#2615226 - 10/21/12 10:08 AM 2003-2004 PATS Disable and 2004 MZT instructions
This belongs in it's own thread as this question has come up, so some of this may seem familiar...
Since I based my work on mostly 2003 diagrams I will conclude that this procedure will work on a 2003 -2004 "retail" panther aka a P-73/P-74 and Grand Marquis. Should work on a Town Car but the starter relay location may be different.
This will also only work keeping the same year PCM as the car, the 2004 PCM won't work on a 2003 due to the transmission having a different tooth count on the OSS Also this process (Edit DOES WORK) MAY work on a 2005 up but with the CAN BUS system there may be many other problems, the PATS and starter interrupt circuits are probably the same or at least similar.
I started this in response to my PATS or the PCM failing and cutting the engine off but this swap is worthy even with a good running car as this deletes the PATS and can cost the same as getting a new key made, and of course to add the 80 MM MAF and Zip tube to a Retail 2004 to add 11 HP!!
First step is to swap the PCM, I found a 2004 P-71 2-04 build date and the PCM code matched the sticker on the door jam.
Since the 2004 P-71 also has the famous Zip tube and the 80 MM MAF with the 2005 up style blade MAF you gotta swap this over as well. As you see above I got a few 8 pin harness plugs so I can swap over the MAF pigtails if I want to run the stock PCM again or use the MM style MAF.
So I installed the 2004 P-71 airbox and Zip tube I already had, oh yeah the P-71 box is not for sale anymore now, I was already keeping the Zip Tube. Now I gotta put the spare MM airbox/MAF up for sale, but I plan to test it out on the car first to see if it would work with the P-71 computer.
Everything installed Reconnect the battery KOEO and CEL comes on the PATS light never blinks or makes any signal. Turn to start and no crank!!!!
Checked the harness in many places everything looks fine. I could not find any proper pinouts for a 2004, the 2004 DVD image I have only has 1 2004 model in it Feb 2003 edition.
Dejected with failure I come back in and search frantically for a possible answer and find this one...
Originally Posted By dRock96Marquis
03+, when turning the key forward, will do nothing. We tried swapping in a CVPI PCM into an 06 P70 as we were going to do the "920A" police equipment package upgrades (gear & torque converter) but were not able to get the car to start or even crank. drock96marquis told me about a wire needing to be grounded in the passenger side kick panel but would tell me nothing else.
So I am guessing there is something to what he said, he has knowledge in these cars so I am assuming what he said was legitimate, but he would say no further!
AND....if what he said COULD work, I'd assume would be something similar that could be done for 98-02 as well to disable the PATS....or at least "fool" it.
I think you may have picked some info from a few different posts of mine wink
There is nothing you can ground in the passenger kick panel that will have any effect on PATS operation.
Likewise, there is nothing you can ground (anywhere) to disable PATS entirely.
On 2003+ models the PATS system incorporated a starter interrupt so the vehicle cannot be cranked at all without the correct coded key (unlike -02 which would crank/no start)
This is done by the PCM (which controls PATS entirely for 03+) controlling ground for the starter relay coil. Power for the coil is still switched by the ignition itself, however the relay won't latch/starter engage unless the PCM also provides the ground to coil.
As PATS is/was a retail model feature, this wiring is only present on them.
On CVPIs, however, the relay coil is ALWAYS grounded - there is no PCM involvement with the starter circuit.
Jumping the starter relay coil to be always grounded on a retail model to duplicate the CVPI's configuration will disable the starter interrupt function of PATS on equipped 2003+ models, allowing the ignition to be turned and starter engaged whether
the key is coded or not.
However, AFAIK the PATS system still disables the fuel system as well - so even if you perform this starter relay bypass the vehicle will likely not start (instead behaving like -02 PATS, crank but no start)
I'm not completely certain on this as I haven't played with an 03+ PATS system to confirm, though I would hope they kept the fuel system disable as well!
So armed with this info I could not find any pinouts for the power distribution box. I was able to gleam enough from the 00-04 DVD to find the pin assignments for the starter relay.
So using the famous ISO diagram
86 = Start signal from ignition switch, power to Relay coil
85= Ground signal from PCM, Ground for relay coil.
30= 12V unswitched from battery, Current feed for switched power.
87A unused
87= power output to starter, Switched power output from relay
Did find the Dist box layout, but this is in my owners manual too
Could not find the diagram for the box, or the schematic of the wires the colors etc.. so plowing forward you see the classic ISO relay layout on the pins for the large 1" relay section.
And look at the Dist box, but noting the tabs marked on the relay ,the above diagram is "backwards" the view is looking at the relay unplugged from the dist box like in your hand
Ha this picture would have helped last night explains my point better.
So I removed the bottom of the dist box and found the wire for circut #57 leading from the #85 pin on the relay.
The #57 circuit is a grey/pink wire and its on the "top" of the bundle pretty much the only wire you can touch leading into the wrapped bundle., but pulling the bottom of the dist box off is pretty much needed to access the wire.
You see this jumper which is attached to the Neg cable.
I confirmed the 12V at pin 30 and #86 is 6V key off then 12V when turned to start. Ok, so plug in the relay go in to the car and...
SHE RUNS!!
Edited by Chevyguy (11/16/15 01:34 PM)
2004 Crown Vic LX SOLD!!
#2615381 - 10/21/12 04:45 PM Re: 2003-2004 PATS Disable and 2004 MZT instructions [Re: Chevyguy]
Better shots of the Distribution box
Just a few wires, not at all intimidating You can see the wire I cut and the wires for the relay are all visible.
The ground wire all routed properly and the Dist box reassembled.
