#2577788 - 08/12/12 05:36 PM Rear axle oil question
LapJ Offline
Loc: Montreal, Canada
A friend came at my house to check his car today and he show me recent repair bill
He got his 2 rear axle wheel bearing replaced at a "cheap" garage and I saw on the bill that they put standard 80w90 oil and they havent put the trac loc additive
Question is: do I absolutly need to put 75w140 oil or i can simply just add the additive??
2005 Quebec city police interceptor, BOC tune,KOOKS long tube w customs 2.5" full exhaust,75mm DBW throttle body,Accufab plenum,Ford Racing 3.73 gear, JMOD, R1 concept cross drilled premium rotor with HAWK HPS pads on 4 corners,Henious rear control arm, steeda underdrive pulley,marauder cluster swap,headlamp harness upgraded Kicker zr 800 old school amp, Orion 12" sub
JMOD done: 4
#2577799 - 08/12/12 06:09 PM Re: Rear axle oil question [Re: LapJ]
White Falcon LS Offline
Loc: SoCal
I had a tag on mine that read "75W140 Syn Oil Only". I'd imagine if it needed the additive, there would be a tag. What's the axle code on the door sticker?
#2577808 - 08/12/12 06:35 PM Re: Rear axle oil question [Re: White Falcon LS]
LapJ Offline
Addictive IS nedded on axle with trac loc im 100% sure
Question was about oil that im not 100% sure
door tag is x5
JMOD done: 4
#2577811 - 08/12/12 06:43 PM Re: Rear axle oil question [Re: LapJ]
Black_Sunshine Offline
I hope mine doesn't get addicted.
My factory service manual says that the additive is only needed for Trac Loc axles. If you have Trac Loc then you need 4oz. of additive in there.
The factory manual also says that you should run 75w140 for severe duty and 75w90 for regular duty. I put some 75w90 Mobile 1 in mine.
The manual says that it needs 5 pints of oil. It doesn't say anything about total capacity if you use additive. Mine has no additive and the oil started coming back out when I had gotten about 2.3 quarts in. I don't know if I over filled it or if I under filled it because I filled it while it was still elevated.
75mm DBW TB
� hood ornament
� c-pillar emblems
� LS style body side moldings
CarDomain
Facebook
#2577841 - 08/12/12 07:36 PM Re: Rear axle oil question [Re: LapJ]
LapJ Offline
If i remember correctly ive put 3 quart in mine+ additive
JMOD done: 4
#2577853 - 08/12/12 08:11 PM Re: Rear axle oil question [Re: LapJ]
Axle code X5 is for a 3.27 Trac-Lok, so yes...it needs the friction modifier additive. Probably be a good idea to step up to synthetic also, but it's not vital if he doesn't give it heavy-duty use.
#2577959 - 08/12/12 10:54 PM Re: Rear axle oil question [Re: LapJ]
fordoldfart Offline
Loc: kansas
You don't say what year the friends car is. It is hard to say what oil to use. If it needs the 75w-140 there should be a tag on the axle stating so. 2.3 qts is really close to 5 pints.
Edited by fordoldfart (08/12/12 10:55 PM)
#2577965 - 08/12/12 11:01 PM Re: Rear axle oil question [Re: LapJ]
LapJ Offline
2003
JMOD done: 4
#2577982 - 08/12/12 11:55 PM Re: Rear axle oil question [Re: fordoldfart]
Yeah but the fluid should not come all the way up to the fill hole.
75mm DBW TB
� hood ornament
� c-pillar emblems
CarDomain
Facebook
3 registered (Dmblanch, stalag, 1 invisible), 58 Guests and 276 Spiders online.
bluejay_32 210
a_d_a_m 136
CrystalPistol 133
DudeAbides 126
Old_Guy_Stu 123
Moby_Vic 84
ford05 63
JeffBoudah 58
Warped9 57
Ponyguy 56
