#2374531 - 09/20/11 12:35 AM
Re: OD off light flashing- transmission
[Re: SLOBRA]
Loc: California
 2001 P73 JMOD Trim rings and tall caps. BH1976 Headlight mod, Philips XTreme9007. Rear 17mm Swaybar. Do you want a JMOD decal sticker? 2for$6, see my profile for link. Need LCM relay? (EQ1-11111S) LCM relay link here:
#2374614 - 09/20/11 10:09 AM
[Re: rick1970]
Loc: Brookfield, WI
2004 P71 Dodge County Sherrif 158K 3.27 Trac-Lock, BBK 78mm TB/Plenum, 1/2 inch spacer, SCT XCAL 2 Tuner with BOC Tune, OBX LT Headers Kit, ACCEL Super Coils, Light back tinted Headlights and Clear Side markers, 8K 55W HID, Heinous Control Arms from ADTR, 17 inch 06 GT Premium Rims Up next either cams, stall, or gears.
#2374989 - 09/20/11 08:40 PM
[Re: rick1970]
Loc: Irapuato, Mexico
Oscar.
1995 Lincoln Town Car Signature 1997 Pontiac Grand Prix GT 2000 Ford Windstar SE
#2375020 - 09/20/11 09:32 PM
[Re: JSanders]
Loc: Minnesnowta
The 01 has a 180 thermostat built right into the trans cooler. Interesting. Did that change in the newer 4R70Ws? Mine is out of a 99 Vic so maybe it's different.
1997 Lincoln Mark VIII LSC Supercharged 9psi, E85, stock bottom end [email protected]
#2398215 - 10/30/11 06:24 PM
[Re: rick1970]
Loc: Florida
#2696563 - 04/15/13 05:44 PM
[Re: rick1970]
Loc: Silver Spring, MD
Greg '01 CVPI '98 SVT Mustang Cobra 2002 SVT Focus
#2696576 - 04/15/13 06:06 PM
[Re: rick1970]
Loc: Columbus, OH
#2696616 - 04/15/13 07:12 PM
[Re: rick1970]