Added a terminal end and attached properly along with the ground strap from the negative terminal to body cable. Don't want this coming loose 500 miles from home. Routed all clean
The MAF pigtail attached to the 8 pin
Temporary crimps I ran out of 22-18's
Replaced the crimps and wrapped it up with 3M tape
The harness tucked away, gotta cut off the stuck mount studs from the airbox and replace em with new ones. Then I will zip tie down the harness better.
All back together and cleaned up some, you do need the 80 mm zip tube to fit over the bigger MAF
Here is the size difference with a 70 mm MAF and 80 mm zip tube
Edited by Chevyguy (11/16/15 01:41 PM)
#2615740 - 10/22/12 01:48 PM Re: 2003-2004 PATS Disable and 2004 MZT instructions [Re: Chevyguy]
LimitedStreet Offline
Loc: Reading,MA
Very nice! If I ever end up with a non-P71 this'll help greatly.
2003 Crown Vic P71- LED Stuff, SW Long Tubes + Cat-back, 18" Fanblades.
#2619560 - 10/30/12 07:11 AM Re: 2003-2004 PATS Disable and 2004 MZT instructions [Re: Chevyguy]
Adding search terms as this was hard to find
2004 P-71 PCM swap
$100 MZT
#2816448 - 03/08/14 08:38 AM Re: 2003-2004 PATS Disable and 2004 MZT instructions [Re: Chevyguy]
I cleaned up my photobucket account. All the missing pictures can be found here
http://s348.photobucket.com/user/folingo...rt=3&page=1
I will end up captioning the album
#2837413 - 05/24/14 11:29 AM Re: 2003-2004 PATS Disable and 2004 MZT instructions [Re: Chevyguy]
ComputerGeek737 Offline
Loc: Tucson, AZ
Thank you for this thread, with all of this info I was able to swap in a 2004 CVPI computer with 80mm MAF and tube in my GM. Everything seems to be running great, even with the 2.73 gears it shifts very well.
For reference the car I got the computer from was an 08/03 build date and HWT2 code.
2004 MGM LS Ultimate
CVPI Front Shocks & Springs, 29mm front 21mm rear sway bars, CVPI dual exhaust added, 70mm TB, Arnott A-2220 Rear Air Bags, D2S 4.0 Headlights
#2837713 - 05/26/14 10:47 AM Re: 2003-2004 PATS Disable and 2004 MZT instructions [Re: Chevyguy]
GREAT!!!
I finally have a convert!!
#2837720 - 05/26/14 11:12 AM Re: 2003-2004 PATS Disable and 2004 MZT instructions [Re: Chevyguy]
Loc: Tucson, AZ
I did steal your idea and used connectors to be able to swap MAF cables which worked out quite well I think. grin
Here's a few pics, I'll upload more of the finished product later.
Pics
#2900783 - 06/06/15 08:26 PM Re: 2003-2004 PATS Disable and 2004 MZT instructions [Re: Chevyguy]
FrankSHORAGE Offline
Loc: VA
Confirmed... 2007 Crown Vic Sport (has 80mm from CVPI) , i installed a 2007 CVPI computer and grounded the 85 pin on the starter relay and viola...it started and runs like a beast!!!!!!!!!!!!
Edited by FrankSHORAGE (06/06/15 08:27 PM)
Frank
2007 Ford Crown Victoria Sport- Factory Moonroof
80mm CVPI ECU/MAF - MPT 93 TUNE / Race Shift - Heinous Billet Upper and Lower rear Control Arms - SW Catback with Flowmaster 40s - Addco Rear Swaybar - Marauder Wing - Bullit Mustang Front Chin Spoiler
#2905031 - 07/01/15 10:07 AM Re: 2003-2004 PATS Disable and 2004 MZT instructions [Re: Chevyguy]
GREAT!!!
Now I will add the 2005-2007 (probably up to 2011) will work with the $100 MZT!!!
#2906487 - 07/10/15 04:43 PM Re: 2003-2004 PATS Disable and 2004 MZT instructions [Re: Chevyguy]
Merc1973 Offline
Loc: MI
Bump for working pics? I would like to see how this is done. Thanks
[img]https://imgur.com/a/Y8I4i3r[/img]
2001 Grand Marquis GS, Tropic Green... MOD LIST:
17mm Sway bar, Bilstein shocks, ADTR Widened steel wheels, Tork Tech supercharger kit with m112 blower, 2.93 upper pulley, glowshift gauges, JMod, 2800 stall monster trans TC, BBK Longtube headers, aluminum driveshaft, 3.73 rar with LSD. 16 PSI screamer!
might know me on Discord as nowen97
#2906577 - 07/11/15 11:53 AM Re: 2003-2004 PATS Disable and 2004 MZT instructions [Re: Chevyguy]
#2906702 - 07/12/15 12:21 PM Re: 2003-2004 PATS Disable and 2004 MZT instructions [Re: Chevyguy]
I wish I could fix the thread pictures,
NOW I CAN since I have Moderator Superpowers!!!!!
the photobucket album pictures are now captioned (you have to start with the picture of my wife holding the air filters) so you can follow along!!
Edited by Chevyguy (11/16/15 01:42 PM)
#3870873 - 02/08/18 12:11 PM Re: 2003-2004 PATS Disable and 2004 MZT instructions [Re: Chevyguy]
Pukebucket is total failure
Here is the album, I have to download all the pics again as they are scattered among the stars
http://s348.photobucket.com/user/folingo...rt=6&page=1
#3871281 - 02/09/18 01:14 AM Re: 2003-2004 PATS Disable and 2004 MZT instructions [Re: Chevyguy]
bspurloc Offline
Loc: New England
I did this to my 2003 because it was cheaper than replacing the shot civilian PCM.
The 2003 PI PCM cant use an 80mm MAF without a program adjustment right?
'03 Sport
'07 Audi Q7
