#2382585 - 10/03/11 10:05 PM Oil pan dented
Baw84 Offline
Loc: Gilberts, il
Ok so have had this knocking noise in my car and have asked two ligit mechanics and one retired works out of his garage mechanic and got different answers from all of them, One said ingnition related , one said timging chains, and one said the oil i was using was too thin..... changed the oil to 1030 no difference, dont think in any way it could be ignition related, i crawled under my car today and while down there noticed that my oil pan has a dent in the very bottom of it maybe dented about a half inch up, at some point someone hit something, any chance this could cause a noise? though i doubt it... and what else could cause a knock noise from under the car from oil pan area i am kinda doubting its timing chain guides as the noise is not coming from the front of the engine its from under toward the back of the engine???
2008 CVPI 133k
Black corner lights, R1 concepts drilled /slotted premium rotors W/ Hawk HPS pads on the front.
nothing else yet...
#2382588 - 10/03/11 10:12 PM Re: Oil pan dented [Re: Baw84]
Black_Sunshine Offline
You've got one problem. You only need one thread.
I doubt the oil pan is your problem. Especially if you didn't just dent it the other day when your problem started. I think that the crank would just bash the pan back down and it wouldn't make a lot of noise.
75mm DBW TB
� hood ornament
� c-pillar emblems
� LS style body side moldings
CarDomain
Facebook
#2382592 - 10/03/11 10:19 PM Re: Oil pan dented [Re: Black_Sunshine]
Baw84 Offline
Loc: Gilberts, il
ok ya i know i know shoulda just posted to the other thread...thats a duh on my part nono
disregard this post everyone
2008 CVPI 133k
nothing else yet...
#2383060 - 10/04/11 05:10 PM Re: Oil pan dented [Re: Baw84]
PHoganDive Offline
Loc: Mass, USA
The oil pickup tube for the oil pump goes right to the bottom the the oil pan. If the bottom of the pan is dented up very much, it could be blocking the oil inlet, and starving the motor of oil. This would result in low oil pressure, which in turn can cause excess wear on parts, especially lower end bearings, which if loose generally make a knock.
#2383180 - 10/04/11 09:18 PM Re: Oil pan dented [Re: Baw84]
m_j Offline
Loc: BC Canada
that and the crank never gets close to the pan in a full skirt style motor like the 4.6
chances are the pan got dented by a misplaced floor jack (go ahead and ask me how I know) as the crossmember will protect the pan from ever contacting anything
my cars crossmember has large gouges and the body mount bolts are bent back from the abuse of the previous owners, but the pan was fine till I customized it with my floorjack
2004 p71 ex RCMP- it is a beater
tr3650 from 2005 mustang
hydraulic clutch (using ford truck master, mustang slave) fabbed pedal assembly
tuned using Delta Force by http://www.dirtydirtyracing.com/ through email smile great customer service
aeromotive 11142 fuel pump
#2383182 - 10/04/11 09:22 PM Re: Oil pan dented [Re: Baw84]
GSDNH Offline
Totally depends on where exactly the dent is.
#2383183 - 10/04/11 09:23 PM Re: Oil pan dented [Re: m_j]
GSDNH Offline
Maybe where the sump is but it is very close in the front....
6 registered (Rainbowpizza, bluejay_32, Rootintootin, ismann, Davidzq, 1 invisible), 74 Guests and 286 Spiders online.
bluejay_32 161
a_d_a_m 106
Rainbowpizza 36
