#2562591 - 07/20/12 08:42 AM 2003 Crown Vic PI Shifts hard between 45-55mph
Fastz28 Offline
Loc: Dallas Texas
i have a 2003 84k miles and when i am driving on the highway it Shifts hard between 45-55mph would could be the reason the transmission fluid looks pretty pink dont know when it was last changed
Thank-you!!
03 crown Victoria police interceptor 230,000 miles
03 crown Victoria police interceptor 200,000 miles
05 crown Victoria LX 68,000(sat for years)
09 crown Victoria police interceptor 98,000
#2563796 - 07/22/12 04:00 AM Re: 2003 Crown Vic PI Shifts hard between 45-55mph [Re: Fastz28]
Run4orest Offline
Loc: NC
Hi,
Seeing that this is your second post I will just make a wild guess?
Did you just get the car within the past 6 months?
Perhaps resetting your transmission to get it off of the previous driving style will help?
Unless you have owned the car a while and this is something that is new to you?
If so, then not sure what to tell you..
There are threads you can find easy on resetting your transmission. Your transmission learns how you drive and adapts, if your last drivers where LEO's then it might want to "GO" while you now want to "cruise" and that,,, "might" be what ya are noticing?
Good Luck!
#2564346 - 07/23/12 05:19 AM Re: 2003 Crown Vic PI Shifts hard between 45-55mph [Re: Run4orest]
Fastz28 Offline
Loc: Dallas Texas
yes ive had that car for about a month now i was just thinking that the over drive kicks in somewhere 45-55 mph i never knew trannys can do that but then again i have never had a car this new sadly so it can learn how you drive that's weird considering that most police cars are driven by 1000s of people but mine belong to the fire chief he only got to use it the title had the city then his name underneath the city it was registered to
Thank-you!!
#2564348 - 07/23/12 06:13 AM Re: 2003 Crown Vic PI Shifts hard between 45-55mph [Re: Fastz28]
RF_Overlord Online   content
Under light throttle OD usually occurs at about 40, and should be fairly gentle, but noticeable. If yours is engaging "hard", as you say, then there may be some other problem.
#2564349 - 07/23/12 06:38 AM Re: 2003 Crown Vic PI Shifts hard between 45-55mph [Re: Fastz28]
One other thought: dunno if this will help.
I just acquired the Grand Marquis in my sig last week. I noticed it occasionally had what I would call a harsh engagement of OD, not like the typical shudder, but more like a momentary "br-r-r-p". Although the ATF appeared clean, not knowing the maintenance history I did a pan-drop, filter change, and drain plug install. Immediately after that, it did the br-r-r-p thing once more, but since then it's been fine. I did a second drain & fill yesterday and the transmission shifts like new.
My point is that even though the fluid "appears" OK, the additive pack can be depleted and a simple refresh may be all that's needed.
#2564378 - 07/23/12 09:29 AM Re: 2003 Crown Vic PI Shifts hard between 45-55mph [Re: RF_Overlord]
Fastz28 Offline
Loc: Dallas Texas
maby i should have the fluid and filter changed I am not a tranny expert at all i have read that having it "flushed" could be bad but just changing the fluid and filter without having it hooked to any machine should be alright
to reset the tranny i just unplug the battery right?
thank you
Thank-you!!
#2564736 - 07/23/12 11:45 PM Re: 2003 Crown Vic PI Shifts hard between 45-55mph [Re: Fastz28]
road_warrior Offline
Loc: ozark, MO
I solved the problem with a bottle of the lucas transmission aid stuff, immediate difference
1992 crown vic lx "victoria"
1987 grand marquis "zombie response operations"
1996 grand marquis gs "christine"
1995 town car m/m hearse "jezebel"
2001 crown vic p71 "the V8 interceptor"
2 registered (RF_Overlord, Rainyp71), 112 Guests and 17 Spiders online.
