#2710316 - 05/17/13 11:45 AM Emergency coolant question!
Benwah Offline
Loc: Phoenix, Arizona
Hey guys, on the way to work this morning my 08 P71's water pump took a [censored]. I know this because the pulley is seized and coolant was shooting out of that little hole on the top of the water pump.
I am having someone bring me tools and I am going to buy a new pump. QUESTION is, I will have to refill the coolant, I cannot do a flush as my car is on the side of a fairly busy road. The coolant in it is green and that's what came with it when I purchased that car..
Is there a specific type I should be getting from AutoZone / O'reilley? Or should I just use whatever I can until I can do a proper flush this weekend? Thanks for the help! I will be replacing the pump here shortly
2008 Crown Victoria P71.
It's a cop car.
#2710317 - 05/17/13 11:50 AM Re: Emergency coolant question! [Re: Benwah]
I'd just put distilled water in to replace whatever coolant you lost. You can get it at a grocery store for pretty cheap. Distilled water is the best coolant you can use, and it will mix with anything.
Originally Posted By: etcv97
#2710352 - 05/17/13 01:53 PM Re: Emergency coolant question! [Re: BillyBishop]
Benwah Offline
Water pump - $52
Coolant + DI water (lost a lot) - $40
Crowbar - $30
Knowing my car will not overheat in the Arizona heat - PRICELESS!
It's a cop car.
#2710366 - 05/17/13 02:45 PM Re: Emergency coolant question! [Re: Benwah]
stalag Offline
Loc: Columbus, OH
Distilled water in a pinch is perfectly acceptable. Do the flush when you get the time. Plus I think in Arizona the temps are high enough that freezing is not an issue.
#2710429 - 05/17/13 05:07 PM Re: Emergency coolant question! [Re: Benwah]
I know the OP is asking about an emergency situation, but just so someone new doesn't mis-interpret the answers above:
Don't run water-only, even in Arizona. In addition to its anti-freezing properties, coolant also contains lubricants and anti-corrosion additives to protect the entire system. In really hot climates, it's acceptable to lower the concentrataion to 30/70, but I wouldn't go any lower.
Edited by RF_Overlord (05/17/13 09:50 PM)
#2710489 - 05/17/13 06:50 PM Re: Emergency coolant question! [Re: RF_Overlord]
Benwah Offline
Thanks for the clarification! I didn't know we could do that here.
It's a cop car.
#2710563 - 05/17/13 10:13 PM Re: Emergency coolant question! [Re: Benwah]
Robert_Allen Offline
Loc: Tuna, Texas
Originally Posted By: Benwah
Water pump - $52
Crowbar - $30
You had to resort to a crowbar too, eh? Mod motor water pumps can be a major PITA to remove. Mine involved a huge screwdriver and a BFH!
1978 Grand Marquis
1996 Ford Thunderbird
2001 Jaguar S-Type
#2710573 - 05/17/13 10:49 PM Re: Emergency coolant question! [Re: Benwah]
stalag Offline
Loc: Columbus, OH
$40 for distilled/deionized water? You got ripped.
should have been at most $4-5 bucks.
I agree with RF about not running water long term. Use of distilled water only is to get you to a place where you can do the flush safely. Use of water with no anticorrosives in place will lead to engine damage. You only have a day or two if running on distilled water only until you flush. Follow my sig for the link in flushing coolants.
#2710673 - 05/18/13 08:55 AM Re: Emergency coolant question! [Re: Benwah]
coolguy147 Offline
Loc: Florida
For emergency purposes...distilled water is fine...
I pay less than a dollar for a gallon.
1998 Mercury Grand Marquis LS
-JMOD
12X,XXX
2006 Pontiac GTO 6sp 6.0l
6X,XXX
6 registered (Fomocop71, TheShadow, Davidzq, 01boatman, Dmblanch, 1 invisible), 68 Guests and 138 Spiders online.
JeffBoudah 81
Armada Master 74
Old_Guy_Stu 72
Moby_Vic 65
Dmblanch 57
a_d_a_m 44
SocalSam 43
Ponyguy 42
