Page 2 of 2 < 1 2
#2753160 - 09/03/13 12:27 AM Re: The Vic overheated a bit tonight, any thoughts? [Re: mkfanatic]
mkfanatic Offline
Loc: Hamilton, OH
It looks easy. There looks to be plenty of room to remove it since it has the electric fans instead of the mechanical fan. Will I still need to remove the fans and the shroud? I'm thinking I'm gonna have to remove the alternator too. Am I correct?
1993 Crown Victoria P74 (wrecked)
1995 Crown Victoria P72 (sold to junkyard)
Mods: P71 Computer
2003 Crown Victoria P74 Sport
Mods: MM MAF + Airbox and K&N Air Filter, 04 Zip Tube, 3.73 gears with trac-lok LSD, AMMC Driveshaft, Tailshaft w/ Forced Lube Mod, and 93 Tune from Lonnie @ BOC
#2753173 - 09/03/13 01:28 AM Re: The Vic overheated a bit tonight, any thoughts? [Re: mkfanatic]
idontbelieveit Offline
Loc: Over there
It's been too long. I'd say yes on the alternator just because it opens up space to ensure those clean gasket surfaces. You can probably leave the fan & shroud alone.
#2753204 - 09/03/13 08:04 AM Re: The Vic overheated a bit tonight, any thoughts? [Re: mkfanatic]
mkfanatic Offline
Loc: Hamilton, OH
What is the torque specifications for the water pump bolts?
Mods: P71 Computer
#2753208 - 09/03/13 08:07 AM Re: The Vic overheated a bit tonight, any thoughts? [Re: mkfanatic]
the alternator is a whopping 4 bolts, so just remove it if it'll make life easier. My car had a mechanical fan which would have made life difficult, but with my not-stock electric fans I'd have a ton of room. Water pump ought to be pretty easy, just a couple bolts, but I haven't actually had to do one on a Panther. If its like every other car, the hardest part will be separating the aluminum pump from the iron block as the 2 dissimilar metals have likely become quite friendly in the presence of water.
#2753254 - 09/03/13 10:35 AM Re: The Vic overheated a bit tonight, any thoughts? [Re: mkfanatic]
Robert_Allen Offline
Loc: Tuna, Texas
The last (and only) time I replaced a water pump on a 4.6L it was a royal PITA. The pump had fused itself to the block and it wouldn't budge. I had to phone a friend, and he resorted to one of those pry bars big enough to relocate small planets, and a rather substantial BFH.
1978 Grand Marquis
1996 Ford Thunderbird
2001 Jaguar S-Type
#2753342 - 09/03/13 03:17 PM Re: The Vic overheated a bit tonight, any thoughts? [Re: mkfanatic]
Originally Posted By: mkfanatic
Turns out my water pump took a crap. The pulley started wobbling then dropped on the crankshaft pulley.
So the waterpump shaft broke, the pulley fell off, and the belt would have gone all slack and come off the other pulleys, and you didn't notice all that?
#2753409 - 09/03/13 06:53 PM Re: The Vic overheated a bit tonight, any thoughts? [Re: mkfanatic]
mkfanatic Offline
Loc: Hamilton, OH
The pulley didn't fall off. I guess the bearings in the water pump were going bad so it was wobbling a little bit. I was showing a friend what it was doing. I only had the car on for a couple seconds and apparently the whole thing dropped just a little bit but it landed on the crankshaft pulley below it. It's barely on it tho but of course I shut it off immediately and haven't started it up since. My sister drives my car a lot and she knows nothing about cars so she didn't notice it.
Mods: P71 Computer
#2753574 - 09/04/13 07:55 AM Re: The Vic overheated a bit tonight, any thoughts? [Re: mkfanatic]
mkfanatic Offline
Loc: Hamilton, OH
Okay, so can somebody tell me the torque specs? Also, can I do a real flush without being able to turn my car on?
Mods: P71 Computer
#2753646 - 09/04/13 12:59 PM Re: The Vic overheated a bit tonight, any thoughts? [Re: mkfanatic]
Chrono Offline
Loc: U.S.
Mitchell is showing 18lb/ft for the water pump and water pump pulley bolts. Also, it's saying to make sure your mounting surface is clean and to lubricate the new o-ring with coolant. Once you install the new pump, do not twist it too much or you can damage the seal. Hope this helps.
#2753714 - 09/04/13 03:06 PM Re: The Vic overheated a bit tonight, any thoughts? [Re: Chrono]
GoldPanther Offline
BOK contributor
Loc: Chitcagoland!
Of course!!! Mitchell ondemand its probably the best tool a mechanic can have!!!
Former 03 mgm ultimate edition owner, currently pantherless.
#2753736 - 09/04/13 03:57 PM Re: The Vic overheated a bit tonight, any thoughts? [Re: SteveS]
ChrisM_NY Offline
Loc: Saratoga, New York
Originally Posted By: SteveS
Originally Posted By: bigROC209
You could try a 180 degree t-stat.
BS Tech.
Changing to a lower temperature thermostat WILL NOT solve an overheating problem.
with the regular thermostat will not keep the car at normal what makes you think a 180tstat will do any better?
2007 CVPI SAP 115K/800hrs
#2753738 - 09/04/13 04:00 PM Re: The Vic overheated a bit tonight, any thoughts? [Re: mkfanatic]
stalag Offline
Loc: Columbus, OH
Probably not on the flush. Check the link in my sig for info on proper flush conditions.
#2754173 - 09/05/13 03:36 PM Re: The Vic overheated a bit tonight, any thoughts? [Re: mkfanatic]
PHoganDive Offline
Loc: Mass, USA
#2754321 - 09/05/13 08:36 PM Re: The Vic overheated a bit tonight, any thoughts? [Re: mkfanatic]
Rainyp71 Offline
Loc: North Carolina, USA
Yes, the pump is really easy. Did mine a little while ago, took all of an hour. Make sure you loosely tighten the screws first with your hand, then torque them down to make sure everything is lined up properly.
2000 P71 Crown Vic former Gordonsville, VA Police Wrecked @ 200,199 Miles - All fixed! Currently 250,000 Miles
GMAX As-05 tires, 3.55 gears, Ford 28 spline limited slip w/ carbon clutches, upgraded trans cooler, Airlift 1000 bags, custom trunk false floor, autometer tach, Sony Double DIN Head Unit, KYBs all around, 26in Cherrybombs 2.25" dual exhuast.
Page 2 of 2 < 1 2
