Page 1 of 4 1 2 3 4 >
#2544426 - 06/18/12 06:54 PM Peelpaint Special Paint project thread
Veikra Offline
Loc: Kanadia
Here's my 2005 getting painted. Because of the nature of the paint/primer issue I'm going back to bare metal.
Here it is, almost all stripped. Still need a lot of sanding but it's progressing.
Thoughts? comments? Questions? Feel free to ask
2005 Crown Victoria P71. 3.27 Trac-lok 310 000Km "Peelpaint Special" https://www.crownvic.net/ubbthreads/ubbthreads.php?ubb=showflat&Number=2544426#Post2544426
#2544441 - 06/18/12 07:25 PM Re: Peelpaint Special Paint project thread [Re: Veikra]
NCHeel Offline
Loc: Charlotte NC
Why not just rent a media blaster or use aircraft paint remover? Going to take a lot of sandpaper and elbow grease.
#2544460 - 06/18/12 08:02 PM Re: Peelpaint Special Paint project thread [Re: Veikra]
Veikra Offline
Loc: Kanadia
I'm using aircraft paint remover.
#2544486 - 06/18/12 09:09 PM Re: Peelpaint Special Paint project thread [Re: Veikra]
Nomad8326 Offline
Loc: Ohio
Well if your taking it back to bare metal anyway way not bring out bigger guns like paint stripper?
#2544508 - 06/18/12 09:59 PM Re: Peelpaint Special Paint project thread [Re: Veikra]
Veikra Offline
Loc: Kanadia
They didn't have any paint stripping disks left when I bought the mats. So I went with what I had smile
The aircraft stripper is really good, but needs more than 1 application to get the primer off.
I may try the disk and see how good they work.
#2544528 - 06/18/12 10:35 PM Re: Peelpaint Special Paint project thread [Re: Veikra]
Nomad8326 Offline
Loc: Ohio
I was thinking more along the lines of liquid paint stripper.
#2544529 - 06/18/12 10:36 PM Re: Peelpaint Special Paint project thread [Re: Nomad8326]
NCHeel Offline
Loc: Charlotte NC
Aircraft stripper is paint stripper on roids.
#2544532 - 06/18/12 10:39 PM Re: Peelpaint Special Paint project thread [Re: NCHeel]
Nomad8326 Offline
Loc: Ohio
Not the last time i tried it.
I tried to strip some front door trim with it and only with repeated applications was able to get some of the paint off.
I've been thinking about going for broke and using apparently stronger then aircraft stripper paint stipper and hope it doesn't destroy the plastic.
#2544607 - 06/19/12 12:17 AM Re: Peelpaint Special Paint project thread [Re: Veikra]
NCHeel Offline
Loc: Charlotte NC
I thought this stuff was Aircraft Stripper but maybe not. I use this and it is no joke.
#2544646 - 06/19/12 01:08 AM Re: Peelpaint Special Paint project thread [Re: Veikra]
Nomad8326 Offline
Loc: Ohio
That is what I used and that is the results I got.
Aircraft crap just smeared the paint around.
#2544794 - 06/19/12 11:25 AM Re: Peelpaint Special Paint project thread [Re: Veikra]
MyP71Vic Offline
Loc: Brookfield, WI
Dang! How long did it take to get it that far? I really need to do something like that to mine as well. I hate the peeling paint and I fixed one scetion but it is spreading in other areas and I just need to get it all done at once instead of doing little patch work. That looks pretty far along do you have a color in mind?
#2544829 - 06/19/12 12:28 PM Re: Peelpaint Special Paint project thread [Re: Veikra]
Veikra Offline
Loc: Kanadia
The aircraft stripper I'm using is US chemical aircraft paint remover. It works very good. IT WILL DAMAGE plastic. So you dont use it on the bumpers and remove as much trims as possible.
Nomad8326: Ive tried a bumper stripper made by SEM, it smeared the paint like you said. It needed a light sanding of the clearcoat to really work.
MyP71Vic: Yeah, I tried fixing a spot and the paint would crawl away from the repaint area. There is no other real fix than this.
It probably took 10 hours between chem strip and sanding. But if you took 2 gallon of the exat stripper I used, you could strip it in an afternoon provided you have removed the trims, lights and etc prior. Use da and 180 on the bumpers, they don't peel like the body so you can paint over them
#2544937 - 06/19/12 04:24 PM Re: Peelpaint Special Paint project thread [Re: Veikra]
Veikra Offline
Loc: Kanadia
pics after some more stripping.
#2545036 - 06/19/12 07:27 PM Re: Peelpaint Special Paint project thread [Re: Veikra]
NCHeel Offline
Loc: Charlotte NC
That's about ready to go. Sand it smooth so less primer can be used. You will find that the new primer will adhere to the old primer very well. The bumpers don't peel as bad due to the extra flex agent they add to the paint. They also paint the bumpers differently than they do the cars.
#2545708 - 06/20/12 08:11 PM Re: Peelpaint Special Paint project thread [Re: Veikra]
Veikra Offline
Loc: Kanadia
A little further. hood is now coated in epoxy
3 registered (derekghs, a_d_a_m, bobb), 61 Guests and 106 Spiders online.
bluejay_32 116
Moby_Vic 84
JeffBoudah 77
Old_Guy_Stu 73
Armada Master 53
a_d_a_m 48
DudeAbides 47
Dmblanch 46
Ponyguy 42
SocalSam 36
