Page 1 of 53 1 2 3 52 53 >
#268532 - 10/18/03 05:31 PM Stickaroo!! The Vast 4k#Fe HO/T5 Swap Chronicle
4000_Pounds_of_Iron Offline
Loc: Nashville, TN
I'm finally getting the old girl apart. This will be the start of a stupid-huge thread (I like starting those) that will give a play-by-play of the HO/T5 swap into my 1991 P72. Today is day 1, October 18, 2003, and I have begun removing the accessories from the pansy 5.0 currently installed. I have removed all the driver-side accessories and brackets, alt, PS pump, and intake tract, as well as disassembled the TB/EGR spacer ass'y so I can have it bored to 63(?) mm. Began the passenger accessory removal, ran out of time before the A/C compressor surrendered.
Tech Question of the day:
What the &@%@!* am I supposed to do when I need an EGR spacer larger than 63mm? Stang parts don't swap here.
Wish me luck.
4k#Fe
Edited by 1987LTDmasta (11/20/03 10:53 AM)
#268533 - 10/18/03 05:41 PM Re: The Vast 4k#Fe HO/T5 Swap Chronicle
Ghost Offline
Loc: Houston County GA
If you have a camera lots of pictures would be great.
2003 Crown Vic Sport
XCAL 2 from RA
Marauder rear sway bar
17mm rear sway bar and 28mm front avail to anyone local that wants them.
#268534 - 10/18/03 05:57 PM Re: The Vast 4k#Fe HO/T5 Swap Chronicle
frzx3 Offline
I am guessing you are staying EFI, if so what are your plans for the car? Just upgrading to HO specs and adding a T-5?
#268535 - 10/19/03 04:07 AM Re: The Vast 4k#Fe HO/T5 Swap Chronicle
Loc: Nashville, TN
I don't have a digital camera at the moment, but I'm going to buy a cheapie as soon as I get to more interesting parts of the swap that have not been previously documented, I.E. the floor shifter and pedal installations and the actual engine install process.
The destination of the car for now will be a nearly stock 5.0L HO speed-density EFI engine with a stock T5 and 3.27 open rearend. Immediately thereafter will be a limited slip of some kind, hopefully a Torsen-type helical gear unit, but more realistically a stock Traction-Loc, with perhaps a step to 3.55 or 3.73 gearing depending on how it performs with the milder rearend.
Next will be a MAF conversion. I have two meters on hand but no computer as yet, followed by a headswap or port work on the E7s, with an intake, throttle, spacer, and MAF to match. I will be staying with the stock HO cam permanently as I am not willing to compromise idle quality, though a swap to 1.7 rockers is possible. I may also consider a junkyard turbo project if I get really ambitious, or perhaps a Kenne Bell type blower if I get really rich. I'm not a big fan of centrifugal blowers, as far as I'm concerned they are the worst of both worlds when it comes to boost. I'll be keeping the T5 until it breaks. If I wear it out, I'll rebuild it, and if I break it, I'll try to score a cheap T56 or 3550 to replace it.
Exhaust will be stock Mustang headers and a stock Stang catted H-pipe, cheapo no-fiberglass turbo mufflers, black side exit pipes if I'm cheap or maybe slash-cut stainless tips out the rear if I find a little dough for it.
Interior will remain mostly stock, perhaps dyed to black, with a set of late Japanese-car bucket seats since we Americans still can't seem to make a decent set of chairs with reasonably firm padding. I have considered entirely replacing the instrument cluster with a street-rod type gauge package, including the speedo, but I like the cop-car chic of the stock 140 speedo also. I have a few interior issues to repair, and I'll be retaining the stock rear bench seat, and leaving the door handles off of the rear doors. The stock rubber floor will remain, and I will likely add cruise control and power locks.
I already have a Kenwood CD player, Infinity 10" sub, and an 85Wx4 RMS amp to install, with a nice set of 6.5" component speakers up front and JBL 6x9s in the rear. Sweet, but not too loud, just tight and clean.
Paint will remain white for the forseeable future, with a good trim-off all over repaint to freshen the looks. I have a few door dings to fill and I need a new passenger headlight bezel and header panel, both are cracked. There is no rust anywhere. My car also never had a spotlight, so I only have a few antenna holes to fill. I'm going to keep the dog-dish caps as well. Hopefully I can figure a way to upgrade the 6.5" rims to 15x8s or 16x8s while keeping fender clearance and the dog-dish caps. I'm aiming for 255 width all-season performance tires all around, regardless of diameter. I would like to enlist Stockton Wheel for this service, but it's more than likely I'll be staying with 225/70s on the stock 15x6.5s for a long time, due to my low budget.
Comments?
4k#Fe
#268536 - 10/19/03 04:50 AM Re: The Vast 4k#Fe HO/T5 Swap Chronicle
kustomsquire Offline
Sweet, sweet, sweet!!!!
1.Supposedly a 65mm t.b. unit will still work just fine with the egr spacer bored to 63mm. No air issues there. (SUPPOSEDLY)
2. I recommend dynomax super turbo's for the exhaust. Approx 30+ a piece real quiet at first, but will open up. As for fiberglass blow outs, they're supposed to be real good, I have them love the sound (now) and have no issues with the fiberglass.
