#2397247 - 10/28/11 11:28 PM
Re: Airbag compatibility
[Re: P_Weston]
Loc: Seattle, WA
seems online that 98-00, then 01-02 bags may have changed, you need larry as he can get all kinds of specs and charts
but bags are spendy this one in real good shape eh? good luck.
 1998 Mercury Grand Marquis LS, HPP package FRPP PI Intake from ADTR, Ported Plenum from ADTR, Steeda Plenum Spacer from ADTR, MSD Coils BBK 70MM TB from ADTR, E3 Plugs, 2004 MZT, SCT X3 Tune from BOC, MAF Jumper from BOC, Optima Yellow Top Marauder Spoiler, Steeda Oil Separator W/custom bracket, Metco Control Arms & Watts Link Addco Rear Sway Bar w/ES Bushings, 3:73 Rear Gears with FRPP Trac Lok, Superior Rear Axles, Spruce Green Brake Calipers PowerSlot Slotted Discs, Hawk HPS pads, Extended Tailshaft with P71 DriveShaft, Rebuilt/Painted Rear Axle, Bilstien Shocks, Chrome FR500 18's, Nitto 555's - 255/45-18 F, 285/40-18 R "One doesnt simply drive the speed limit when listening to Heavy Metal"
#2397285 - 10/29/11 12:35 AM
[Re: P_Weston]
never say never
Loc: Minneapolis, MN
Speaking of airbags, would an 08/09 RCM work in an 05?
#2398290 - 10/30/11 08:35 PM
[Re: P_Weston]
Cpt. Smug
Loc: Cali
OK Phil, i figured it all out for you. all you will need to use from the Dewgong is the actual airbag charge. everything else will be used from the 2002. take the 2002 airbag and turn it upside down like so... using a 10MM wrench or socket, remove the four bolts on the rear of the airbag upon removing them, slide off the bracket on the back. take off the main metal rear of the airbag. this holds the charge in place. after doing this, you will notice the 2 stage charge of the 2002 airbag can now be readily removed. 2 stage charge removed. airbag shell with cover still on is whats left. now you are ready to follow the same steps disassembling your 2000's airbag, and put the charge from your 2000's airbag into the 2002 airbag shell, than bolt it all back together. you now have a hybrid 2000-2002 airbag, complete with Mercury Logo! and instillation will be 100% plug and play.
