#2396246 - 10/27/11 01:32 PM Digital dashboard display
DES Offline
Loc: IL
Hello this is my first post - sorry if this is the wrong section to put this- I have a 2000 grand Marquis ls. The problem is the digital dashboard only works on 2/3 the gas and temp gauge work and the speedo and odometer work the information center on the right does not. A while ago if it were cold or damp out it occasionally worked. Has anyone had success at repairing this problem I read that cold solder can cause this I have pulled the cluster and checked the plugs and all were tight. I'm hesitant to take the cluster apart as the cars a daily driver and digital clusters are hard to find if I ruinthis one
Thanks
2007 crown Victoria lx sport dk toreador red w/ stone interior 3.27 gears, buckets and Console 117k miles mods- cvpi zip tube, stainless works catback, honeycomb grille, heated mirrors, drop in k&n panel filter, marauder sub, audiophile radio, Mach 1 chin spoiler, trunk organizer.
2003 grand marquis gs, 15k miles, aspen green over parchment mods - 05 chrome inside handles, wood/ leather steering wheel, power passenger seat, marauder sub.
2000 grand Marquis ls ultimate edition light blue 42k miles mods - 03+ cupholder and emblems
2006 marquis gs tungsten with stone interior. Magnaflow exhaust and 4.10s
#2396483 - 10/27/11 08:27 PM Re: Digital dashboard display [Re: DES]
The 96-97 town car has has the same display as Your car. My 96 lost mph bunch of stuff would come and go. Got another cluster all is good. Solder connection for harness plugs goes bad
Edited by Chevyguy (10/27/11 08:48 PM)
2004 Crown Vic LX SOLD!!
#2396558 - 10/27/11 10:28 PM Re: Digital dashboard display [Re: Chevyguy]
DES Offline
Loc: IL
yeah i have thought about just getting a new cluster from the junkyard they only want about $30 dollars at the picknpulls by me. The only worry is the mileage not reading right unless that is stored elsewhere than the cluster. Might check the solders this weekend when i do my heated mirror swap. thanks for the reply i wasn't sure if the towncar clusters swapped now i have more sources to pull one from.
#2397984 - 10/30/11 12:08 PM Re: Digital dashboard display [Re: DES]
Yeah miles will be wrong, plus you can't see what the used one has. The one I got was only 2000 miles more than the original 239K at the time!! You can try to re-solder the connector pins while using the $30 panel.
#2398381 - 10/30/11 10:36 PM Re: Digital dashboard display [Re: Chevyguy]
DES Offline
Loc: IL
yeah i went to the junkyard saturday and all the cars were pretty picked over and the few digital clusters were broken or scratched up. If i get a used one maybe there is a way i can get it reset or matched to my current mileage.
#2398485 - 10/31/11 01:55 AM Re: Digital dashboard display [Re: DES]
Ponyguy Offline
Loc: Oswego, IL
Originally Posted By: DES
yeah i went to the junkyard Saturday and all the cars were pretty picked over and the few digital clusters were broken or scratched up. If i get a used one maybe there is a way i can get it reset or matched to my current mileage.
Before I went to that trouble, I'd try to fix the one you already have. When dash lights fail after a number of years and miles, bulb replacement and connector clean/repair usually solves the problems.
Sig removed. Read the rules.
My transportation sources:
1972 Green Schwinn Speedster;
1984 Canyon Red Mustang V-6;
#2398764 - 10/31/11 02:00 PM Re: Digital dashboard display [Re: DES]
gberg Offline
Loc: MN
Also curious about the digital dash mine has been going in and out lately. It's 2000 Crown Victoria lx are all of the digital dashes compatible with each other or it they change over the years?
3 registered (Jacques, LTC_Dave, Darkant), 53 Guests and 101 Spiders online.
bluejay_32 97
Armada Master 86
Old_Guy_Stu 74
Moby_Vic 59
Dmblanch 57
DudeAbides 50
a_d_a_m 47
SocalSam 44
Ponyguy 40
