Page 11 of 13 < 1 2 9 10 11 12 13 >
#2677255 - 03/03/13 07:36 PM Re: The Marauder Cluster Swap... [Re: KGIXXER7]
MEvans043 Offline
Loc: Upstate, New York
Originally Posted By: KGIXXER7
is the needle pushed in to far? if it is pushed on to far it will get stuck. just something easy to check
That's a possibility, I did install custom gauge faces on it.
Does anyone know what the tachometer signal type should be? I think it may be a square wave w/ varying frequencies, but I'm not sure.
04 P71- 5 speed manual
Clicky >>TR3650 5 Speed Swap
#2677550 - 03/04/13 11:43 AM Re: The Marauder Cluster Swap... [Re: Ezbok58a]
MEvans043 Offline
Anyone know? If it is infact a square wave it would explain why my digital multimeter does not acurrately measure the output of the tach signal.
#2677560 - 03/04/13 12:04 PM Re: The Marauder Cluster Swap... [Re: MEvans043]
Florida_Mike Offline
Loc: Northeast Florida
Why not pick up a cheap aftermarket tach to check it?
‘04 Ice Blue P73 (POTM Jan ‘22), MZT Mod with ADTR intake pipe, Ported Plenum, BBK 70mm TB, BOC 93 Octane Tune, Dual exhaust with Magnaflows and MM tips, Fanblades with 235/50/18 Front - 245/55/18 Rear, KYB Shocks, Adco swaybars, Marauder Rear Spoiler, Aftermarket Marauder front and rear bumpers, Bumper Tuck, blacked out headlights, Marauder corner lights, Marauder fog lights, GCC Grill, body colored mirror shells. (MM cluster waiting for install.)
#2677620 - 03/04/13 03:04 PM Re: The Marauder Cluster Swap... [Re: Ezbok58a]
MEvans043 Offline
Hmm, I hadn't thought about that... I may try that if I continue having issues.
#2677655 - 03/04/13 04:18 PM Re: The Marauder Cluster Swap... [Re: Florida_Mike]
That's what I did when trying the tach in my '05 before hooking up the Marauder cluster, that way I knew the hook up worked before going through the steps.
#2678175 - 03/05/13 07:31 PM Re: The Marauder Cluster Swap... [Re: Ezbok58a]
Have you still spliced into a single coil wire? That won't work.
You need the main coil feed wire which is pin 34 on C127 (the large connector under the brake master cylinder) on my 1999. It's red with a light green stripe on my car.
#2678198 - 03/05/13 08:16 PM Re: The Marauder Cluster Swap... [Re: NGreen0807]
MEvans043 Offline
I have it wired to a single coil,(cylinder 8 I think), as called for in the wiring instructions. It's a MSD 8913 Tach adapter.
#2678208 - 03/05/13 08:56 PM Re: The Marauder Cluster Swap... [Re: MEvans043]
gplayer Offline
Loc: Atlanta, Georgia
Thats almost the same problem OP had. You read this whole thread right? He had to wire it to the main coil wire to get enough power to make it work right.
1993 Crown Victoria LX Dead and gone
2003 Acura Cl Type-S, current DD, 140,000 miles. 6 speed manual (One of ~3750). Pioneer single low profile 10 inch, Pioneer GM5100T.
1970 Chevy C20 Project truck, SBC, 4 speed manual. Go-Fast goodies include: 400 crankshaft, bored .030 over, Vortec heads, Comp Cams XR252HR, hardened pushrods, 1.6 roller rockers, Scat Pro Stock forged connecting rods, Edlebrock Air Gap intake, Holley 650 Carb, Mallory Unilite distributor. Suspension: Front disc brakes with 2.5 inch drop spindles, Hotchkiss shocks, 4 inch drop coils in the rear, 3.73 gears, 265/40/R18 rear tires, and American Racing Torque thrust 18's. 13.9 1/4 mile.
#2678226 - 03/05/13 09:25 PM Re: The Marauder Cluster Swap... [Re: gplayer]
MEvans043 Offline
I've read it probably 3 times now. Still confused. The instructions MSD gave me contradict what you're telling me to do.
#2678228 - 03/05/13 09:34 PM Re: The Marauder Cluster Swap... [Re: MEvans043]
gplayer Offline
Well, not to be a dick, but its obviously not working with what msd is telling you, right? but OPs is working with the main coil wire. I would give it a shot.
#2678235 - 03/05/13 09:51 PM Re: The Marauder Cluster Swap... [Re: Ezbok58a]
MEvans043 Offline
The problem is it's not working at all. When the OP had it wired the "wrong way", he was at least getting 1/8th of the tach signal. I'm getting nothing at all.
#2678270 - 03/05/13 11:22 PM Re: The Marauder Cluster Swap... [Re: Ezbok58a]
Just went ahead and drew a simple diagram and read the instructions online for you Morgan. Texted it to you.
You do indeed need to interrupt the wire I mentioned earlier and run it through the box with the red and red/green wires on the MSD harness.
#2678272 - 03/05/13 11:25 PM Re: The Marauder Cluster Swap... [Re: Ezbok58a]
I do speak the truth. Pulled from MSD's website for #8913
#2678275 - 03/05/13 11:30 PM Re: The Marauder Cluster Swap... [Re: NGreen0807]
MEvans043 Offline
Well. I do believe I've wired my Tach-adapter wrong twice now. mad
Thanks Nick, I was looking at this diagram ALL wrong!
#2678291 - 03/06/13 12:05 AM Re: The Marauder Cluster Swap... [Re: Ezbok58a]
Here's for 2003+ Morgam. Still pin 34. RD/LG circuit 16
4 registered (ford05, alumarine, CarMon, Scuba_Steve), 147 Guests and 5 Spiders online.
