#2690401 - 04/01/13 06:59 PM Continuation of issues..
zfxp99 Offline
Loc: florida
99 CVPI
170k miles
just replace plugs and coils
Well
I went to the junkyard and pulled a working MAF, the previos MAF idled at 1.0 and below to .8
I still get stutter and slow acceleration.
MY compression on all cylinders is great, not throwing any codes.
my car is running very rich, I know I'm dumping fuel, both of my floorboards are heating up... I'm out of ideas.
#2690404 - 04/01/13 07:04 PM Re: Continuation of issues.. [Re: zfxp99]
logan126 Offline
Loc: Jefferson, Ga
checked your O2 sensors?
'93 cvlx P74 240k+(not sure anymore. odo quit working a while back..)
dual exhaust
headlight relay upgrade
#2690405 - 04/01/13 07:06 PM Re: Continuation of issues.. [Re: logan126]
zfxp99 Offline
Loc: florida
I've unplugged them both and ran with the same exact stuttering..
I've searched for the usual vacuum suspects such as the intake manifold and nothing.
#2690412 - 04/01/13 07:20 PM Re: Continuation of issues.. [Re: zfxp99]
LSpann601 Offline
Loc: Jackson, Mississippi
Clogged cat convertors...if your cats are heating the floorboard nine times out of ten there clogged...
Have you checked to see if your fuel injectors are working properly a clogged one will also make your car stunter and not have power
Edited by LSpann601 (04/01/13 07:23 PM)
1997 Crown Victoria P71
2006 Crown Victoria P71 OLD MS Highway Patrol Car (Wrecked)
2003 Mercury Grand Marquis GS
2008 Crown Victoria Police Interceptor OLD NPS Park Ranger Car
1981 Chevy Monte Carlo 305ci/700r4
#2690428 - 04/01/13 08:13 PM Re: Continuation of issues.. [Re: zfxp99]
zfxp99 Offline
Loc: florida
they all seem to be ticking, would one side clogged affect all of it?
#2690439 - 04/01/13 08:51 PM Re: Continuation of issues.. [Re: zfxp99]
LSpann601 Offline
Have you looked under the car at the cats when the car reaches operating temp...are they red??? do you smell anything coming out the exhaust?
#2690442 - 04/01/13 09:03 PM Re: Continuation of issues.. [Re: zfxp99]
Soliferrum Offline
Loc: texas
what is this "ticking"? i believe i might have this same problem, it happens when i first start it up and move from a complete stop only when i apply throttle.
2004 P71...and rotting.
anyone in the texas golden triangle, sure would be helpful.
#2690459 - 04/01/13 09:31 PM Re: Continuation of issues.. [Re: zfxp99]
LSpann601 Offline
its normal for fuel injectors to tick tick tick...i normally get a rattle on first start up due to oil starvation...motocraft oil filter is suppose to help the problem
#2690541 - 04/02/13 04:07 AM Re: Continuation of issues.. [Re: zfxp99]
deezdrama Offline
Loc: central il
Sounds like clogged cats .... I just went through this
imgurl
<<<2007 Crown Vic P71>>>
175k
Precision Industries Stallion Torque Converter, New Ford Racing PI Intake, Polished plenum, Cat delete/duals/Thrush 2 chambers/3.5" tips, 18" Bullitt rims, 5% tint all around
<<<2010 White P71>>>
105k
15% tint, blacked door pillars, marauder corner lamps, HID projector headlights, 18" staggered Bullitts..... work in progress
#2692188 - 04/05/13 12:50 PM Re: Continuation of issues.. [Re: zfxp99]
zfxp99 Offline
Loc: florida
throwing code p0430
and the cats are not clogged... had them test frown
#2692243 - 04/05/13 02:19 PM Re: Continuation of issues.. [Re: zfxp99]
S13minus1 Offline
Loc: San Diego, CA, USA
p0430 is catalyst efficiency below threshold on bank 2... i recited that from memory. your cats have had their last meow, replace them.
-Alex
'96 Crown Victoria, base, 204k miles, my daily.
'87 Nissan 200SX, my toy
#2692263 - 04/05/13 02:49 PM Re: Continuation of issues.. [Re: zfxp99]
stalag Offline
Loc: Columbus, OH
Along with the prior poster, replace your o2 sensors with new units. Your o2 sensors work in conjunction with the MAF to set fuel trims. If the MAF is fine and the cats are running hot and are still working, your O2 sensors are shot. Bare minimum is to replace the O2 sensor. If you are replacing catalytic convertors, get some units from Magnaflow. Your old O2 sensors with the P0430 code are shot. They are causing your car to run pig rich and not taking care of this now will lead to catalytic convertor failure.
#2692381 - 04/05/13 08:07 PM Re: Continuation of issues.. [Re: zfxp99]
coolguy147 Offline
Loc: Florida
Haven't heard much of a rattle (tiny) on startup since I changed did my first oil change with the motorcraft filter. Motorcraft FTW
1998 Mercury Grand Marquis LS
-JMOD
12X,XXX
2006 Pontiac GTO 6sp 6.0l
6X,XXX
2 registered (MalMashn, Svtmedic), 42 Guests and 258 Spiders online.
bluejay_32 218
Old_Guy_Stu 119
a_d_a_m 111
DudeAbides 95
Ponyguy 71
Moby_Vic 43
Davidzq 42
ClayBelt 42
Bangster 37
