Page 2 of 2 < 1 2
#2472594 - 03/02/12 09:43 AM Re: '05 CVPI + SW exhaust + Cams = [Re: BlackVic_P71]
I'm glad I could help ya out man. The car sounds mean laugh
Now how much torque did you make with the stock intake?
#2489829 - 03/27/12 04:00 PM Re: '05 CVPI + SW exhaust + Cams = [Re: BlackVic_P71]
6Paul11 Offline
Loc: Northern CA
Originally Posted By: BlackVic_P71
A few months ago I had the rear end rebuilt with Ford Racing 3.73 gears, Carbon clutches and a full Ford rebuild kit so all bearings and seals are new.
In the last few weeks I've begun to move onto the engine. With help from Nick, this went very well.
I've had a BBK 75mm TB(#1758) for about a month, that was step 1.
I picked up the rest of a Stainless Works exhaust system(listed for '03-04 but fits perfectly) and put that on in the days leading up to dropping the car off. Now I have the SW headers and 2 1/2" stainless piping all the way, sounds incredible.
Now on to the good stuff, I ordered a set of HiTech Stage 2 cams, 255lph fuel pump and 24lb injectors.
Since internal engine work is far beyond what I can handle, I dropped it off at RealSpeed Automotive here on Long Island for the cam install and dyno tune.
I had them also throw on a set of Steeda pullies while they were at it.
How much were the cams, injectors and fuel pump? I have a tune from BOC could I just take it to a tuner and they can reprogram as needed?
2003 CVPI
BBK 70mm Tbody, ADTR ported plenum, Flowmaster dual exhaust, steeda UD pulley's, Heinous Rear Control Arms, Viper 160XVL SST Remote starter.
Enkei LS-5 18x8 wheels Black
I mostly come out at night...mostly.
#2489837 - 03/27/12 04:14 PM Re: '05 CVPI + SW exhaust + Cams = [Re: BlackVic_P71]
Danno1985 Offline
Loc: Milwaukee, WI via NY
Great stuff man, sounds amazing!
2000 Crown Victoria LX. 160K. Duals, 3.73 trac-lok, currently rocking rally wheels with 215/65r16 Dunlop snows. Mobil 1 0W40 in the crankcase, Royal Purple 75W90 in the back. Still kicking'.
#2490242 - 03/27/12 11:50 PM Re: '05 CVPI + SW exhaust + Cams = [Re: BlackVic_P71]
Need MOAR videos!
#2490942 - 03/28/12 09:36 PM Re: '05 CVPI + SW exhaust + Cams = [Re: NGreen0807]
#2492220 - 03/30/12 04:54 PM Re: '05 CVPI + SW exhaust + Cams = [Re: NGreen0807]
250 I think.
Originally Posted By: KayTar
Need MOAR videos!
Soon.
#2492224 - 03/30/12 04:58 PM Re: '05 CVPI + SW exhaust + Cams = [Re: 6Paul11]
Cams - $639
Injectors - $176
Fuel pump - $125
If you want to use a local tuner that has SCT software, they can put it on your handheld tuner.
Or you can get a tune from Lonnie, much easier that way.
#2492773 - 03/31/12 03:45 PM Re: '05 CVPI + SW exhaust + Cams = [Re: BlackVic_P71]
6Paul11 Offline
Loc: Northern CA
Cool thanks. Was there an online site you purchased from or did you get them local?
Also I was reading some mustang forums about the Hitech's and they had an issue with clearance has that been an issue with the crown vics?
Lonnie has a tune for that setup already?
Edited by 6Paul11 (03/31/12 04:07 PM)
2003 CVPI
#2492817 - 03/31/12 04:57 PM Re: '05 CVPI + SW exhaust + Cams = [Re: 6Paul11]
These cams can only be ordered through HiTech.
If correctly installed, clearance shouldn't be a problem from what I've seen here.
Lonnie has a tune.
#2492864 - 03/31/12 06:25 PM Re: '05 CVPI + SW exhaust + Cams = [Re: BlackVic_P71]
interceptor1985 Offline
Loc: OREGON
You can try to wrap a sock around the camera, just leave the lens exposed to try and cut the wind a bit...
#2492909 - 03/31/12 07:46 PM Re: '05 CVPI + SW exhaust + Cams = [Re: BlackVic_P71]
martz0r Offline
Loc: Punta Gorda, FL
Who needs porn when you have those vids? Nice!
'07 Durango HEMI Limited 4x4
#2495059 - 04/04/12 12:52 PM Re: '05 CVPI + SW exhaust + Cams = [Re: BlackVic_P71]
6Paul11 Offline
Loc: Northern CA
Lonnie has a tune.
So with the boltons I already have listed in my sig would the Cams, fuel injectors, and fuel pump net me any gain. Some are saying without headers/freer flowing exhaust I'd be hurting performance.
2003 CVPI
#2495636 - 04/05/12 06:57 AM Re: '05 CVPI + SW exhaust + Cams = [Re: BlackVic_P71]
sounds mean man
I like it laugh
Page 2 of 2 < 1 2
6 registered (astrae, Rainbowpizza, Tove, DudeAbides, Davidzq, 02_LSE), 63 Guests and 171 Spiders online.
bluejay_32 163
Old_Guy_Stu 91
a_d_a_m 79
CrystalPistol 68
DudeAbides 52
TheCableGuy 52
RF_Overlord 48
Moby_Vic 47
Ponyguy 45
Bangster 42
