#2699017 - 04/21/13 06:37 AM PCV looking thing on left valve cover
JSO2003P71 Offline
Loc: Florida
On top of the left valve cover (drivers side)there is a black plastic thing that looks like a PCV valve that is not connected. It is drawing vacuum because when I put my finger over it,it makes a suction sound when I remove it.Where should this be connected at? If it goes to the plastic engine cover I am missing that part so what should I do with it? Also the check engine light comes on after the engine starts. Thanks
2003 cvpi,2008 cvpi,1994 honda accord,1976 camaro,1988 c1500,2001 honda accord,1999 honda accord,1994 suzuki rf900r,2012 Dodge charger,2001 mustang gt,2010 impala,2013 impala,2013 Taurus
#2699027 - 04/21/13 08:49 AM Re: PCV looking thing on left valve cover [Re: JSO2003P71]
torotoro Offline
Loc: NJ
what year is the car?
2002 LX Spruce Green/Tan Cloth ~120000 miles
Bilsteins, 17mm rear sway bar, BH1976 headlight relay harness, side marker/blinker mod
BC4E Dead Pedal, Upgraded Speakers, 35% Window Tint, De-chromed Exterior, Soundproofing.
#2699028 - 04/21/13 08:54 AM Re: PCV looking thing on left valve cover [Re: JSO2003P71]
If this fitting is toward the firewall, then it connects to the intake tract. There should also be a fitting or a hole in the intake tract and these two connect together. If that hose is missing, you have unmetered air going into the throttle body and that's the reason for your CEL.
#2699031 - 04/21/13 09:12 AM Re: PCV looking thing on left valve cover [Re: RF_Overlord]
BigNSlow Offline
Aussie powered
Loc:
Originally Posted By Ezbok58a
He runs a fake equipment install company just so he could run his vehicles with lights on them, and his hobbies include running motorcycles off the road, terrorizing civilians in Walmart parking lots, handing out pamphlets on Open Carry, backing into parked cars and then blaming it on the parked car, securing perimeters, getting into conflicts that no rational person gets into, and helping stranded motorists...
I'm sure I'm missing some but that's techno as we know him...
#2699048 - 04/21/13 10:14 AM Re: PCV looking thing on left valve cover [Re: JSO2003P71]
JSO2003P71 Offline
Loc: Florida
Sorry, Its a 2003. Here is a picture of it.
#2699052 - 04/21/13 10:29 AM Re: PCV looking thing on left valve cover [Re: JSO2003P71]
there should be a hose from there to the port on the intake tube that is next to the hose that goes to the IAC (the one that is connected still). if its disconnected/missing then not only do you have a vacuum leak, then you are getting unmetered/unfiltered air in thru the hole in the zip tube.
#2699053 - 04/21/13 10:29 AM Re: PCV looking thing on left valve cover [Re: JSO2003P71]
There's a tube that connects that valve cover to the second hole on the backside of the air intake tube.
Pantherless since September 2019
1978 Ford Fairmont | soon to be 5.0L (Coyote)
2017 Ford Fusion SE | 2.5L
#2699064 - 04/21/13 11:26 AM Re: PCV looking thing on left valve cover [Re: JSO2003P71]
Superhobo Offline
Loc: Kansas City
That connects to the intake tube like mentioned above. That's the intake side of the PCV. The return is on the passenger side and connects to the plenum.
2000 P71. -PI intake, BBK 78mm throttle intake, 80mm MAF, Granatelli COPs, Autolite plugs, Ford 30# injectors, MMR fuel rails, Ford GT cam followers, K&N filter, UD pulleys, Stewart WP, Comp XE262H cams, Trick Flow cam spacers, Stainless Works long tubes w/catted lead pipes, 2.5" cat-back w/MagnaFlow x-pipe & Jones Full Boar mufflers, Heinous CAs, Metco Watts-Link, Energy Suspension bushings & end links, 4:10/Trac-lok w/carbon fiber clutches, Setina rear window barriers, Taxi Depot front bumper guard, Sony head unit, Pioneer speakers, tuned w/Sniper.
#2699088 - 04/21/13 01:56 PM Re: PCV looking thing on left valve cover [Re: JSO2003P71]
JSO2003P71 Offline
Loc: Florida
OK, I went out and looked and I see where it goes now. Right next to the other tube. There are several parts I need for this car. Is there a swap meet section on this site? Is this tube only on the police interceptor engine?
#2699091 - 04/21/13 02:00 PM Re: PCV looking thing on left valve cover [Re: JSO2003P71]
nope, its on all Panthers. There is no difference between the police interceptor engine and a regular CV/GMQ/TC engine. Power difference comes from a more aggressive tune and dual exhausts.
Like posted above, that tube supplies air into the block and the PCV valve on the other valve cover sucks it back out creating a closed circulation for crank case pressures.
#2699210 - 04/21/13 06:39 PM Re: PCV looking thing on left valve cover [Re: JSO2003P71]
JSO2003P71 Offline
Loc: Florida
OK, Thanks everyone for the info. Sounds like we don't want to be driving without the tube. I'll have to get one soon.
#2699693 - 04/22/13 06:13 PM Re: PCV looking thing on left valve cover [Re: JSO2003P71]
Pnasty Offline
Loc: Warren, Ohio
This is what it should look like
Edited by Pnasty (04/22/13 06:19 PM)
Edit Reason: picture add
"Stranger Things Have Happened"
#2699698 - 04/22/13 06:16 PM Re: PCV looking thing on left valve cover [Re: JSO2003P71]
Pnasty Offline
Loc: Warren, Ohio
Hmmm there should've been a picture there^^^^
#2699885 - 04/23/13 06:08 AM Re: PCV looking thing on left valve cover [Re: JSO2003P71]
JSO2003P71 Offline
Loc: Florida
Is it metal where it plugs into the air intake?
#2699932 - 04/23/13 10:07 AM Re: PCV looking thing on left valve cover [Re: JSO2003P71]
it is plastic where it goes into the intake.
4 registered (magic, CrownBen, 2 invisible), 82 Guests and 300 Spiders online.
bluejay_32 165
Old_Guy_Stu 98
a_d_a_m 94
Moby_Vic 55
CrystalPistol 50
TheCableGuy 47
RF_Overlord 44
Ponyguy 39
