#2600470 - 09/22/12 11:01 PM
rear differential gasket
Loc: Lincoln, NE, USA
planning work out on car but can't remember what sealer...gasket maker...whatever i need to re-seal the cap on...anyone got recommendations or know what I'm looking for?
'06 P71 Crown Vic from Grand Island, NE Dual Exhaust With Muffler Delete & Welded Exhaust Tips Blue LED Bulbs Dome Lights,Glove Box,*NEW*Trunk LED strip's Sony DSX-S100 Stereo Deck Dual 12 in. Sony Explodes combined 2400w peak (1500w amp)
#2600473 - 09/22/12 11:10 PM
Re: rear differential gasket
[Re: tiburonsvh]
RTV, in a color of your choice because heat isn't really a factor back there.
Personally, I've never been a fan of RTV. I've never been good with it. Maybe I was using it back before I learned a lot of other things. Either way I prefer to use a gasket whenever possible. When I changed the oil in my diff I used a Felpro gasket. It was a rather plain and cheap looking gasket. It was less than $10. I figured that it was about the same cost as the RTV. The biggest thing with it not leaking in the future is correct and even torque. I'm glad I used the gasket because next time the job will be a snap because there is no old RTV to remove.
75mm DBW TB2005 Grand Marquis GS Two Tone Edition Vibrant White over Arizona Beige The GS Two Tone Package includes: � hood ornament � c-pillar emblems � LS style body side moldings � body color mirror caps (the b-pillars are body color too, but I don't know if that is package specific) � two tone interior (mine is leather and includes embossed logos on the seats) � front door sill plates that say �Grand Marquis� CarDomainFacebook
#2600475 - 09/22/12 11:11 PM
[Re: tiburonsvh]
I just went to AutoZone and got a Fel Pro cover gasket. Otherwise black RTV should do the trick. There is no pressure or heat (well not alot of heat) so it doesn't take much to seal them up.
#2600482 - 09/22/12 11:53 PM
[Re: tiburonsvh]
I use this Loctite product for gaskets: http://www.amazon.com/Loctite-39158-Hi-T...=loctite+gasket That is, when I can find it. When I can't find it I usually will tack it on there with a tiny bit of grease from the grease gun. I don't put anything on the silicone ones of course.
#2600608 - 09/23/12 11:15 AM
[Re: tiburonsvh]
Victor Reinz RDS55341 from CarQuest. Cork over a metal frame.
#2601807 - 09/26/12 12:49 AM
[Re: tiburonsvh]
Loc: Minnesota
The best gasket-in-a-can you'll ever find is Permatex "The Right Stuff". I sealed up my differential with that when I changed the fluid, and I used it to seal the oil filter adapter to engine block connection when I deleted my oil cooler. Neither area leaks in the slightest. Used it on other vehicles too, and not once has it EVER leaked.
2008 Grand Marquis LS, 138K miles 2014 Chrysler 300C, 97K miles (sold) 2005 Grand Marquis LS, 145K miles (sold) 2000 CVPI, 229K miles (sold)
0 registered (),
38
250
