08/10/11 10:53 PM Re: 4.6l to 302 5.0l engine swap [Re: Bangster]
Brentoast Offline
Whats Kommifornia?
Well I have the tools and skill and can make time for this. Although I have Repaired and Replaced an engine before I have never swapped two different kinds so I have no experience in custom fab and welding, hopefully I wont have to do too much. So I hope there are no complications but it could be a new adventure for me.
I am completely car less right now but I would like to upgrade my engine to a 5.0L and dont mind being car less to do so. Since my engine must come out anyways I might as well improve my car.
Also I could just buy a used block and transfer all my other engine parts onto it. I just dont know if thats a good idea for the long run. I know its much cheaper though.
Also another idea if I upgrade my engine to a newer used 4.6L which year should I get and I prefer a DOHC instead of my current SOHC
Thanks Bangster for the input
Edited by Brentoast (08/10/11 10:55 PM)
2000 ford crown vic
#2350831 - 08/11/11 06:12 AM Re: 4.6l to 302 5.0l engine swap [Re: Brentoast]
LOL even a stock HO 5.0 is a downgrade from a PI 4.6
A 5.0 swap is hard enough in a AOD equipped 92 A 2000 needs a pile of parts from a 86-91 and a 5.0 won't bolt to your transmission
Get a used 4.6 even a 2011 will fit with some parts swapped over from your 2000. Exhaust manifolds oil pan and engine mounts all changed on 2003
2004 Crown Vic LX SOLD!!
#2350838 - 08/11/11 06:35 AM Re: 4.6l to 302 5.0l engine swap [Re: Chevyguy]
x2 save you time and money and stay with the 4.6
#2350841 - 08/11/11 06:49 AM Re: 4.6l to 302 5.0l engine swap [Re: Brentoast]
GSDNH Offline
How are you going to put an older motor into a newer car, and drive it in California?
Edited by GSDNH (08/11/11 09:01 AM)
#2350855 - 08/11/11 07:23 AM Re: 4.6l to 302 5.0l engine swap [Re: GSDNH]
ImpulseRocket89 Offline
Loc: Omaha, NE USA
If you want a bigger engine, you could also just grab a 5.4
#2350862 - 08/11/11 07:31 AM Re: 4.6l to 302 5.0l engine swap [Re: Chevyguy]
Some of us don't agree...
Problem is all the pieces to make it fit... Explorers excepted, most 5.0 were OBD-I and as also mentioned the 4.6 has a goofy bellhousing bolt pattern so you'd need to swap the transmission to one that will mate to a 5.0/5.8... Now that I've mentioned the 5.8, if you were serious, I'd go that route... A big Windsor with a good set of heads(even a fair set) will kick any NA(normally aspirated)4.6 into next week...
All this said, if it has to pass emissions, forget the whole thing... Emission Nazis would fail it as soon as they opened the hood...
And for you guys that "think" a 4.6 is better, my full weight/option '88 T-Bird with a Trick-Flow headed 5.0 has run [email protected] on a cool evening and at 75*/80* would run [email protected] all day long... Yes the Bird is probably 400Lb lighter than a panther, but hauling the extra weigh still should run a 13.7...
Yeah your comeback will be, "with heads & cams a 4.6 can make similar power to a 5.0" and just how much does those cost compared to the Windsor?
Now with P/S & PDB
#2350909 - 08/11/11 09:03 AM Re: 4.6l to 302 5.0l engine swap [Re: Brentoast]
GSDNH Offline
^^^ I'll agree with the Windsor. They do make great power and cost less to mod.
#2350914 - 08/11/11 09:08 AM Re: 4.6l to 302 5.0l engine swap [Re: Brentoast]
I clicked on this hoping to see a DOHC 5.0L discussion. Needless to say I was disappointed grin
Save your money (and aggravation) and just drop another 4.6L in there!
Pantherless since September 2019
1972 Ford Galaxie 500 | 6.6L | 82,xxx miles
1978 Ford Fairmont | 3.3L | 130,xxx miles
2017 Ford Fusion SE | 2.5L | 50,xxx miles
#2350957 - 08/11/11 10:04 AM Re: 4.6l to 302 5.0l engine swap [Re: Brentoast]
I say just do it with a 5.0 or put back in a 4.6 and save all of us the 3 pages of people bickering back and forth that will undoubtedly end up happening.
#2350967 - 08/11/11 10:14 AM Re: 4.6l to 302 5.0l engine swap [Re: Brentoast]
gDMJoe Offline
Loc: Timbuk3, MI
Your intended swap ( carb'ed 5.0 ) would be illegal in CA.
Illegal mods not allowed ««« -click-
-click the Vic-
#2351015 - 08/11/11 12:03 PM Re: 4.6l to 302 5.0l engine swap [Re: Brentoast]
72mgm98 Offline
Loc: U.S.
1998 M.G.M. M75 LS, H.P.P.
"The pain of every change is forgotten when the benefits of that change are realized"~Tom Hopkins
�Everybody pities the weak, jealousy you have to earn�~ Arnold Schwarzenegger
#2352526 - 08/14/11 04:30 AM Re: 4.6l to 302 5.0l engine swap [Re: 72mgm98]
Brentoast Offline
Yeah after some thinking and research Ive decided to not put a 5.0L in it and put a 5.4 instead and use my 4.6 heads and buy an HPS intake and shorties. Since I will already have the engine dissasembled should I put and other relatively inexpensive parts on it to give it more HP. Think 1,000 or less.