3.As for wheel clearance you should have no issues with 15X7 or 8's. Keeping the dogdishes may be a problem though. You could send your wheels out to be widened. Or you may consider using trying a "steel smoothie wheel" try
www.wheelvintiques.com or www.petepaulsen.com . Paulsen's cheaper I think. They're real old school like 50's, but with those you could keep a chrome cap and just paint the outerwheel black, giving you pretty much the same look. Should cost you less than $250.00 for all 4.
good luck on your project, stay focused ! I'm pretty much right there with you,time and work wise.
cheers!
1990 ex-Country Squire 302 Proproducts Intake, Compcams Nitrous cam,street/strip stang AOD (now dead),BBK shortie headers (stage 8 locking bolts) into ,Mac H pipe 2 1/4 duals and Dynomax mufflers, BBK intake, Ford Racing wires, trac-lock w/3.73's, Energy Suspension sway bar bushings/end links, police steering box.
http://www.superford.org/registry/vehicles/index.php?vID=3117
"my mother always used to say this was too much car to handle...you couldn't handle the v8"
-starsky
#268537 - 10/19/03 09:50 PM Re: The Vast 4k#Fe HO/T5 Swap Chronicle
AOD Offline
sounds good...keep us up to date.
#268538 - 10/21/03 01:08 PM Re: The Vast 4k#Fe HO/T5 Swap Chronicle
Fairmont_Kevin Offline
Loc: Sarasota, FL
I think once you have to bore the TB too big for stock, you could either have a new one made out of billet or find a way to adapt the CV throttle cable bracket to a Stang TB.
kevin
#268539 - 10/22/03 08:34 PM Re: The Vast 4k#Fe HO/T5 Swap Chronicle
Loc: Nashville, TN
Pics are now available of this stage.
Superford Web Page
I'll throw another batch up here when I have more news.
Here's a little style idea I had. Opinions? Of course, the engine plate will be refinished with the spray-paint-it-and-sand-off-the-tops-of-the-letters-and-then-clearcoat-it method. And you had no idea that was even a method.
4k#Fe
#268540 - 10/22/03 09:44 PM Re: The Vast 4k#Fe HO/T5 Swap Chronicle
1987LTDmasta Offline
Loc: Chicago, IL.
uh NO.. leave the engine plate undetr the hood where it belongs.. looks better there!
and BTW i already knew about that method.. i did it about 3 years ago to my vic?
she gone.
5.0 liter EFI High Output
Police Package suspension
Current:
'67 Mustang coupe
#268541 - 10/22/03 10:24 PM Re: The Vast 4k#Fe HO/T5 Swap Chronicle
SVT87 Offline
Loc: Orange County, CA
Ahh yes, tackling the great job that I never did. Good luck.
Matt
#268542 - 10/22/03 11:01 PM Re: The Vast 4k#Fe HO/T5 Swap Chronicle
Loc: Nashville, TN
I knew two years ago when you showed up here that you were just a flash in the pan. Never mind that you've done almost everything else before me, I still win. There is still a small but significant chance I might fail, but not before I go with an aftermarket roundy-round racer hydro clutch setup, hopefully mounted on the floor like an F1 racer/VW Beetle. That would be really wierd.
4k#Fe
PS Dammit Epi, reduce that picture in width so my thread stays pretty. This will probably go on for six months.
Edited by 4000_Pounds_of_Iron (10/22/03 11:02 PM)
#268543 - 10/23/03 12:46 AM Re: The Vast 4k#Fe HO/T5 Swap Chronicle
Please dont
That would ruin the sleeper look you car has now.
Sleeper that is, till you blast through the gears w/ that T5 leavin them em in the dust!
-starsky
#268544 - 10/23/03 01:38 AM Re: The Vast 4k#Fe HO/T5 Swap Chronicle
Loc: Nashville, TN
I really doubt I'm going to be all that fast. Even with a little timing bump, intake, and exhaust mods, I doubt I'll make much better than 235 HP. I'll be lucky for a 15-flat run in a 3800lb car with my 235lb ass in the seat. We'll see how she runs. At least I'll be able to waste most of you suckas. Maybe Seb will give me his doorstop I mean paperweight I mean 347. What I really want is a car as fast as my old '95 GT convertible, a high 14 sec car.
4k#Fe
#268545 - 10/23/03 02:15 AM Re: The Vast 4k#Fe HO/T5 Swap Chronicle
RedWagon630 Offline
Would be cool to have a National meet of all CVN Box cars, Roundies (92+) invited too.
Edited by RedWagon630 (10/23/03 02:16 AM)
#268546 - 10/23/03 02:47 AM Re: The Vast 4k#Fe HO/T5 Swap Chronicle
I really doubt I'm going to be all that fast:D What I really want is a car as fast as my old '95 GT convertible, a high 14 sec car.
4k#Fe
Then stroke it like a porn star, lol
-starsky
Moderator:  88grandmarq, Mperson, RF_Overlord
