#1433625 - 03/26/08 01:23 PM
Re: Gear Swap: Did I bite off too much, went with
[Re: Allen Maty]
Loc: North Bloomfield, Ohio
Now here is a guy that isn't afraid of the price of gas and the power of a V8. Thats awsome!
Sounds like all you really need is a tune a Drive shaft and your in business.
how low of gears would the aluminum D/S be good to?
02 GMQ HPP 88k miles 4th panther I have owned no mods yet..... My Garage: www.supermotors.net/8297Loud pipes save lives!
#1433772 - 03/26/08 04:50 PM
[Re: dRock96Marquis]
Loc: Sacto. Calif.
Whiplash disclaimer come with 4.30s?
#1433796 - 03/26/08 05:21 PM
[Re: Mileaway]
Loc: Bowie, MD
Wow.
2.73's to 4.30's, that's quite an impressive leap.
Absurd signature chopped. Read the rules.
#1433846 - 03/26/08 06:13 PM
[Re: natedog]
Loc: Glendale, CA
I would sure say. I have 3.55s and im worried bout gas prices. haha. tell me how the 4.30 gears work. eventually i might swap my gears.
04 Crown Victoria LX Sport 95 AM General Hummer
#1433871 - 03/26/08 06:47 PM
[Re: whdahel]
Loc: Seekonk, Ma
how low of gears would the aluminum D/S be good to? Excellent, seconded! By the way does he have the lowest gear on CVN, I can't recall a lower gear in someone's car?
2002 CV LX Sport Speed Bleeders installed with the new brakes!10/07-brakes 85K at the time http://www.flickr.com/photos/ [email protected]/2382004080/
#1433916 - 03/26/08 07:44 PM
Re: Gear Swap: Did I bite off too much, went with 4.30
[Re: Al]
very interesting ratio
what rpms are you hitting at various mphs
you are geared lower than many 1 ton trucks
1997 P71 145K miles
#1433932 - 03/26/08 07:57 PM
[Re: observer]
Loc: wichita
he's got lower gears than a OTR Truck they only come with 4.11 altho id like to see a vic with 4.56 gears
#1434068 - 03/26/08 10:46 PM
[Re: 95merckid]
Loc: Sioux Falls, SD
4.30 is a CV is insane. They would be good for running 1/4 miles and if you wanted to pull something the size of a mobile home. 4.10 in a pickup are more reasonable because they have a taller tire thus more mph per rpm of the axleshaft. I useto drive a 89 F250 without overdrive and it would turn 3000 rpms at 60mph so the 4.30 ratio in the CV would be even worse. So ballpark rpm of the driveshaft at 85 would be in the neighborhood of 4500. With a .70 OD ratio that would put the engine rpm a little over 3100. Hope you add some protection for yourself from the driveshaft. It will be a murder weapon when it flys apart and goes thru the floor and out the roof.
#1434110 - 03/26/08 11:20 PM
[Re: autotech57103]
Seriously people, is the driveshaft that big of a problem on crown vics? I don't understand why it would be. I've pushed my Cobra to 160mph several times and it holds up fine, even at 5500rpm in 4th (which is about 120 if I remember correctly). Seriously, is there something I'm missing??
#1434123 - 03/26/08 11:27 PM
[Re: Quickvic30]
YES it's about 2 feet longer than a stang shaft. Which is what I assume causes flexing at higher RPMs?
#1434173 - 03/27/08 12:10 AM
[Re: MountainDewSVT]
Loc: Rochester NY
Seriously people, is the driveshaft that big of a problem on crown vics? I don't understand why it would be. I've pushed my Cobra to 160mph several times and it holds up fine, even at 5500rpm in 4th (which is about 120 if I remember correctly). Seriously, is there something I'm missing?? yup this aint no mustang.. so get those thoughts out of your head... as far as pulling the quarter mile.. no way he will pull those gears on a stock motor... he hasnt got enough motor
2006 LX with HPPBlue, Light Camel Interior,Magnaflow Exhaust,PI Zip Tube Underdrives from ADTR.net Pioneer AVIC X930BT Nav system, JL xD400/4amp, JL Speakers, Audiovox backup camera Given to DG in Ohio
