#27438 - 11/09/02 03:23 PM Octane & Spark Out plugs, drains my battery
Anonymous
Unregistered
When I put the octane plug on, (95 Crown Victoria Police) it drains my battery dead! I already kill one down to 7 volts over night. I done tests with a light bulb to negative terminal on my battery, when the octane plug is out (default) it's ok, when I put it on, it drains my battery! What's up with that? Is it supposed to be doing that?
Another question is about the spark out plug. When removed, ECC has no longer control over timing. What is better, when ECC controls the timing, or when your ignition relies on PIP sensor for that? What gives better control and more power?
#27439 - 11/09/02 03:24 PM Re: Octane & Spark Out plugs, drains my battery
Anonymous
Unregistered
(spark out plug doesn't drains the battery, only the octane plug does, when you put it on to advance 3 degrees)
#27440 - 11/09/02 03:27 PM Re: Octane & Spark Out plugs, drains my battery
JohnG Offline
Tech Admin
Loc: Socialist state of MN
Physically impossible unless there is a dead short in the harness.
Your car does not have a PIP.
#27441 - 11/09/02 07:22 PM Re: Octane & Spark Out plugs, drains my battery
Anonymous
Unregistered
According to my wiring diagram of EDIS. There is a PIP signal going from EEC-IV to EDIS module.
Still question stands, do I gain anything by removing SPOUT plug?
How do I troubleshoot the octane plug? Anyone have octane plug set to advance 3 degrees, does it works?
#27442 - 11/09/02 07:42 PM Re: Octane & Spark Out plugs, drains my battery
JohnG Offline
Tech Admin
You said, and I quote "PIP sensor", in your first post. On the signal, you are correct.
The "spout" is only a "jumper", either open or closed....a switch if you will, no variability at all.
Get a wiring diagram and follow it back to the EEC/EDIS.
#27443 - 11/09/02 10:44 PM Re: Octane & Spark Out plugs, drains my battery
Anonymous
Unregistered
I apologize for any inconsistency in my first post. I am not familiar with this type of ignition. I will get the wiring diagram. Thank you for your help.
#27444 - 11/10/02 12:49 AM Re: Octane & Spark Out plugs, drains my battery
Mr_pogo Offline
A Spout (Spark Output) plug sets engine to base timing when pulled, only used for checking the ignition timing. Leave it in.
My WAG would be possibly bad ecm or ecm ground. But as mentioned check your wiring diagrams. Would also check for fault codes.
4 registered (WSTRLNG, billross, Drac, MalMashn), 38 Guests and 260 Spiders online.
bluejay_32 218
Old_Guy_Stu 119
a_d_a_m 111
DudeAbides 95
Ponyguy 71
Moby_Vic 43
Davidzq 42
ClayBelt 42
Bangster 37
