Page 2 of 2 < 1 2
#2686341 - 03/24/13 12:54 PM Re: hello guys my first time posting! [Re: zfxp99]
Rolling-Thunder Offline
Loc: Albany, NY
O2 sensors are usually fine for about 150,000 miles, at which point, they should be replaced, as I did with my CV Sport. If I was having these symptoms with my car, I would certainly think that the MAF sensor is more likely the culprit.
The original poster can also do some diagnostic tests of his own on the MAF sensor, providing he has a voltmeter.
2014 Escape, model S - white
2003 Crown Vic Sport - spruce green
MZT mod, 180 T-stat, NGK 4177 plugs, 21mm sway bar, fuel tank shield kit, Sil-blade low profile wipers
#2686354 - 03/24/13 01:14 PM Re: hello guys my first time posting! [Re: Rolling-Thunder]
zfxp99 Offline
Loc: florida
I do, in fact have one.
when I get off of work I will test it.
So the maf can cause stutter and other symptoms?
#2686505 - 03/24/13 06:13 PM Re: hello guys my first time posting! [Re: zfxp99]
sm41 Offline
Loc: Wilmington, NC
Yes, it most definitely will.
Also, which cats were removed? If only the backs have been cut, no issues should arise. If you removed the front pair though, that will throw a CEL.
Edited by sm41 (03/24/13 06:14 PM)
2001 Crown Vic, 125k miles. Intake, exhaust, tune, 3.73s. Mr. Viccles
'89 Mustang LX. 5.0, T5, GT40 build incoming. Marengo
'89 Jeep Cherokee. AX-15 5 speed swap, 3" lift, 30" mismatched tires. el Burro
'86 Mustang GT. Napoleon Blownapart. R.I.P. in pieces
-Steven
And I knew a boat wasn't a good idea for a standoff. I hope Wrinklypants realizes that now.
#2688191 - 03/27/13 06:09 PM Re: hello guys my first time posting! [Re: zfxp99]
zfxp99 Offline
Loc: florida
Well cleaned and tested maf, it tested well.
I'm smelling major fuel being dumped, and it's heating up the cats, on both sides..
There's only a few things that can do this correct?
Page 2 of 2 < 1 2
3 registered (bluejay_32, TheShadow, PatrickBateman), 64 Guests and 182 Spiders online.
bluejay_32 194
a_d_a_m 142
Old_Guy_Stu 125
DudeAbides 90
Ponyguy 64
Davidzq 47
Moby_Vic 45
LTC_Dave 39
ClayBelt 37
