#1790381 - 06/14/09 11:07 AM
Starter Removal "Trick"
Loc: Southeast michigan
I dropped an 01 off at a local repair shop for a starter replacement. At the time I had more money than time. Bill came out to $71.10 for labor. Anyways, when I asked for the old starter back, the mechanic was kind of reluctant. To make a long story short he brought it back in pieces. His "Trick" is to break the silenoid off with a hammer. This shatters the nose cone off dislodging the silenoid. The nose cone is made of some sort of alloy and breaks easily when hit. Once the silenoid is off, the top 2 bolts are much easier to access and remove.
Edited by Michigansquadcar (06/14/09 11:08 AM)
#1790407 - 06/14/09 11:31 AM
Re: Starter Removal "Trick"
[Re: Rizzo]
Loc: LI,NY
That's How I did mine on a 99. My 03 was much easier but i still broke the solenoid off.
2007 Black P71 2003 Green p74 1991 Crown Victoria 1999 Green SAP-Part Car
#1790454 - 06/14/09 12:59 PM
[Re: larryo340]
professional grade
Loc: BUF
I didn't have that option when I pulled the motor recently since the starter was still good.  Still wasn't bad using the wobble extension method from the front, though. However, I will keep this in mind if the starter ever goes bad.
#1790481 - 06/14/09 01:45 PM
[Re: mrbear5300]
my 2-bolt starter was dead last year at work, i didnt know what is the problem but a miracle happened that the car started then after knocking on it using a hammer!!
i bought a used solinoid and motor brushes from the junk, dis-assembled the starter completly and washing it using gas, greasing the gears and re-installing..it is like new right now.
i will try to "kill" the old solinoid lol
http://www.supermotors.net/users/vic1992LX 1992 crownvic LX P74 (ex US DOD unit) SOLD 2009 1998 crownvic P73 (came from canada) SOLD 2014 1990 oldsmobile cutlass cierra 3.1L FE3 WORK VEHICLE 2007 toyota yaris 1.3L wife vehicle SOLD 2011 ford edge limited 3.5L AWD flooded (lifetime project) 2012 Ford Focus 2.0L. Exciting transmission technology.
#1790483 - 06/14/09 01:46 PM
[Re: 98P73_IRAQ]
Loc: Saskatoon, Saskatchewan
#1790512 - 06/14/09 02:53 PM
[Re: gord_bolton]
That would be the ideal way. The problem is the cat converter is in the way of these screws. With proper access, these screws are VERY hard to remove due to rust/corrosion. In order to replace silenoids in the past, I would use an impact screwdriver on them after the starter assembly was removed from the car.
#2763110 - 10/01/13 03:48 PM
[Re: Michigansquadcar]
Loc: brookings SD
2006 light metallic blue cvpi 113000 miles 3.27 gears trac lock 2000 white cvpi 109xxx miles, 2005 cvpi engine swap done!! 94 cvpi R.I.P.
#2763112 - 10/01/13 03:49 PM
[Re: tigman5356]
Loc: brookings SD
i got this wrench hot with the wirefeed. I still have to tackle the 3rd bolt up high yet
#2763478 - 10/02/13 12:13 PM
[Re: tigman5356]
Loc: Northumberland, PA
big fan of this.....I've bent a few wrenches into shapes that I needed in order to get at stubborn bolts. most notably a bent and shaved 9/16 to get at the distributor hold down nut on my old caprice 307ci. you can always buy more wrenches but those bent ones tell a story all their own :-)
2003 CVLX; 312k mi (perch 103k); P74; Black Paint/Black leather; Blinking side marker mod; 2.73 open dif; Autolite Dbl Plat; General Altimax RT43; LCM Ext relay, FRPP mani; Max-Life 5w-30 03 Crown Victoria LX by Wags4000, on Flickr 2001 Merc GM LS; RIP at 340k mi (bought at 67k)-my former commuter. Finally passed on due to no one driving it and things just stopped working. 1986 Merc GM LS; 165k mi (bought at 118k)- Red with White vinyl half roof; 5.0L; RIP 87 Caprice Wagon; 356k; 5.0L(307cu) RIP
3 registered (Rainbowpizza, LTC_Dave, 1 invisible),
42
181
