#2729254 - 07/02/13 07:00 AM
Re: Rear Air Suspension problem
[Re: scooter]
Loc: Bucks County, PA
$500 for the compressor and they want to start there? UMMMMMM..... RUN!!!! Run Far!!!!!
The think that concerns me is that is works without any issues for 3 weeks, then has issues. If it were a leak, then it would not work at all.
I am thinking the vent solenoids myself, they are cheap, and also have new O-rings. I doubt it is the compressor vent, but could be wrong.
And as mentioned before, you can get new bags, solenoids and a compressor for around $350 and then have your mechanic put them in, or do it yourself.
1996 Mercury Grand Marquis LS w/HPP Protected by HALON, the real stuff!!
2012 Ford Fusion Sport AWD, Yep it has Halon too!
#2729387 - 07/02/13 03:12 PM
[Re: scooter]
There are actually 2 valves in the RAS. One is the solenoid at the air spring itself, the other is on the compressor. When the system is told to vent, it has to open both the air spring solenoid and the vent solenoid on the compressor. This produces that "sighing ghost" sound people sometimes hear after the car is shut off. If the solenoid on the compressor is bad, it's possible it's stuck in the vent mode, so no air comes out the feed to the back of the car when the compressor is running.
#2729480 - 07/02/13 07:10 PM
[Re: scooter]
Loc: Stockton, CA
I hope you're good to go. It's possible that a leak was causing your air compressor to work overtime and then it finally failed. However not likely since your problem was intermittent. If you had a leaky airbag the problem would still exist.
When my RAS went out it was one of the airbags so I just went with P71 coils so that I wouldn't have to worry about it anymore. I didn't bother changing the shocks and I actually liked the way it felt with coil springs.
It feels more agile and seems to have a little more 'jump' off the line with the coils.
2002 Marquis LS Precision Trac, new engine @ 125K, GT Wheels, HP tires, SCT Xcal 2, 91 Octane tune from BOC, Traction Locker w/Ford Racing clutches, 3.55's, Police D/S, Ford Racing IM @114K, 75mm TB, Trick Flow Plenum, Ziptube, GT MAF, P71 Rear Coils, Summit Racing UDP's, HPP Sway Bar, Gas KYB's, J-Mod, 2-1/4" Dual Exhaust, Thrush Glasspacks & 18" tips, MSD COPs, NGK TR55's & Grey Injectors, Pinstripe removed, Disc changer, 2400 watt Pioneeer amp & 6x9's, Kicker Comp VR 10" DVC subwoofers.
#2729505 - 07/02/13 07:40 PM
[Re: scooter]
The new compressor did not have the connector for the rubber hose that was on the old one that went to this little black box mounted on the front frame (snorkel I think). Is this OK? That "snorkel" is actually a muffler for the vent. It's not necessary.
#2729705 - 07/03/13 04:50 AM
[Re: scooter]
Hopefully that is all that it was. It sounds that way since it went right up and no warning lights.
If something goes again, it will most likey be the bags.
After 4 repairs on mine, I switched over to coils and will not look back, I do agree with BigROC 209, I replaced mine with new coils and shocks and it seems to hook up better then it ever did off the line.
It my GM was still my daily driver, I would have repaired the RAS, but for $100 for new coils and rear shocks..... A few hours in my driveway was well worth the peace of mind never to worry about the RAS again.
Glad you car is fixed.
#2732898 - 07/11/13 11:44 AM
[Re: scooter]
The dryer is part of the compressor, if you just bought a new compressor it should have a new drier. If not then it can't hurt to buy a new drier, they are not too expensive. The drier has a desiccant inside that removes moisture from the air before it gets into the system: http://en.wikipedia.org/wiki/DesiccantIf the air springs are not leaking then there is no need to replace them. If they are old or show signs of cracks or are leaking then I would say go ahead and replace them. Tell tail signs of a leaking spring is the car drops to the ground after sitting all night or while driving the compressor run though no weight has been added. One thing to check, though, is the height sensor. They tend to rust and eventually come off causing the car to think the height is low and calls for the compressor to inflate the springs, thus you get this really high rearend. I would put a few squirts of WD-40 on the two attaching points. The height sensor is on the Watts linkage forward of the fuel tank.
2004 Ford Crown Victoria LX Sport - 1 of 2656 - Midnight Gray w/Dark Charcoal Mods: 21mm rear sway bar, Marauder head unit, Marauder sub/amp, Ford "premium" two-way door and deck speakers, Curless cure, Ford Focus fog lamps with Marauder head light switch, trunk organizer, short over head console with Homelink.
2017 Explorer Police Interceptor
#2733118 - 07/11/13 09:36 PM
[Re: scooter]
I do not totally understand how the dryer works or how moisture gets into to system and how it is removed. Warm air can hold more moisture than cool air. When you compress air you add heat, and it will hold even more. The RAS compressor takes in outside air, compresses it, and pumps it to the air springs through the dryer, which is filled with dessicant which absorbs moisture. Moisture in the system can cause corrosion and will turn to ice in the winter, blocking the air lines.
#2734354 - 07/14/13 10:00 PM
[Re: RF_Overlord]
Loc: Rochester NY
Just replacing my air system in the 2006. Scored a complete kit from Strutmasters for $367.00. Bags, solenoids, O rings,, dryer and compressor.
I wasted that much on a compressor at 70k miles.
Lasted only 40k miles.
The bags dry rot over time. Also, no one ever replaces their rear shocks on these cars, which really should be done at 50-60k. This also leads to early failures.
I switched up my 2000 to regular coils, but for that kind of price I am keeping the air ride.
While I am at it we are doing the steering shafts and endlink bushings.
I did the struts last December. So the car should be good for another 100k!
Edited by Big_Bad_Joe (07/14/13 10:03 PM)
2006 LX with HPPBlue, Light Camel Interior,Magnaflow Exhaust,PI Zip Tube Underdrives from ADTR.net Pioneer AVIC X930BT Nav system, JL xD400/4amp, JL Speakers, Audiovox backup camera Given to DG in Ohio
#2734682 - 07/15/13 06:10 PM
[Re: scooter]
Loc: Mississippi
A lot of very good info. I purchased my CV 98 LX almost 2 Yrs ago and air suspension had been converted to coils and new monroe shocks. I think Dealer did it as one time previous owner had all work done there. I have been very happy with ride and road control on mine. Also I dont have to worry about maintaining my air system.
But in end its a personal choice as someone stated.
Its only my opinion and worthless cept to me!  1998 Crown Vic Lx. 103,000 miles, Dual Exhaust W/ H-Pipe, Magnaflow's and 2nd Cat Delete, FRPP PI Intake, P&P Plenum, Summit 70mm TB, MTZ, BOC 93 OCT Tune, 180 stat, 22c Plugs, ADTR High Flow intake tube, Autometer Z-Series Tach in Column Mount, 2" Hitch Receiver, Previous Owner Replaced Air Suspension with Coils. BH1976 Headlight Harness, Black P71 Honeycomb Grille. (On but not shown)
