#2686204 - 03/24/13 09:17 AM hello guys my first time posting!
zfxp99 Offline
Loc: florida
Well i have a 99 p71
She started to "misfire" so i replaced plugs and coils.
The problem started with a constant pulsing at cruising speeds wether is had been 30 or 70.
Once ive done this the issue has gotten much worse.
Replaced tc, no change. Tested fuel jnjectors all good. Coils all good.
Catalysts werr getting hot, had them removed no change.
It does this stumble constantly now, getting progressovely worse. MUCH WORSE GOING UP.HILL
Does anyone else agree fuel pump?
#2686210 - 03/24/13 09:23 AM Re: hello guys my first time posting! [Re: zfxp99]
Only way to know is test fuel pressure, otherwise you're just throwing parts at it... Have you read the codes???
Any drivabilaity problem should start with cleaning the MAF, simple, cheap and fixes probably 40-50% of the issues that are reported...
Now with P/S & PDB
#2686217 - 03/24/13 09:31 AM Re: hello guys my first time posting! [Re: zfxp99]
zfxp99 Offline
Loc: florida
Is there a guide showing how to do this?
#2686225 - 03/24/13 09:36 AM Re: hello guys my first time posting! [Re: zfxp99]
cragantler1 Offline
Loc: Fla. Cracker in South Conway
Search is your friend
https://www.crownvic.net/ubbthreads/ubbthreads.php?ubb=showflat&Number=1153795#Post1153795
BOK has a ton of tips for you.
Welcome from a Floridian in Maine
2004 Arizona Beige P-73, gone but never forgotten
2004 P-73,113k+
Performance & Handling:
P-71 H-pipe with Flowmaster 50s/Rear Meow delete/ADTR P&P plenum/70mm TB/Marauder swaybars/MZT/BOC tune/J-Mod/ 2006 P-71 rear coils/Gatorback belt/2005 17" Mustang GT Premium rims with Pirellis/ FRPP 3.55's / FRPP Trak-Lok
best time, pre-gear change: 15.4 @ 91.6mph
Appearance:
Honeycomb color matched grille/lower grille mesh mod/S-55 tail/reverse lights mod/bumper tuck/window chrome and wood dash delete/black reflective rear fascia/side marker mod/15% rear, 35% front tint/Marauder gauge cluster/1999 Lincoln Continental console and floor shift/Marauder gauge pod with "real" Autometer gauges/ Ford Focus driving lights with 5000K HID's wired to Marauder light switch for factory operation/repaired LCM/Marauder corner lights
#2686253 - 03/24/13 10:21 AM Re: hello guys my first time posting! [Re: zfxp99]
zfxp99 Offline
Loc: florida
I found this EXACT guide after i searched lol. ive done this already. Still stumbling n bumbling
#2686261 - 03/24/13 10:33 AM Re: hello guys my first time posting! [Re: zfxp99]
zfxp99 Offline
Loc: florida
If you disconnect your egr valve and no change in idle, thats a problem correct?
#2686262 - 03/24/13 10:35 AM Re: hello guys my first time posting! [Re: zfxp99]
I'd do a compression test on it to rule out a mechanical issue in the engine.
#2686269 - 03/24/13 10:45 AM Re: hello guys my first time posting! [Re: zfxp99]
zfxp99 Offline
Loc: florida
Ive done that already. I cleared.
Also im not throwing any misfire codes at all.
Im thinking i have a vacuum leak. But i always thought they only reared their ugly little hrwds up at idle...
Edited by zfxp99 (03/24/13 10:48 AM)
#2686276 - 03/24/13 10:52 AM Re: hello guys my first time posting! [Re: zfxp99]
Rolling-Thunder Offline
Loc: Albany, NY
Have you tried driving the car with the MAF sensor unplugged?
Just because it is clean, doesn't mean it isn't going bad.
I would do that before trying anything else.
2014 Escape, model S - white
2003 Crown Vic Sport - spruce green
MZT mod, 180 T-stat, NGK 4177 plugs, 21mm sway bar, fuel tank shield kit, Sil-blade low profile wipers
#2686277 - 03/24/13 10:54 AM Re: hello guys my first time posting! [Re: zfxp99]
zfxp99 Offline
Loc: florida
When its unplugged idle evens out, but when i give it a little gas, it stutters, is that supposed to happen? Lol
#2686299 - 03/24/13 11:59 AM Re: hello guys my first time posting! [Re: zfxp99]
stalag Offline
Loc: Columbus, OH
In short, yes. Unplugging the MAF turns off both the O2 sensors and the MAF sensor and sends the computer into a default limp mode. Chances are you either have either O2 sensors that need to be changed because they are "lazy" or a MAF sensor. O2 sensors need to be changed due to the fact they can become contaminated and the heat/cool cycles also have an impact on how they read. Replace the O2 sensors if you do not know how long they have been in place and in any case they should be replaced every 80K miles. Removal of catalytic convertors is not recommended as it is illegal. Clean the MAF sensor with MAF cleaner or electrical contact cleaner. Use of carburetor cleaner is not recommended because the solvent will cause other damage. If this does not improve the MAF sensor, replacement should be done. It is a definite misconception and belief around here that unplugging the MAF is diagnostic for a bad MAF. This is BS tech.
On a separate note put the information for your car in the signature so you don't have to retype it each time.
#2686304 - 03/24/13 12:11 PM Re: hello guys my first time posting! [Re: zfxp99]
zfxp99 Offline
Loc: florida
an o2 sensor would cause rough idle, and stuttering?
#2686326 - 03/24/13 12:33 PM Re: hello guys my first time posting! [Re: zfxp99]
stalag Offline
Loc: Columbus, OH
Yes it can! O2 sensors used to set fuel trims. Malfunctioning O2 sensors can also cause a catalytic convertor to run hot. You mentioned a hot catalytic convertor. That is diagnostic of a failing O2 sensor. Failing O2 sensors will cause the car to run rich and will dump fuel into the catalytic convertors causing them to overheat and fail.
#2686331 - 03/24/13 12:38 PM Re: hello guys my first time posting! [Re: stalag]
Loc: Albany, NY
Have to disagree with you there.
When the MAF sensor started going south on my T-Bird, I went to Autozone, purchased a new one, and installed it in the parking lot. The MAF sensor was defective, and the car died on the way home. I unplugged the MAF, and drove the rest of the way home just fine.
How is this not a diagnostic method for a bad MAF ?
One of the assumptions that can be made is that if the engine runs better with the MAF unplugged, in comparison to it plugged in, then the MAF sensor can be bad.
Edited by Rolling-Thunder (03/24/13 12:40 PM)
#2686334 - 03/24/13 12:42 PM Re: hello guys my first time posting! [Re: Rolling-Thunder]
stalag Offline
Loc: Columbus, OH
Because unplugging the MAF sensor turns off both the O2 sensors and the MAF sensor. It also changes the fuel tables to run rich. It backs off timing to be safer. These changes are not isolative for the MAF alone. Replacing a MAF that is bad is just happenstance. This info comes from discussions with both Lonnie at BOC and with Ford techs.
3 registered (Crown_Vic_6, Davidzq, crjackson), 46 Guests and 284 Spiders online.
bluejay_32 226
Old_Guy_Stu 120
a_d_a_m 99
DudeAbides 91
Ponyguy 72
CrystalPistol 45
Moby_Vic 44
Davidzq 43
ClayBelt 43
Bangster 37
