#2695122 - 04/11/13 06:10 PM
Digital to Analog...I need advice
Loc: Illinois
So I picked up this analog gauge cluster from a junk yard and it's in pretty good condition and has all of the bulbs and wires in tact. I also took the plastic surround which houses it since the one in my Marquis currently is different. Now, how much of a pain in my a$$ will it be to do this swap? I have a 2001 Grand Marquis with the digidash, and considering that I scored this analog cluster for free, it seemed too good to pass up and I'm seriously considering the swap. I have a mild knowledge of electronics and circuitry. I can solder and splice and follow directions and stuff like that... Does anybody have any experience with this or any write-ups that could guide me through the process? Any help or advice would be greatly appreciated! Thanks! Here's a pic
Arizona Beige, 2001 Mercury Grand Marquis LS TR3650 5-SPEED SWAP P71 H-pipe, SLP loudmouth II mufflers, 3.5 inch Megs resonated exhaust tips 3.73 Gears with Mo's Speed Shop tune,Trac-loc Limited slip diff. from a P71 Color Matched rear fascia, Color Matched Grille surround with black slots 15% tint in the rear, 2.5 inch lowering springs in front, 2 inch in the rear 16" steelies with tall center caps (225/60/16) Currently 72,000 Miles on the Odometer!
#2695314 - 04/12/13 02:48 AM
Re: Digital to Analog...I need advice
[Re: jcataldo]
never say never
Loc: Minneapolis, MN
Maybe this is a stupid question, but why would you want to ditch the digi-dash?
#2695494 - 04/12/13 04:12 PM
[Re: jcataldo]
Loc: Illinois
Idk, I'm not 95 years old and I don't like all the buttons that I never use. I've always preferred a good old fashioned analog display
#2695771 - 04/13/13 11:11 AM
[Re: jcataldo]
Loc: Cincinnati, Ohio
Just like you have probably heard your whole life "Don't fix it if it ain't broke".
97 MGM 128K- The Hoopdy Mods: Headlight relay upgrade 2 15in Kickers w/ fogate amp 93 Lincoln Continental Executive Series (Sold) 07 Saab 9-3 Wagon 2.0t 6-speed manual- 110k - The gas saver
#2695803 - 04/13/13 12:55 PM
[Re: jcataldo]
Loc: Seattle, WA
others have swapped from analog to digital. its a whole different dash harness. means entire front dash needs to come out and then all wiring needs swapped over to an analog one. POTM winner Phillip in his merc did it. took him long time to find correct harness to go digital, but suspect finding analog would be easier. need only find a mercury with no digital . there are write ups in cvn of this swap. https://www.crownvic.net/ubbthreads/ubbthreads.php?ubb=showflat&Number=2499221this link has many other links to get started
 1998 Mercury Grand Marquis LS, HPP package FRPP PI Intake from ADTR, Ported Plenum from ADTR, Steeda Plenum Spacer from ADTR, MSD Coils BBK 70MM TB from ADTR, E3 Plugs, 2004 MZT, SCT X3 Tune from BOC, MAF Jumper from BOC, Optima Yellow Top Marauder Spoiler, Steeda Oil Separator W/custom bracket, Metco Control Arms & Watts Link Addco Rear Sway Bar w/ES Bushings, 3:73 Rear Gears with FRPP Trac Lok, Superior Rear Axles, Spruce Green Brake Calipers PowerSlot Slotted Discs, Hawk HPS pads, Extended Tailshaft with P71 DriveShaft, Rebuilt/Painted Rear Axle, Bilstien Shocks, Chrome FR500 18's, Nitto 555's - 255/45-18 F, 285/40-18 R "One doesnt simply drive the speed limit when listening to Heavy Metal"
#2695848 - 04/13/13 03:34 PM
[Re: P_Weston]
Loc: Illinois
I don't know about buttons I'm not using, cause I use the fuel mileage readouts all the time. I use all the extra indicators on the screen as well, and are very helpful to me personally. Well for me, I hate the gas mileage button because I don't like knowing what kind of terrible gas mileage i'm getting, and it's not the most accurate thing in the world. I always have it set to the "miles until empty" display which is the only thing I would really miss. I never use trip A or Trip B odometers and the "Average Speed" display is useless in my opinion. I don't mind the engine temp readout, but I hate the fuel readout since there are no dashes to show 3/4 tank, 1/2 tank or 1/4 tank which bothers me...it's either one dash above those values or one below. It annoys me a lot for some reason. And I could care less for the speedometer because if i'm ever accelerating quickly, it skips numbers cause it can't keep up, and I don't even have any performance mods yet! And also, the only time I ever change everything to metric is when i'm trying to fool my gullible friends into thinking i'm going faster than I really am...but other than that, I never use that button either. Anyway, sorry for the rant, but that's just my take on the digidash since everyone is always surprised at the fact that I prefer the analog. But in the end, I just hope I won't be kicking myself repeatedly when I do the swap because I don't realize how difficult this could actually be... Once again though, any wiring diagrams or tips on how to do this properly and efficiently would be greatly appreciated. Thanks!
#2695897 - 04/13/13 06:11 PM
[Re: jcataldo]
Loc: Minnesota
Analog all the way, I excluded any mgm with the digital dash form my search when I was looking to buy. My 06 does have the digital MPH but also has both the analog speedo and tach which I like. Good luck with the conversion.
My Rides: 2008 F350 CC SB Lariat 4x4 V10 2006 Mercury Grand Marquis LX stock for now. 2001 F150 SC XLT 5.4 plow truck 1998 Mark VIII transforming into street rod/bracket racer 1990 Mustang LX bracket racer 12.29 ET @ 107MPH
#2696006 - 04/13/13 11:03 PM
[Re: jcataldo]
Loc: Texas
If that speedo is from the same year car as yours, you should go back to the same junk yard and ask for the wiring harness from the same car they pulled the speedo from. then, wire that harness into your car.
'94 crown Vic now up to 40000 orig. miles stock. Replaced rusted fuel tank. Tight engine. Valve seals leaking. 2nd owner. Repainted once. New tires, brakes. Egr channel clean out done. New autolite platinum plugs. Dealer transmission flush and radiator flush.
#2696139 - 04/14/13 02:20 PM
[Re: eagleye]
Loc: Illinois
If that speedo is from the same year car as yours, you should go back to the same junk yard and ask for the wiring harness from the same car they pulled the speedo from. then, wire that harness into your car. The gauges are from an 04 I believe, and I have the all the connectors and stuff from it
