#1434182 - 03/27/08 12:18 AM
Re: Gear Swap: Did I bite off too much, went with 4.30
[Re: Big_Bad_Joe]
good point joe. to have the ideal setup, you should match the gearing to engine. right now my 3.55s are just about ideal. once i go to a pi intake with my other mods, something more aggressive(though slightly) will be optimal. although, i would love to feel what those 4.30s are like, lol.
-Current: 2001 Crown Victoria P74  -Gone, but not forgotten: 1988 Mercury Grand Marquis 1994 Ford Crown Victoria 2000 Ford Crown Victoria HPP 2004 Ford Crown Victoria LX Sport 2004 Mercury Grand Marquis
#1434275 - 03/27/08 04:28 AM
[Re: BigJon]
Loc: Glendale, CA
If i do a PI intake with a new plenum and 70mm throttle body with a short ram intake fed by a CAI Ram Air plus shorty headers and a custom exhaustwould my stock 3.55 Gears be fine? I'm going to switch to posi if that makes a difference. Thanks
04 Crown Victoria LX Sport 95 AM General Hummer
#1434331 - 03/27/08 07:57 AM
[Re: REAL4WD]
your 3.55s will be fine. definitely get the trac-lok(posi), you will love it.
#1434339 - 03/27/08 08:12 AM
[Re: BigJon]
[email protected]
Loc: ATL
you need a drive shaft loops most def. I would also do the forced lube mod and try and find you a MMC driveshaft.
#1434664 - 03/27/08 04:22 PM
[Re: Big_Bad_Joe]
Loc: SC
as far as pulling the quarter mile.. no way he will pull those gears on a stock motor...
he hasnt got enough motor
Can you please explain what you mean here?
#1435006 - 03/27/08 09:43 PM
[Re: Bigcarlover]
Loc: Sioux Falls, SD
Suppose if you are delivering pizza in a neighborhood that rarely sees hiway those gears would be ok, lol
#1435031 - 03/27/08 10:02 PM
[Re: Bigcarlover]
Can you please explain what you mean here? in layman's terms, you need more hp to be truly beneficial in the 1/4 mile. steeper gears help with tq multiplication. once the gearing is 'used' you need the hp to take over. you do not have enough.
#1435249 - 03/28/08 07:13 AM
[Re: 98VicP71]
Loc: Glendale, CA
your 3.55s will be fine. definitely get the trac-lok(posi), you will love it. Thanks. Is the trac-lok hard to install? you need a drive shaft loops most def. I would also do the forced lube mod and try and find you a MMC driveshaft. and i believe a already hav a mmc driveshaft due to the fact i own a CVPI.
#1435252 - 03/28/08 07:19 AM
[Re: REAL4WD]
[email protected]
Loc: ATL
your 3.55s will be fine. definitely get the trac-lok(posi), you will love it. Thanks. Is the trac-lok hard to install? you need a drive shaft loops most def. I would also do the forced lube mod and try and find you a MMC driveshaft. and i believe a already hav a mmc driveshaft due to the fact i own a CVPI. you will want to physically check your DS to make sure it is MMC as it was only an option the aluminum DS was standard on all CVPIs. Track lock install requires the entire rear end to be torn down and rebuilt from what I understand so it would be something you may want a shop to install. Don't quote me on that but that is what I understand anyway.
#1435527 - 03/28/08 02:17 PM
[Re: 98VicP71]
Loc: Seekonk, Ma
It is difficult if you don't have experience on rear ends....I've been thinking bout doing it myself but this is one area I don't have any "wrench time on". So the Vic will go to the shop when I find 3.55's and a job:) Already have the trac-loc in the basement thanks to Buck
2002 CV LX Sport Speed Bleeders installed with the new brakes!10/07-brakes 85K at the time http://www.flickr.com/photos/ [email protected]/2382004080/
#1436114 - 03/29/08 03:11 AM
[Re: 98VicP71]
Loc: Glendale, CA
your 3.55s will be fine. definitely get the trac-lok(posi), you will love it. Thanks. Is the trac-lok hard to install? you need a drive shaft loops most def. I would also do the forced lube mod and try and find you a MMC driveshaft. and i believe a already hav a mmc driveshaft due to the fact i own a CVPI. you will want to physically check your DS to make sure it is MMC as it was only an option the aluminum DS was standard on all CVPIs. Track lock install requires the entire rear end to be torn down and rebuilt from what I understand so it would be something you may want a shop to install. Don't quote me on that but that is what I understand anyway. and how do i know how to tell the difference between an aluminum and a mmc driveshaft?
#1436119 - 03/29/08 03:36 AM
[Re: REAL4WD]
seeing that you have a 00 p71, you have the ammc ds. unless someone swapped it out, i doubt that.
#1437804 - 03/31/08 07:31 AM
[Re: BigJon]
[email protected]
Loc: ATL
you can't say he is garanteed to have the MMC driveshaft as it was an option just like the 3:55 gears. I have seen some 99's and 00s with the normal aluminum drive shaft and 3:27 gears.
There is a thread on the board already about the MMC shaft and how to determine if you have it.
I believe it is a green stripe or something on it. I can't remember off the top of my head though.
