#1114547 - 01/27/07 06:59 PM Spotlight fuse location?
Benfolio Offline
Loc: Milwaukee, Wi.
Tried to search... got nothing. I got no power to the spotlight and all the fuses are good.
However I have no clue which fuse supplies the power to the spotlight, there's nothing in the owners manual that's concrete.
What's the most likely fuse?
I need a place to start.
1998 Subaru Legacy
1998 CVPI - SOLD
2001 CVPI - SOLD
www.SUPERMOTORS.net/users/Benfolio
www.MySpace.com/Benfolio
#1114548 - 01/27/07 07:01 PM Re: Spotlight fuse location?
99_03PantherS Offline
Loc: NW side Chicago
How do you have your spot connected?
does a wire run to the fuses?
Jason G.
'06 Towncar Designer
'81 Mark VI 2 door
'88 Towncar Cartier
'16 F-450 V10 DRW
#1114549 - 01/27/07 07:05 PM Re: Spotlight fuse location?
Darnon Offline
Loc: Attica, NY
I believe fuse number 20 was mentioned as being the spotlight fuse over in the other spotlight thread.
#1114550 - 01/27/07 07:09 PM Re: Spotlight fuse location?
Benfolio Offline
Loc: Milwaukee, Wi.
I didn't trace the wire, but the spot is connected however they connected it when it was installed back in the day.
I'll check #20 since there's not supposed to be anything there, and there's not. What amp fuse should I use though?
1998 Subaru Legacy
1998 CVPI - SOLD
2001 CVPI - SOLD
#1114551 - 01/27/07 07:11 PM Re: Spotlight fuse location?
It could also be a burnt bulb too.
Jason G.
'81 Mark VI 2 door
'88 Towncar Cartier
'16 F-450 V10 DRW
#1114552 - 01/27/07 07:12 PM Re: Spotlight fuse location?
Darnon Offline
Loc: Attica, NY
He said he doesn't have power at the spotlight, so I don't think that's an issue.
Fuse should be 20 amp.
#1114553 - 01/27/07 07:14 PM Re: Spotlight fuse location?
lpp71 Offline
Postimus Maximus
Loc: NW Indiana
If the light it self isn't working it might have just gone bad, I've had 2 go bad before, I hope it isn't but you never know. Also the side post plastic mounts are easy to take off and put back in, give that a try and see if you can find where the wire goes, I know there are 2 types of setups for those.
1999 Lincoln Town Car - 290k *** 1997 Lincoln Town Car - 95k
1998 Ford Crown Vic - 300k *** 2005 Mercury Sable - 160k
#1114554 - 01/27/07 07:16 PM Re: Spotlight fuse location?
Benfolio Offline
Loc: Milwaukee, Wi.
Not fuse 20. Put a 20A there and had power at the fuse, but still nothing at the wire that goes to the light before the switch.
I'm gonna go home, maybe I'll play with it later unless someone has a better suggestion.
Thanks for the help everyone!
1998 Subaru Legacy
1998 CVPI - SOLD
2001 CVPI - SOLD
#1114555 - 01/27/07 11:27 PM Re: Spotlight fuse location?
1998P71EL Offline
Loc: Macomb County, Mich
Did you check every fuse in the fuse panel under the dash on the driver side? I looked up the 2001 owners manual online(fleet.ford.com) under maintance and the fuse panel was the same for 98-00 but changed in 01. I have the 2000 book in front of me and in the fuse list it says....
FUSE LOCATION 8 15 AMPS LCM, POWER MIRRORS, KEYLESS ENTRY, CLOCK MEMORY, EATC, POWER WINDOWS, POLICE SPOT LIGHT, SECURILOCK
Since it's grouped with other stuff on a 2000, is there any other things not working in your ride? it's possible the continued the grouping in 2001, but didn't list it.
(Formerly EL1998P71) 1998 CVPI Ex-City of Romulus, Michigan, Now has 121,XXX miles (Started with 19,103)
#1114556 - 01/29/07 12:21 AM Re: Spotlight fuse location?
Benfolio Offline
Loc: Milwaukee, Wi.
Everything works... except the spot. I'm wondering maybe the wire was cut under the dash? The car had lights mounted on the mirrors and while the wires are there inside the doors, they were cut where the come out of the doors near the kick panels, so maybe they did the spot too?
Someday (when it's warm) I'll climb under there and have a look.
1998 Subaru Legacy
1998 CVPI - SOLD
2001 CVPI - SOLD
#1114557 - 01/30/07 06:40 PM Re: Spotlight fuse location?
cvertech Offline
Loc: Broad Brook, CT
I checked out one of our cars at my job. It is a former ct state police 2001 cvpi. I used a test light on the female plug for the driver's side spotlight power wire. I found that when i removed fuse #23 (15 amp blue) in the panel under the dash that it shut off the current to the spotlight wire. Hope that can help you Benfolio. The owner's manual for the 2001 model year does not say which fuse it was but try #23 and see what happens.
2000 Ford Crown Victoria LX "HPP" - Harvest Gold - Medium Parchment Leather
#1169073 - 04/14/07 06:39 PM Re: Spotlight fuse location? [Re: cvertech]
Benfolio Offline
Loc: Milwaukee, Wi.
Bringin' it back from the dead!!
I found the wire. It was cut and was just lying under the column. The cut end was near the OBD II data link connector, but there was no other end that it could have been cut from that I could see. I was assuming it would have been plugged into the back of the under dash fuse panel, but there are no wires cut there, nor is there a terminal just hanging out in the back of the fuse panel.
Should I just pick an empty fuse location and find a terminal, and plug it in there?
1998 Subaru Legacy
1998 CVPI - SOLD
2001 CVPI - SOLD
#2597926 - 09/17/12 10:25 PM Re: Spotlight fuse location? [Re: Benfolio]
jpeters05cvpi Offline
Loc: Mi, USA
Hey i have similar problem. I took apart the back of the spot light where the switch is and it shorted out while I was trying to fix the switch but it. I took every fuse out of every fuse box and they are all fine. the spot lights worked before but now neither of them do...i have dual spotlights and I cant figure out why they dont work now. can anybody help me? i traced the wire it goes down to a huge wire harness and goes along the kick panel where you open the door at...and then i lose it.
#2597971 - 09/18/12 12:54 AM Re: Spotlight fuse location? [Re: jpeters05cvpi]
K9Unit Offline
Loc: back in pa
you prob killed the switch inside were the out side switch makes contact its a chunk of plastic with wire coiled around it sounds like you fried em both best best is to remove handle and test spot light using a jump pack or something its how i narrowed it down i did the same thing and had to buy a new switch
1995 cvpi
#2598277 - 09/18/12 06:19 PM Re: Spotlight fuse location? [Re: K9Unit]
Loc: Mi, USA
I hooked 12v up to the wire were the bullet connector is both spot lights works...its not the switchs. what else is there that could go wrong?
2 registered (LTC_Dave, Lil_Al), 75 Guests and 280 Spiders online.
bluejay_32 155
Old_Guy_Stu 97
a_d_a_m 94
Moby_Vic 55
DudeAbides 53
CrystalPistol 50
TheCableGuy 47
RF_Overlord 44
Rainbowpizza 39
Ponyguy 39
