#2553377 - 07/03/12 04:16 PM Car slows down rapidly/worn transmission?
maxknox Offline
Always thinking about Donald Duck Dunn
Loc: Euclid, Ohio
Couldn't turn up any results trying to find a similar issue so here's a question.
Anyone out there ever notice their car slowing down, most noticeably at freeway speeds, faster than it should?
I've noticed that since I had a j-mod(but not a full transmission flush) the car seems to slow down a bit too quickly when cruising at highway(55-70mph) speeds.
Immediately after my j-mod I noticed some transmission flutter when coasting at near cruising speeds. It felt like the car was try to slow itself way down. This has completely gone away. Still, I notice the car seems like it's dragging when I take my foot off the gas at higher speeds. I'm not carrying around extreme weight and I haven't used the car to tow anything ever.
My thought is that it's my torque converter but I don't even know if that would cause this. Any suggestions?
Originally Posted By Moby_Vic
It's not my fault you're all a bunch of soft pansies.
_________________________________________________
#2553417 - 07/03/12 06:08 PM Re: Car slows down rapidly/worn transmission? [Re: maxknox]
P71Ham Offline
Loc: Parkersburg, WV
Have you checked your bearings? A buddy of mine's truck did that before we replaced the bearings.
'01 Crown Vic. P73. 145k. Ex college president's car.
Mods so far:Bumper tuck, Sony Xplod head unit, sidemarker blink mod, New OEM headlight housings from ADTR, BH1976 Headlight Relay Harness, $40 junkyard 70mm TB (More to come as $$$ permits)
#2553437 - 07/03/12 06:53 PM Re: Car slows down rapidly/worn transmission? [Re: maxknox]
Dan04Merc Offline
Loc: CT
Are you sure it is in overdrive when you are driving at highway speeds?
2004 Grand Marquis
2011 Crown Victoria (Rear ended in a parking lot, total loss)
2007 Grand Marquis
#2553450 - 07/03/12 07:14 PM Re: Car slows down rapidly/worn transmission? [Re: maxknox]
Jeff_from_jeffco Offline
Loc: Mo, jefferson country
mine does the same thing and has with 3 different torque converters i stopped chasing the problem and just kept my foot on the pedal :/ im sure it has something to do with clearances etc but i cba to find it when working 13 hour days lol and im rebuilding a trans from the ground up and j-modding before install so i'll let you know if i feel a difference.
2000 p71 police interceptor from Town n County
Aftermarket stereo with 4 12 inch audiopipe subwoofers and 2 1500w rms amps 1 ohm stable smile
top speed run so far of 135
159,xxx Still running like a champ
jmod- with no springs
99 PCM/MAF, bumper tucked, 200 amp alternator upgrade, headlamp relay mod, wig wags, 102 inch whip with cb. - all done with ctrichsler's help
2004 cummins turbo diesel - 111k
2005 dodge SRT-10 pickup 37k miles
1995 dodge 1500 206k miles
#2553543 - 07/03/12 10:20 PM Re: Car slows down rapidly/worn transmission? [Re: maxknox]
TechnoWeenie Offline
Loc: The perimeter
calipers not releasing, axle bearing, and rear end, in that order.
#2553553 - 07/03/12 10:30 PM Re: Car slows down rapidly/worn transmission? [Re: maxknox]
thedanned Offline
Loc: Albuquerque New Mexico
Jeff might be on to something. If your torque convertor clutch is not releasing when you let off the gas it would do this. To check for this tap the brake pedal when it is slowing to release the clutch.
Sold:
2000 P71
99 Grand Marquis GS
Currently Pantherless.
Manley, Stainless Works, Edelbrock, Accufab, Steeda, Heinous, Hitech, Edge, 4.10s, and 225 255! tires
#2553557 - 07/03/12 10:37 PM Re: Car slows down rapidly/worn transmission? [Re: maxknox]
Crown2Victorious Offline
Loc: La La land
Next time you go to slow down and you want to eliminate the trans as the "culprit" just pop it in neutral. See if still does it.
