#2691284 - 04/03/13 07:55 PM
Re: What did you do to your panther today?
[Re: BigMerc96]
In his whale. With a supercharger, the stock whale tank is in the way, so most just get the one from an Aero which mounts on the passenger side fender apron and frees up the space in front of the engine. Bingo
2008 P71 - Vortech V2-SQ, 3.4" pulley, 2nd cats removed - Sold 2013 Silverado 2500 6.0 4X4 - Sold 2017 Challenger 392
#2691432 - 04/03/13 11:31 PM
[Re: Spartan]
EVILVIC
Loc: Orange County, California
Intercooled Kenne Bell 2.1L Supercharger, Accufab 75mm TB, 90mm MAF, 60LB Injectors, Comp XE278AH Cams & Valve Springs, 3600 Stall Circle D Converter, Stainless Works Long Tube Headers w/Cats & Stainless Works Catback w/ S-Tube Mufflers, 3.73 Gears, 31 Spline Tru-Trac, JMOD, B&M Deep Dish Trans Pan, B&M Trans Cooler, Moroso Deep Oil Pan, 160F Tstat, Electric Water Pump, Aeromotive A1000 Return Fuel, Addco Front & Rear Sway Bars, MEDC Rod Control Arms & MEDC Rod Watts Link w/ ARP Stud, Dual Adjustable Front & Rear Shocks w/ Adjustable Ride Height, Drilled & Slotted Front & Rear Rotors w/ New Calipers & Linelock, 110 Octane Dyno @ XXX RWHP & XXX RWTQ - BEST STOCK MOTOR 1/4 Mile 11.82 @ 113 MPH (1.62 60') EVIL VIC YOUTUBE CHANNEL - EVIL VIC FACEBOOK PAGE - POTM October 2012 & February 2015
#2691448 - 04/03/13 11:56 PM
[Re: dmcdfreak]
13 inches of pure joy
Loc: Lombard Il
Proud member of the 86400 Crew My new ride = Lacoste Observe CA in black and white. REAL leather. How bout dem apples? Thats way too much typing. AJ gets a pass because he only gets to do it once a day.
#2691679 - 04/04/13 01:33 PM
[Re: Spartan]
Those wheels looks great dmcdfreak!
Pantherless since September 2019 1972 Ford Galaxie 500 | soon to be 7.0L 1978 Ford Fairmont | soon to be 5.0L (Coyote) 1988 Ford Econoline E-350 | Quigley 4x4 | 7.5L 2017 Ford Fusion SE | 2.5L
#2691681 - 04/04/13 01:39 PM
[Re: Spartan]
EVILVIC
Thanks Guys! I am very happy with how they came out. Cant wait for the dyno now.
#2691807 - 04/04/13 05:58 PM
[Re: Spartan]
I finally put on the summer wheels
#2691815 - 04/04/13 06:42 PM
[Re: Spartan]
Loc: Statesboro Ga
Painted my reverse lights!
Just a kid with too many projects A small Ford car -The Daily '96 Chevy c1500 -The racetruck moneypit project That's it folks
#2691835 - 04/04/13 07:43 PM
[Re: BlackVic_P71]
Loc: Upstate, New York
I finally put on the summer wheels Dang! I'm jelly over your car now... Anyway, I'm now part of an exclusive group... The few, The proud, The manual panthers.
#2691917 - 04/04/13 10:18 PM
[Re: Black_Sunshine]
King of necro-threads
Loc: Madison, Wisconsin
What's the point of deadening your plate? IIRC he has a pretty significant sound system that would make the plate rattle going down the road. nothin big, just a couple 10's... but I hate rattle's and tracked one down to the plate. I also have small pieces of deadener between the plate and smoke cover, and added plate mounts to the bottom of the plate as well. no more rattle lol I have 2 12's and I had to do that to my EVILVIC plate when I got it too. I know the feeling my friend. I've found that simply gluing it on with silicone is just as effective and only takes a couple of seconds. That never occurred to me but it makes total sense, especially now thinking about the Cavaliers and Centurys I see outside school with the base all the way up. Those rattle all over, of course, but the license plate does make a unique noise.
2005 CVPI. 298 Bajillion miles.
#2691931 - 04/04/13 10:47 PM
[Re: Spartan]
Loc: Lombard Il
#2691940 - 04/04/13 11:06 PM
[Re: ajdereicup]
Loc: Statesboro Ga
Painted my reverse lights too   damn yours turned out sick man!
#2691943 - 04/04/13 11:10 PM
[Re: Spartan]
^Looks really good AJ!
I just got back from a late night parts run a couple hours ago. Fetched some grade 8 nuts for the new transmission mount, bought Pennzoil synchromesh transmission fluid, some aluminum tape, and some new exhaust flanges.
Had something weird happen to my dad and I while in the Lowes parking lot... We came out of the store with the grade 8 nuts, got in the car (my dads 03 p71), put the key in, turned the key, nothing. Tryed it again, nothing. Not even a click or crank, as if their was no electrical connection on the starter at all. My dad finally gave up and called my older sister so she could pick us up and while he was talking to her, I found a piece of cardboard to lay on and reached under the car. I felt the starter and the electrical connections, all looked good. I decided to try and start it one more time and what do you know, it starts up just fine. So after my car gets out of the garage we'll be putting his in to figure out why the starter failed...
#2691947 - 04/04/13 11:17 PM
[Re: Spartan]
Loc: Lombard Il
Thanks guys. Its not perfect cause my fingers are too thick to bend the vinyl tape in the corners really good but from a foot or 2 away its not noticeable. And it kinda pissed me off with the front plate clearing it it not coming out as good as it should've but I already used up part of the other decal to put the "R" back on because it fell off when I was washing in hence the clearing over it anyways. And I busted one of my reverse lights closing the trunk lid when I had the back off:P
ME do you think it may just be a bad spot in the starter? But it should still do something if it was I'd think. But when you touched the connections you may have jiggled a wire just right to get it all connected again. Make sure all the wires are tight on the starter and just trace the lines up as far as possible to make sure they're all good not melted or anything
#2691954 - 04/04/13 11:21 PM
[Re: MEvans043]
Loc: Orlando, FL
Had something weird happen to my dad and I while in the Lowes parking lot... We came out of the store with the grade 8 nuts, got in the car (my dads 03 p71), put the key in, turned the key, nothing. Tryed it again, nothing. Not even a click or crank, as if their was no electrical connection on the starter at all. My dad finally gave up and called my older sister so she could pick us up and while he was talking to her, I found a piece of cardboard to lay on and reached under the car. I felt the starter and the electrical connections, all looked good. I decided to try and start it one more time and what do you know, it starts up just fine. So after my car gets out of the garage we'll be putting his in to figure out why the starter failed... Clean the battery terminals. My SC400 used to do that a lot.
2000 CVPI SAP, 2005 Pontiac GTO. WARNING: This post may contain sarcasm. Poster discretion is advised. Today's forecast for CVN is bickering with a chance of sh!tstorm.
