#2559143 - 07/14/12 09:32 AM
Re: '03 Marauder engine shudder...
[Re: a_d_a_m]
Loc: Mo, jefferson country
everyone can call me crazy but i can assure you if it happened right after i filled up i would still take the fuel pump out and atleast drain the tank and try getting gas at another station. may seem weird to everyone but if it happened right after fill up it is the fuel system (or atleast would be the system i check first). im leaning towards a couple things:
Fuel pump, fuel filter, bad fuel regulator allowing gas to seep in (diaphram has failed and is allowing 100% fuel instead of cutting off adding and so on) running rich, or the fact of bad gas. just the things i would check...
2000 p71 police interceptor from Town n County Aftermarket stereo with 4 12 inch audiopipe subwoofers and 2 1500w rms amps 1 ohm stable  top speed run so far of 135 159,xxx Still running like a champ jmod- with no springs 99 PCM/MAF, bumper tucked, 200 amp alternator upgrade, headlamp relay mod, wig wags, 102 inch whip with cb. - all done with ctrichsler's help Other vehicles: 2004 cummins turbo diesel - 111k 2005 dodge SRT-10 pickup 37k miles 1995 dodge 1500 206k miles
#2559210 - 07/14/12 12:40 PM
[Re: Jeff_from_jeffco]
Fuel pump, fuel filter, bad fuel regulator allowing gas to seep in (diaphram has failed and is allowing 100% fuel instead of cutting off adding and so on) running rich, or the fact of bad gas. just the things i would check... x2 it is very unlikely to see a perfectly running car go bad in few min unless you had an accident . my best bet is water in fuel
#2559274 - 07/14/12 03:30 PM
[Re: a_d_a_m]
i just find it funny how without any diagnostics nor any misfire codes spoken in this thread everyone jumps right to its a cop thats bad lol if its running that rough he had to have it towed all of your suggestions would have thrown a cel except the ones dealing with fuel haveing water in it. just my .02  before you throw wasted money into your car that may or may not need those parts... please take a fuel sample and let it sit for 2-3 hours and see if it seperates so we know if you got gas or water/gas. im still thinking its water in the tank.
#2559714 - 07/15/12 03:06 PM
[Re: a_d_a_m]
After talking to Pier last evening about this on the phone, I am inclined to start with the cheap fixes first and pull the fuel filter (needs a replacement probably anyway) and let the fuel sit for a little to see if it separates. I agree that it's suspicious that the problem started immediately after fueling up. The reason I am mostly worried is because of the ticking I heard a few days earlier, and because of the odor from the tailpipe. When I moved the car into the garage yesterday, I noticed that it didn't smell like burnt oil, but like SUPER RICH gas smell. I'm in Ontario right now; when I get home I will drop the fuel filter and keep everyone posted. And lest I forget, thank you everyone for their suggestions, input, whatever. I am only a semi-okay wrench and haven't had many problems with this car. Needless to say, stuff like this scares me.
#2559829 - 07/15/12 08:34 PM
[Re: a_d_a_m]
Loc: Cleveland, OH USA
Could you tell which side the ticking was coming from? Which side the exhaust is missing?
Rule the blown plug out for sure. It'd be a racket unmistakeable and your COP cover would likely be cracked or dented.
03 4v are notorious for overheating on the #7-8 holes due to lack of coolant circulation. Ticking is the main symptom of this. If you haven't done a cooling mod or had the revised head installed with the blue stripe on it I'd put even money on this being your problem with 108k on the clock. Surprised only one person has hinted at it yet. It's a possibility one of the exhaust seats came loose from uneven cooling and that caused the tick and now you have an exhaust leak at the chamber. This is worst case scenario, but very common.
Call the gas station back and see if any new complaints have come forward. They will probably say no regardless. Even if it is bad gas, knowing what I know I'd be pretty concerned about that tick if it isn't already the problem.
EDIT: Also, a hanging exhaust valve from a bad seat would scavenge raw fuel from the intake stroke. Less fuel in the chamber means lean condition. Lean condition means miss. It also means smelly exhaust. Just keep that in the back of your mind. If you want maybe I can swing up later this week and have a listen?
Keep doing what you're doing with the fuel until you rule everything else out.
Edited by prodigalson (07/15/12 08:38 PM)
Permanently banned.
#2560988 - 07/17/12 09:37 PM
[Re: prodigalson]
Loc: Boston, Mass.
Keep doing what you're doing with the fuel until you rule everything else out. That's a good suggestion/theory. My 1st '03 Marauder, which I purchaced almost new back in '04 had a horrendous tick and overheated constantly, at 5k miles no less. I ended up unloaded the car with 20k because of the constant issues. Hopefully this is not the case with Adams vehicle ...
Edited by Interceptor4LYF (07/17/12 09:40 PM)
CVN class of 2002 ("Interceptor4lyf")
#2560994 - 07/17/12 09:52 PM
[Re: prodigalson]
Which is exactly why I suggested listening to the rhythm of the engine as it spins over, this test takes all of 10 seconds... If it's uneven then the compression should be verified and forget about all the other suggestions until a reading is taken...
1998 Grand Marquis LS. 96K mi. .. Stock 2007 Grand Marquis GS. 90K mi. .. Stock 1996 F-150 XLT 196K mi Beater, Stock ---------- My Toys--------- (links are up)1969 Fairlane Cobra 428CJ 4-Speed 1972 Comet GT Restomod 306, C4 1988 Turbo Coupe 331 AOD & 3.73 .. Pressurized ½ Motor is History *****************NEW TOY!!!*********************1969 Base Fairlane 302, C4, 45K mi(really!) Now with P/S & PDB Gonna wake it up with a Blue Print headed 347
#2561178 - 07/18/12 05:50 AM
[Re: a_d_a_m]
never say never
Loc: Minneapolis, MN
I know you won't be able to tear into it for a while, and it could be bad, but try not to worry about it too much, it could be COPs. My old vic had a bad one, threw a CEL and drove like crap. Had to struggle to get to 50mph. My truck on the other hand, it only sometimes threw a CEL for COP issues (of which it's had plenty) in spite of running like it was about to explode.
#2561294 - 07/18/12 11:58 AM
[Re: a_d_a_m]
Loc: Free America (WV)
Sure sounds like a bad COP or bad plugs.
2011 Black CVPI-Charlie Murphy II, 125K miles, Gray Interior, Fog Lights, 35% Tint All Around, Working Shotgun Release, 3.27 RAR, 2017 Mustang Wheels.  2005 CVPI-Rick James-SOLD 2000 Exploder-Charlie Murphy I-SOLD 1998 CVPI-Snow Beast-SOLD 1991 CVLX-Beast-SOLD 1987 Tempo-The Red Demon-RIP Beef Supreme Tech NewsPlease put your year/make/model/mileage in your signature, it helps everyone answer your questions.
#2561375 - 07/18/12 02:49 PM
[Re: a_d_a_m]
Loc: Brookfield, WI
My 04 never threw a CEL but 3 COP's crapped out at once. Hopefully it will be ok it is bad enough the other one just got taken out.
2004 P71 Dodge County Sherrif 158K 3.27 Trac-Lock, BBK 78mm TB/Plenum, 1/2 inch spacer, SCT XCAL 2 Tuner with BOC Tune, OBX LT Headers Kit, ACCEL Super Coils, Light back tinted Headlights and Clear Side markers, 8K 55W HID, Heinous Control Arms from ADTR, 17 inch 06 GT Premium Rims Up next either cams, stall, or gears.