When I do things, I like to do them right the first time and go all out relatively speaking for someone who works a minimum wage job haha. I dont do half-ass jobs. Basically I wanna get the most HP I can for my dollar, value HP. And yes I know upgrading motors arent cheap, but with time I will improve it.
So anyways any suggestions?
Also thanks for the link^^^
Man California can be lame sometimes, but livin in the Sierra nevadas allows me to put the pedal down without looking for flashing lights.
Edited by Brentoast (08/14/11 04:37 AM)
2000 ford crown vic
#2352538 - 08/14/11 04:56 AM Re: 4.6l to 302 5.0l engine swap [Re: gDMJoe]
interceptor1985 Offline
Loc: OREGON
However they did use the 5liter up in 2000 in the explorers though you will need to do some fancy wiring tricks to get her to work with all the OEM smog equipment.
Mine is a 1985 swapping in a 97 5liter from a explorer. I'll need all the smog equipment from the ex before I can pass. BUT it is do-able.
#2352647 - 08/14/11 11:00 AM Re: 4.6l to 302 5.0l engine swap [Re: interceptor1985]
gDMJoe Offline
Loc: Timbuk3, MI
interceptor1985 - However they did use the 5liter up in 2000 in the explorers ...
And they were FI and not carb'ed.
#2352807 - 08/14/11 04:04 PM Re: 4.6l to 302 5.0l engine swap [Re: Brentoast]
knucklehead0202 Offline
Loc: Southern California, U.S.A.
do what i'm in the process of and just buy a box 5.0 panther. getting rid of my '98. i'll take a 5.0 any day.
1998 CV p71. 93,xxx miles now, still haven't got it painted.
#2352808 - 08/14/11 04:05 PM Re: 4.6l to 302 5.0l engine swap [Re: knucklehead0202]
Why?
Originally Posted By: etcv97
#2352830 - 08/14/11 04:53 PM Re: 4.6l to 302 5.0l engine swap [Re: Brentoast]
Max11x11 Offline
Loc: Pennsylvania, US
Save yourself a world of trouble and buy either a 5.4 or 4.6. Make life a whole lot easier.
1999 Crown Vic PI - Black - 97K miles - Former federal agency and NJ police car - JModded - Flowmaster 40s - 3.55 gears -+- TOTALED. R.I.P
2004 Crown Vic PI - White - 130K miles - Former Sheriff's car -+- Sold
2001 Lincoln Continental - Champagne - 103k - Granny driven FWD like a baws!
#2353018 - 08/14/11 11:39 PM Re: 4.6l to 302 5.0l engine swap [Re: BillyBishop]
Loc: OREGON
Why?
Because Boxes kickass is why.
#2353187 - 08/15/11 09:44 AM Re: 4.6l to 302 5.0l engine swap [Re: Brentoast]
Bangster Offline
What is worse than a non HO 5.slow SEFI? CFI!
Don't get me wrong, I still drive, on occasion, an 89 Grand Marquis and a 90 Town Car. But the 145 hp, low redline, wind noise, wallowy overboosted steering, make me want back into my 00 Grand Marquis pretty quickly. I won't mention gas mileage, the nice 2-3 chunk clunk AOD shift, etc.
Would I like a properly updated box? yes, I would love to take a coupe, add the aero box bits, a proper SBF that is EFI and an electronic controlled transmission (or a manual). But stock for stock, or lightly modified, going back to a box doesn't make sense.
#2353400 - 08/15/11 04:37 PM Re: 4.6l to 302 5.0l engine swap [Re: Brentoast]
Originally Posted By: Brentoast
Yeah after some thinking and research Ive decided to not put a 5.0L in it and put a 5.4 instead and use my 4.6 heads and buy an HPS intake and shorties. So anyways any suggestions?
well since you are going the 5.4 swap heres some good info.
first why do you want to swap heads?
Make sure the 5.4 is betewen 99 and 2004.
If you want to improve the 5.4 get a decent plenum and throtle body combo.
I,m using a ported accufab plenum with a 75mm accufab throtle body.
Remember that 5.4 love the extra air.
underdrive pulley will also helps.
what gear are you running right now?
#2353450 - 08/15/11 05:35 PM Re: 4.6l to 302 5.0l engine swap [Re: 2004_p71]
Brentoast Offline
Never even thought of an underdrive pulley, will do. Definitely will upgrade the plenum and throttle body.
Well I just checked my heads and they are not PI like I thought they might be so wont switch heads. I will just look to find a 5.4l with PI improvments
My gears are 3.55's
2000 ford crown vic
#2353498 - 08/15/11 06:45 PM Re: 4.6l to 302 5.0l engine swap [Re: Brentoast]
3.55 is agood start
just get a pi 5.4 and call it a day laugh
#2353755 - 08/16/11 12:22 AM Re: 4.6l to 302 5.0l engine swap [Re: 2004_p71]
Brentoast Offline
yeah 2004_P71, Im only gonna do a few mods. In my Mind there are lots of things I want to do but my thoughts cost a lot more than whats in my bank account which I think many can relate too. Either way Once I find an engine and swap it out Im gonna be much happier with all the new found horses. I'm looking forward to an acceleration increase more than anything though.
Nice youtube vids also
Edited by Brentoast (08/16/11 12:56 AM)
2000 ford crown vic
1 registered (1 invisible), 39 Guests and 130 Spiders online.
bluejay_32 204
a_d_a_m 126
Old_Guy_Stu 124
DudeAbides 95
Ponyguy 68
Davidzq 47
CrystalPistol 46
Moby_Vic 44
ClayBelt 38
Bangster 35
