Page 4 of 6 < 1 2 3 4 5 6 >
#2492206 - 03/30/12 04:21 PM Re: 5.4 DOHC Swap **OFFICIAL** Progress Thread [Re: prodigalson]
So stock fuel lines eh? Thats cool.
Any other thoughts or ideas you have on the fuel system?
#2492240 - 03/30/12 05:31 PM Re: 5.4 DOHC Swap **OFFICIAL** Progress Thread [Re: prodigalson]
prodigalson Offline
Loc: Cleveland, OH USA
The calculators say 42lb injectors for the power I'm guestimating and probably a Walbro 255 or Focus SVT pump. I'll see what Lonnie recommends when I get closer to first start.
Permanently banned.
#2492445 - 03/30/12 10:24 PM Re: 5.4 DOHC Swap **OFFICIAL** Progress Thread [Re: prodigalson]
Gotts2BMe Offline
If I were you I would consider that aeromotive stealth pump. 340 lph. Its what I picked up for my truck. I have not installed it yet, its for my lightning top end swap.
1995 Lincoln Town Car - 5.4 swap, no cats, true dual magnaflow, trac loc, 4 link, ported intake, SCT tuning
2000 F150 5.4 - Long Tube headers, Gotts intake, magnaflow exhaust, UDP's, efans, ported intake, 75mm TB, SCT tuning, 33" Firestone M/T's
#2492467 - 03/30/12 11:01 PM Re: 5.4 DOHC Swap **OFFICIAL** Progress Thread [Re: prodigalson]
prodigalson Offline
I don't think I'll need that much for an NA application, but I'll look into it.
Permanently banned.
#2492771 - 03/31/12 03:38 PM Re: 5.4 DOHC Swap **OFFICIAL** Progress Thread [Re: prodigalson]
CameronVic Offline
Coolest guy on CVN
Loc: Middle TN
I'd bet money an in tank 255 will be perfectly fine Jason.
1999 P71, 5.3, twins, on methanol
2006 P71, JMOD and heinous control arms, daily
2004 SAP
2002 LX sport, marauder interior
#2493817 - 04/02/12 10:23 AM Re: 5.4 DOHC Swap **OFFICIAL** Progress Thread [Re: CameronVic]
luv-my-2002-p71 Offline
Loc: New York
That's what I'm running. Got it from Lonnie at Blue Oval Chips.
#2499895 - 04/11/12 07:49 PM Re: 5.4 DOHC Swap **OFFICIAL** Progress Thread [Re: prodigalson]
prodigalson Offline
The heads FINALLY shipped out to MHS this afternoon.
The block and crank have been put away for storage a couple weeks ago.
Not much I can do to the engine without heads so its time to start focusing on the necessary vehicle changes.
I've been playing around with the hydrobooster the past couple of Saturdays. I got it clocked 90 degrees so the accumulator is on the upper outside corner instead of inside. The lines come in underneath. I then had to find a master cylinder that turned the lines to the outside.
After two trips I settled on a MC from a junkyard Explorer/ Ranger. It isn't ideal at all but it is being made to work. I gutted it and cleaned and inspected all the seals. I had to machine down the diameter of the alignment bore to 38.5mm from about 41mm. Now I'm in the process of cutting down the actuator rod on the booster because it's not the right depth and it isn't adjustable like the vacuum booster. There's probably a better fitting MC but I wasn't going to spend too much time looking. It's aluminum, I'll just make it fit.
The booster stud pattern needs to be widened 1" across. It also needs to be spaced out 1/2" from the firewall because the plunger rod is that much longer than the vacuum booster. Both of these issues will be solved in one step with an additional mounting/correction plate.
Once I get all the machine work done on the plate I'll mock it up and measure for the P/S lines. Custom hoses will be made along with custom brake lines and I should have a functioning hydrobooster in a month or so.
After that we start on the AC chamber.
Permanently banned.
#2503100 - 04/16/12 01:19 PM Re: 5.4 DOHC Swap **OFFICIAL** Progress Thread [Re: prodigalson]
prodigalson Offline
I've decided to pass on the Sullivan alternator bracket and fab my own reverse mount bracket similar to the Eaton swap brackets the Marauder guys use.
OUT
IN
I won't have to swap alts first of all, or move the ABS off the frame or swap oil adapters or any of that nonsense the Sullivan swap calls for. I can reuse my own 130 amp 4g alt, and it's lower profile than the 6g alt so it won't stick out all that far. I'll make my own bracket to use all four mounts. The guy selling them on MM.net wants too much and his design only uses the lower mounts
Permanently banned.
#2503432 - 04/16/12 10:22 PM Re: 5.4 DOHC Swap **OFFICIAL** Progress Thread [Re: prodigalson]
Black_Sunshine Offline
The backwards one might be easier to service later too.
75mm DBW TB
� hood ornament
� c-pillar emblems
� LS style body side moldings
CarDomain
Facebook
#2503583 - 04/17/12 04:18 AM Re: 5.4 DOHC Swap **OFFICIAL** Progress Thread [Re: prodigalson]
GSDNH Offline
Sorry to hear you have to go through so much trouble, I didn't have to do any of that stuff to fit my master cylinder to my hydrobooster.
#2503611 - 04/17/12 07:53 AM Re: 5.4 DOHC Swap **OFFICIAL** Progress Thread [Re: prodigalson]
prodigalson Offline
Like I said I could have spent more time researching, but I only went through what I saw at the junkyard. I had no luck at all finding anything with the right bore. Regardless of the piston bore, all the mounting bores were about 2-3mm too large.
You use a newer booster than my 98 don't you? According to Bendix -98/99+ use different master cylinders. Maybe the newer ones use the more common bore cause I couldn't find anything to fit mine.
It's not a big deal really because it's aluminum I just shaved it and its no big deal to shave the rod. The plate will be more interesting.
Permanently banned.
#2504887 - 04/19/12 12:27 AM Re: 5.4 DOHC Swap **OFFICIAL** Progress Thread [Re: prodigalson]
prodigalson Offline
This project is going on hold. One of my vendors suddenly unwilling to perform the necessary services. I need to find some things out.
Permanently banned.
#2504899 - 04/19/12 01:03 AM Re: 5.4 DOHC Swap **OFFICIAL** Progress Thread [Re: prodigalson]
SCHALLZ Offline
Loc: La Crosse WI, USA
Man that sucks seemed like things were coming together nicely
Hopefully it gets worked out quickly and you can get this project moving again
#2505158 - 04/19/12 12:53 PM Re: 5.4 DOHC Swap **OFFICIAL** Progress Thread [Re: prodigalson]
GSDNH Offline
With Nick from Modular Head Shop out of the picture, that definitely is a serious blow to your project, sorry to hear.
#2505234 - 04/19/12 02:46 PM Re: 5.4 DOHC Swap **OFFICIAL** Progress Thread [Re: prodigalson]
That sux man knowing the situation abouth your heads frown
2 registered (Old_Guy_Stu, D_nor), 76 Guests and 30 Spiders online.
