#2391286 - 10/18/11 06:45 PM Are these transmissions interchangeable?
Jeff_from_jeffco Offline
Loc: Mo, jefferson country
are the yw7p-aa transmissions interchangeable with the xw7p-ba, xw7p-ca, or xw7p-da? if so what would need to be done. these are for a 2000 cv p71
2000 p71 police interceptor from Town n County
Aftermarket stereo with 4 12 inch audiopipe subwoofers and 2 1500w rms amps 1 ohm stable smile
top speed run so far of 135
159,xxx Still running like a champ
jmod- with no springs
99 PCM/MAF, bumper tucked, 200 amp alternator upgrade, headlamp relay mod, wig wags, 102 inch whip with cb. - all done with ctrichsler's help
2004 cummins turbo diesel - 111k
2005 dodge SRT-10 pickup 37k miles
1995 dodge 1500 206k miles
#2391834 - 10/19/11 04:54 PM Re: Are these transmissions interchangeable? [Re: Jeff_from_jeffco]
anyone have any idea?
#2393568 - 10/23/11 01:32 AM Re: Are these transmissions interchangeable? [Re: Jeff_from_jeffco]
A '00 CVPI would use the XW7P(-7000-)BA and -CA versions from the factory.
XW7P(-7000-)AA and DA are civilian /retail model transmissions. These do not have the extended tail shaft housing and extended output shaft like the CVPI transmission.
The extended tailshaft housing can be swapped over from your existing transmission (install new bushing. Or just install complete new tailshaft w. bushing) to use the retail model trans. Your CVPI driveshaft has a small vent hole in the center of the yoke. Plug this hole if you use one of the short output shaft/retail transmissions with the extended tailshaft and your stock driveshaft.
Additionally, the retail model transmissions will have an 8 tooth VSS drive on output shaft (vs 7 tooth 99-02 CVPI). A new speedo gear will be required to keep the speedometer accurate
FYI, MANY different years/specs could be used by swapping around basic parts.
#2402975 - 11/07/11 06:00 PM Re: Are these transmissions interchangeable? [Re: Jeff_from_jeffco]
well this transmission in this is an yw7p-aa transmission and it is a crownvic police interceptor. i bought the veh from town and country ploce department, and it is the p71 vin etc. i believe its the "high performance package" if im not mistaken. but what all would it entail to swap once of these other transmissions in?
#2402977 - 11/07/11 06:04 PM Re: Are these transmissions interchangeable? [Re: Jeff_from_jeffco]
There's no such thing.
Also, this page has a ton of info on different transmission models and part interchangeability.
Originally Posted By: etcv97
#2402995 - 11/07/11 06:23 PM Re: Are these transmissions interchangeable? [Re: BillyBishop]
read what you posted look for the -aa transmission on the 2000 model year. it is labeled a high performance package.......
#2403033 - 11/07/11 07:37 PM Re: Are these transmissions interchangeable? [Re: Jeff_from_jeffco]
Nope. That's something different. HPP stand for "Handling and performance package"
It's a civilian model with classy features. Not sure why it has a different transmission though.
#2403074 - 11/07/11 08:55 PM Re: Are these transmissions interchangeable? [Re: BillyBishop]
i will carfax my vin and post it tonight because i can assure you that its a police interceptor and that trans supposed to be on it atleast i think it is. would this explain why i have a trans fld lk when i park on angles withs the front of veh in teh air?
#2403203 - 11/07/11 11:48 PM Re: Are these transmissions interchangeable? [Re: BillyBishop]
You have to remember, these are used vehicles that were beat to hell and part of large fleets. All sorts of stuff gets swapped between models and years because most of it is interchangeable or only slightly different.
It is extremely common for a used CVPI to have the 'wrong' transmission installed, so don't get hung up on it.
Depends on where it is leaking from. If from the CENTER of the driveshaft YOKE, then you likely have a retail model transmission / short output shaft.
You mentioned you have a YW7P(-7000-)AA trans installed right now. This is a retail/civvy spec trans (for HPP cars) and has the short output shaft. The tailshaft housing may or may not have been swapped. About how much space is between the base of the yoke flange and the tailshaft bushing?
The CVPI long/vented yoke needs to be plugged when used with a short output shaft trans to keep it from leaking, as I mentioned earlier;
The XW7P-BA and -CA versions would be a direct swap.
The XW7P-DA version you listed could be used by swapping the output shaft and plugging the yoke as mentioned earlier. You will also need a different plastic speedo gear with this trans, a 23 tooth (assuming you still have stock 3.55 RAR)
'00 HPP models received a transmission with 7 tooth VSS drive output shaft instead of the normal 8 (but with normal short output shaft and tailshaft housing), as the HPP went with a 3.55 RAR for '00 model year. The VSS/speedo driven gear required for 3.55s with 8tooth drive self destructs (very high tooth count (23)) by like 10k miles, which obviously won't work for an OEM application. The 7 tooth drive is required so a lower tooth count gear (20) can be used for increased longevity.
#2403207 - 11/07/11 11:51 PM Re: Are these transmissions interchangeable? [Re: dRock96Marquis]
bow All hail dRock. Great info.
#2403210 - 11/07/11 11:52 PM Re: Are these transmissions interchangeable? [Re: dRock96Marquis]
2000NARC Offline
Loc: Belmont Shore
How do you plug the hole?
1996 Mustang GT, dark blue effect
19" ADR Spartans, 99 PI engine swap, flowmasters, 70mm TB,
Plenum spacer, Stalker 2 front bumper, front coilover kit
#2403221 - 11/08/11 12:10 AM Re: Are these transmissions interchangeable? [Re: Jeff_from_jeffco]
Most have just used RTV (clean yoke very well with brake cleaner before applying). A few actually tapped the hole and installed a plug but this requires removing the U-joint first, of course.
Many just run it as-is, and either never noticed/don't realize it leaking or have and don't know why it is.
It is more prevalent on those with the forced lube mod.
This picture, courtesy Steve83, shows the vent hole position and typical underbody grime/oil on the tunnel resulting from the leak;
#2403257 - 11/08/11 01:46 AM Re: Are these transmissions interchangeable? [Re: Jeff_from_jeffco]
2000NARC Offline
Loc: Belmont Shore
Thanks, I noticed mine was leaking out after I changed my transmission fluid. I suppose I'll climb under there and silicon it shut.
#2403601 - 11/08/11 06:01 PM Re: Are these transmissions interchangeable? [Re: Jeff_from_jeffco]
so they are interchangable without any swapping of any parts except possibly a yolk?
2 registered (Jasper425, TheShadow), 63 Guests and 232 Spiders online.
CrystalPistol 362
bluejay_32 324
a_d_a_m 231
Rainbowpizza 167
DudeAbides 149
JeffBoudah 124
Old_Guy_Stu 77
BigNSlow 69
Bangster 62
