#2562591 - 07/20/12 08:42 AM
2003 Crown Vic PI Shifts hard between 45-55mph
Loc: Dallas Texas
i have a 2003 84k miles and when i am driving on the highway it Shifts hard between 45-55mph would could be the reason the transmission fluid looks pretty pink dont know when it was last changed
Thank-you!! 03 crown Victoria police interceptor 175,000 miles 02 crown Victoria police interceptor 174,000 miles 02 crown Victoria police interceptor 139,000 miles(parts car 05 Crown Victoria LX (daily driver) 33,000(sat for years)
#2564346 - 07/23/12 05:19 AM
Re: 2003 Crown Vic PI Shifts hard between 45-55mph
[Re: Run4orest]
Loc: Dallas Texas
yes ive had that car for about a month now i was just thinking that the over drive kicks in somewhere 45-55 mph i never knew trannys can do that but then again i have never had a car this new sadly so it can learn how you drive that's weird considering that most police cars are driven by 1000s of people but mine belong to the fire chief he only got to use it the title had the city then his name underneath the city it was registered to
#2564348 - 07/23/12 06:13 AM
[Re: Fastz28]
i was just thinking that the over drive kicks in somewhere 45-55 mph Under light throttle OD usually occurs at about 40, and should be fairly gentle, but noticeable. If yours is engaging "hard", as you say, then there may be some other problem.
#2564349 - 07/23/12 06:38 AM
[Re: Fastz28]
One other thought: dunno if this will help.
I just acquired the Grand Marquis in my sig last week. I noticed it occasionally had what I would call a harsh engagement of OD, not like the typical shudder, but more like a momentary "br-r-r-p". Although the ATF appeared clean, not knowing the maintenance history I did a pan-drop, filter change, and drain plug install. Immediately after that, it did the br-r-r-p thing once more, but since then it's been fine. I did a second drain & fill yesterday and the transmission shifts like new.
My point is that even though the fluid "appears" OK, the additive pack can be depleted and a simple refresh may be all that's needed.
#2564378 - 07/23/12 09:29 AM
[Re: RF_Overlord]
Loc: Dallas Texas
maby i should have the fluid and filter changed I am not a tranny expert at all i have read that having it "flushed" could be bad but just changing the fluid and filter without having it hooked to any machine should be alright
to reset the tranny i just unplug the battery right?
thank you
#2564736 - 07/23/12 11:45 PM
[Re: Fastz28]
Loc: ozark, MO
I solved the problem with a bottle of the lucas transmission aid stuff, immediate difference
1992 crown vic lx "victoria" 1987 grand marquis "zombie response operations" 1996 grand marquis gs "christine" 1995 town car m/m hearse "jezebel" 2001 crown vic p71 "the V8 interceptor"
2 registered (LTC_Dave, Lil_Al),
75
280