2004 P71 Crown Victoria. (ex Brown County K-9 unit)
1995 Dodge Caravan (yawn)
1987 Crown Victoria LX (possibly for sale)
1991 Mercury Grand Marquis (bad trans at just under 250K)
#2553919 - 07/04/12 04:23 PM Re: Car slows down rapidly/worn transmission? [Re: maxknox]
maxknox Offline
Loc: Euclid, Ohio
I'll probably start by popping it into neutral. I assume that if the car stops slowing down in neutral that it's probably the trans?
I'll try tapping the brake too, I didn't realize that would do anything. Hopefully this doesn't get too deep.
#2553921 - 07/04/12 04:24 PM Re: Car slows down rapidly/worn transmission? [Re: maxknox]
maxknox Offline
Loc: Euclid, Ohio
And just to be clear, it doesn't feel like I'm jabbing the brake as soon as I let off the gas, but it's noticeable enough that I do feel myself go forward for sitting in my seat.
#2553924 - 07/04/12 04:26 PM Re: Car slows down rapidly/worn transmission? [Re: maxknox]
maxknox Offline
Loc: Euclid, Ohio
And the main reason I ask is because I drive over 95% highway and still only squeeze 21-22mpg avg.
#2553932 - 07/04/12 04:49 PM Re: Car slows down rapidly/worn transmission? [Re: maxknox]
With that MPG and symptom, are you sure it's shifting into O/D??
If acceleration is normal, I doubt there is a issue other than maybe no O/D...
Now with P/S & PDB
#2554002 - 07/04/12 07:29 PM Re: Car slows down rapidly/worn transmission? [Re: maxknox]
Loc: The perimeter
count the shifts.
On a GS with 2.73, should be in OD right around 40... With those gears, I could be going 60, let off the gas, and it'd take me a good 10-15 seconds to drop to 50....
If you had a ridiculously high gear, then I could see it... But 2.73s ARE 'highway cruising gears'.
#2554455 - 07/05/12 04:32 PM Re: Car slows down rapidly/worn transmission? [Re: maxknox]
D-Fenz Offline
Loc: Free America (WV)
I'd be suspicious of the axles/bearings personally. 03-early 05 were apparently troublesome.
2005 CVPI-Rick James-SOLD
1998 CVPI-Snow Beast-SOLD
1991 CVLX-Beast-SOLD
1987 Tempo-The Red Demon-RIP
Beef Supreme Tech News
#2555544 - 07/07/12 07:15 PM Re: Car slows down rapidly/worn transmission? [Re: maxknox]
maxknox Offline
Loc: Euclid, Ohio
Definitely shifts into O/D(assuming that an indicator is if I hit the O/D button and it shifts down, but I'll count to be sure). And I definitely have a shift at 40.(car does have 2.73s)
Tried tapping the brakes, no difference there.
If I'm at 70, it's ten seconds on a good day to coast down to 50 on flat pavement.
60-50 is probably 6-7 seconds.
I'll add axles and bearings to my to-do list.
Recently with this hot weather I haven't wanted to do much of anything, plus the heat is making the car idle pretty rough when it gets up to operating temp(which doesn't take long when it's 90 plus out).
Thanks for all the suggestions.
#2555547 - 07/07/12 07:18 PM Re: Car slows down rapidly/worn transmission? [Re: maxknox]
maxknox Offline
Loc: Euclid, Ohio
The FIRST thing I've done is probably the easiest which has been to change my driving habits(I'm sure I'm not the first to admit just how hard that is). Basically no more green light launches(I don't chirp the tires or anything to begin with) and no more flooring it on the freeway unless completely necessary... also less hard-braking, and I've always ALWAYS tried to avoid hitting my brakes above 55 mph and just let the car slow itself down when I need to.
6 registered (Svtmedic, DudeAbides, Moby_Vic, RF_Overlord, davedonahoe, 1 invisible), 74 Guests and 289 Spiders online.
bluejay_32 310
a_d_a_m 236
Rainbowpizza 186
DudeAbides 151
JeffBoudah 116
Moby_Vic 107
Old_Guy_Stu 86
Bangster 61
BigNSlow 58
2004_p71 55
