Page 10 of 13 < 1 2 8 9 10 11 12 13 >
#2637401 - 12/08/12 09:03 PM Re: The Marauder Cluster Swap... [Re: Ezbok58a]
Ezbok58a Offline
Loc: Who wants to know...
And with that another crisis was averted.
#2637456 - 12/08/12 11:01 PM Re: The Marauder Cluster Swap... [Re: MEvans043]
Originally Posted By: MEvans043
Ok, I've decided to finally get my Marauder gauge swap going so, I need some help.
I picked up an extra set of cluster pigtails at the the junkyard today. I plan on re-pinning them and then wiring it up to my car so then all I have to do is match wire color.
You gonna practice repinning on the donor plugs?
#2637467 - 12/08/12 11:11 PM Re: The Marauder Cluster Swap... [Re: Ezbok58a]
MEvans043 Offline
Loc: Upstate, New York
No, I miss-spoke.
What I planned on doing is to use the pigtails and re-pin them.
Then cut off the connectors from my cars cluster and wire it up by matching the pin colors from one pigtail to the other.
But... I just realized I got these pigtails from a 2001. That has different pins than 03-05 so I won't be doing it that way.
04 P71- 5 speed manual
Clicky >>TR3650 5 Speed Swap
#2637657 - 12/09/12 11:31 AM Re: The Marauder Cluster Swap... [Re: MEvans043]
Just use the donor plug to practice taking the pins out then repin your factory plugs, once you get started it's not that hard. You will need a donor pin or 2 so it helps to have those plugs anyway.
#2637660 - 12/09/12 11:37 AM Re: The Marauder Cluster Swap... [Re: Ezbok58a]
MEvans043 Offline
beer1
Thanks Tom, we'll do.
#2669138 - 02/14/13 08:41 AM Re: The Marauder Cluster Swap... [Re: Ezbok58a]
Bowtie_Vic Offline
Loc: Kansas
Man how did I miss this! I've been wanting a tach and 140 speedo for my '97 Turbo Vic so badly!
Definately going to pursue this very soon!
'03 Mercury Marauder, Coyote 5.0L/6R80 swap
Master Certified Blue Oval Dealership Technician since 2004
My Demonstration of a proper burnout
#2673627 - 02/23/13 10:59 PM Re: The Marauder Cluster Swap... [Re: Ezbok58a]
MEvans043 Offline
Ok. Finally started on my cluster swap today. Reading through this thread I found out that I wired up the Tach Adapter wrong. I wired it up to a single coil instead of the whole inline coil wiring, so that will have to be addressed before I continue to much more. It's at least a good thing that I used bullet connectors, so reconnecting the cut coil wire is easy.
#2673652 - 02/23/13 11:41 PM Re: The Marauder Cluster Swap... [Re: Ezbok58a]
MEvans043 Offline
One thing I don't understand is how the spark is distributed.
https://www.crownvic.net/drock96marquis/images/tach/03-tach.jpg
According to this diagram of Derek's, the inline power feed splices power to each coil and obviously it pulses 8 times per revolution.
But how are these pulses "routed", for a lack of a better term, to each coil in the correct sequence? Is there an ignition module somewhere that controls this?
#2673688 - 02/24/13 12:54 AM Re: The Marauder Cluster Swap... [Re: MEvans043]
Ezbok58a Offline
Are you talking about the feed for the tachometer?
The way it was explained to me was find the common wire on all 8 coils, then follow the harness they all join into and splice into that common wire later in the loom.
#2673778 - 02/24/13 10:44 AM Re: The Marauder Cluster Swap... [Re: MEvans043]
Do not leave a temporary connector on there, fix the wire so there is less chance for problems(like corrosion) later on.
#2677205 - 03/03/13 04:39 PM Re: The Marauder Cluster Swap... [Re: Ezbok58a]
MEvans043 Offline
So I'm so [censored] confused now.
I rewired my Tach Adapter, the correct way this time, checked my pins and connections, and still have no function out of the Tach.
I don't know why the Tach has no function at all. Everything else on the cluster works...
#2677244 - 03/03/13 07:01 PM Re: The Marauder Cluster Swap... [Re: Ezbok58a]
MEvans043 Offline
Can anyone offer any advise? I'm completely stumped on this one...
#2677247 - 03/03/13 07:11 PM Re: The Marauder Cluster Swap... [Re: Ezbok58a]
Ezbok58a Offline
Any life out of the tach at all? This is interesting.
#2677251 - 03/03/13 07:24 PM Re: The Marauder Cluster Swap... [Re: Ezbok58a]
MEvans043 Offline
Not a single sign of life.
I have power to the pins, and the tach adapter is providing a signal, but still no worky. Not even a twitch of the tach needle.
#2677252 - 03/03/13 07:26 PM Re: The Marauder Cluster Swap... [Re: Ezbok58a]
KGIXXER7 Offline
Loc: Lansing, MI
is the needle pushed in to far? if it is pushed on to far it will get stuck. just something easy to check
05 P71 20/5% tint, window trim blacked out, Badgeless grille, Ported Plenum, Underdrive Pulley's, 19" GT500 replica wheels, marauder interior
0 registered (), 59 Guests and 12 Spiders online.
