#2709858 - 05/16/13 11:48 AM Code question
MGM24 Offline
Loc: ATL,Shaw AFB,SC
I have the following codes what does this point to?
P1131 Lack Of HO2S1 Switches, Lean (Bank 1, Sensor 1)
P0420 catalyst efficiency below thresh hold on bank 1 and 2
P0430 cat efficiency below limit bank 2
P0133: Circuit Slow Response (Bank1, Sensor1)
#2709899 - 05/16/13 02:14 PM Re: Code question [Re: MGM24]
Rick35 Offline
Loc: Naperville, Illinois
Sounds like your oxygen (02) sensors are bad, try to replace them, and then see if it helps. (make sure you erase the codes after replacing them).
If any code, especially P0420, shows up, then it is time to replace the catalytic converters.
2004 Crown Victoria LX Spruce Green 111k mileage
#2710117 - 05/16/13 10:28 PM Re: Code question [Re: MGM24]
idontbelieveit Offline
Loc: Over there
The 1131 and 0133 codes both point to the same fault and it's what's called a lazy O2 sensor. The sensors become contaminated and it's having trouble sniffing out the oxygen content in your exhaust. It's going to be the front O2 sensor on the passenger side catalytic converter. When you pull the O2 sensor, observe its condition and look for contamination, coloration that matches the color of your coolant, oil soaking, anything greater than some mild carbon soot. That can be an indicator that you've got bigger problems. I've seen O2 sensors repaired by soaking them in Simple Green engine degreaser. That's assuming it's just a little carbon buildup is in the sensor. The 0420 and 0430 codes most times indicate the catalytic converter is junk. You'd want to try and look at live data if possible to compare the O2 sensors on both ends of each cat. Otherwise, you could also shoot the front and the back ends of the catalytic converter with an infrared thermometer. If the temperature is colder at the back end, it means that the cat isn't heating up to burn off the excess hydrocarbons and whatnot. Leaky exhaust in front of the cats could be letting excess oxygen into the stream and throwing the codes too.
#2710121 - 05/16/13 10:39 PM Re: Code question [Re: MGM24]
theperfectdrugsk Offline
Loc: Raleigh, NC
If the simple green doesn't work, hit it with some b12 chemtool...its supposedly safe for O2 sensors.
not old...just cranky
#2710568 - 05/17/13 10:24 PM Re: Code question [Re: MGM24]
MGM24 Offline
Thanks for the replies it sounds like I have some work to do
4 registered (DudeAbides, my2008P71, 2 invisible), 49 Guests and 218 Spiders online.
CrystalPistol 206
bluejay_32 172
Ponyguy 59
JeffBoudah 59
Moby_Vic 57
Dmblanch 54
Bangster 40
DudeAbides 39
