#2770433 - 10/25/13 06:24 PM 255/50R17 on stock 17 " interceptor steel wheels ?
WSMP71 Offline
Loc: Pa
Just got a set of 17" steel interceptor wheel this afternoon and now I'm looking to buy some tires. I read on the forum that I could run 255/50R17 on all four corners with these rims with no rubbing or clearance issues ? Anybody running this set up and your likes or dislikes ?
Thanks again,
Bill Miller
09 CVPI(Sold)
05 CVPI (Sold)
#2770444 - 10/25/13 06:57 PM Re: 255/50R17 on stock 17 " interceptor steel wheels ? [Re: WSMP71]
WSMP71 Offline
Loc: Pa
I should have also added, my car is a 2005 P71.
09 CVPI(Sold)
05 CVPI (Sold)
#2770447 - 10/25/13 07:14 PM Re: 255/50R17 on stock 17 " interceptor steel wheels ? [Re: WSMP71]
00MGMLS Offline
I think the rims are too skinny. They're only 7" wide I believe. I wouldn't go over the 235 wide the p71's spec'd.
#2770454 - 10/25/13 07:57 PM Re: 255/50R17 on stock 17 " interceptor steel wheels ? [Re: WSMP71]
The stock 17" steelie is 17x7 1/2".
Depending on which online resource you look at, a 255 width tire may be ok on a 7 1/2" wheel
#2770466 - 10/25/13 08:22 PM Re: 255/50R17 on stock 17 " interceptor steel wheels ? [Re: WSMP71]
BigNSlow Offline
Loc:
255s fit just fine.
#2770468 - 10/25/13 08:27 PM Re: 255/50R17 on stock 17 " interceptor steel wheels ? [Re: WSMP71]
WSTRLNG Offline
Loc: Plymouth, New Hampshire, USA
That's what I have on mine and they are great.
Victor WeSTeRLiNG
2006 "Abe" LTC Executive 6-door (3-row bench) 78k miles.
#2770505 - 10/25/13 10:02 PM Re: 255/50R17 on stock 17 " interceptor steel wheels ? [Re: BigNSlow]
Mr. 427
Originally Posted By: BigNSlow
255s fit just fine.
THIS.
That's the widest I'd go though.
1964 Ford Galaxie 500 R-Code
1972 Ford Galaxie 500
2008 Ford CVPI
#2770532 - 10/25/13 10:52 PM Re: 255/50R17 on stock 17 " interceptor steel wheels ? [Re: WSMP71]
REAL4WD Offline
Loc: Glendale, CA
I have 255/50ZR17 Nitto NT555s on each of my 17" LX Sport wheels. They look awesome, Tire store didn't even argue or make a fuss about it. just said sign here acknowledging these aren't stock sized tires and we are not responsible for installing these on your car.
The Nt555s handle great, but with the rim not being wider, the sidewall flexes more and you give up a little of your handling.
04 Crown Victoria LX Sport
95 AM General Hummer
#2770550 - 10/25/13 11:22 PM Re: 255/50R17 on stock 17 " interceptor steel wheels ? [Re: WSTRLNG]
09mnsp Offline
Loc: Minnesota, U.S.
Got any more recent pics of yours?
09 P71
#2770894 - 10/27/13 02:14 AM Re: 255/50R17 on stock 17 " interceptor steel wheels ? [Re: WSMP71]
Bangster Offline
I am NOT running these on any 7 inch wide rims, but this is the size I am looking at running on the rear of my Mark VIII on 17x9 rims.
255 wide is nearly perfect on the 9 inch wide rims, I am currently running 255/45 17s on the rear and I love the look and how they handle. I think it might be a little wide on 7~7 1/2 wide rims, but not overly so. I am moving the 255/45 17 to the front to replace the current 245/45 17s I am running (too small for the car) which are nearly too narrow for the wheels, but the tire shops have never had any problems mounting them
97 Cougar 4.6 Sport (RIP)
89 Cougar LS (RIP)
63 Falcon 302
82 F-150
97 Mark VIII LSC (RIP)
2017 Escape SE (RIP)
2012 Fusion Sport AWD
#2771382 - 10/28/13 04:17 PM Re: 255/50R17 on stock 17 " interceptor steel wheels ? [Re: WSMP71]
STLVIC Offline
Loc: Minnesota
I'm running a 275-50-17 on an 8 inch rim. A 255-50-17 should be fine on a 7 inch rim.
2004 MGM - Ice Blue - Tastefully Modded
Former Panther: 2006 Interceptor - POTM - March 2013 - Mods:
Drivetrain: 2nd CAT delete, Summit Racing mufflers, ported/polished plenum and TB, Transmission J-Mod and upgraded internals, Summit Racing underdrives, Ford Racing 3.73s, BOC 87 Octane Tune, 170 degree T-Stat, Brake Motive drilled and slotted rotors, PowerStop ceramic pads.
Best ET: 15.05 @ 91.15 MPH, not bad for bolt-on's grin
Exterior: Tinted windows, Mustang GT Premium wheels - black w/ aluminum caps and Nitto NT450's (255 front, 275 rear), Lowered 1.25" all four corners, S55 black tail lights, blacked out headlights and corners, fog lights, Mach 1 chin spoiler.
Other Rides:
2018 F150 XLT - EcoBoost, straight-piped, lifted on 35's
1984 Olds Cutlass - 468 Big Block Olds
1984 Ford Bronco II - trail and camping rig!
#2771442 - 10/28/13 07:46 PM Re: 255/50R17 on stock 17 " interceptor steel wheels ? [Re: STLVIC]
WSMP71 Offline
Loc: Pa
Thank You Everyone for Your Help smile
Bill Miller
09 CVPI(Sold)
05 CVPI (Sold)
#2856070 - 08/19/14 07:17 PM Re: 255/50R17 on stock 17 " interceptor steel wheels ? [Re: WSMP71]
P71_SN1P3R Offline
Loc: Atl, Ga
WHAT ABOUT A SET OF 05' STEELIES FROM A CHARGER? I HAVE 99 P71 AND 05' STEELIES CAME WITH TIRES FROM THE CHARGER ARE 215/65/17 AND I WANT IT TO GO WITH 235/60/17 BUT THE TIRE PLACE TOLD ME THAT SIZE TIRE ARE FOR SUV! I LIKE THE HEIGHT OF THE TIRE PERSONALLY /65/ I DONT WANT TO GO WITH THE 215 TO SKINNY! THANKS,
99 crown vic P71 81xx miles
Black leather seats swap from a 2002 MGM 8 way
17" steel wheels from 06 DC
#2856077 - 08/19/14 07:39 PM Re: 255/50R17 on stock 17 " interceptor steel wheels ? [Re: P71_SN1P3R]
TireRack says 255/50 are to be used on 7-9" wheels so you should be ok.
#2856114 - 08/19/14 10:53 PM Re: 255/50R17 on stock 17 " interceptor steel wheels ? [Re: WSMP71]
P71_SN1P3R Offline
Loc: Atl, Ga
Thanks, got it! I read some where here in the forums that the 09-11 lx Vic's tire size is 225/60/17 is that true? Will I have any issues if I go with that size tire?
Moderator:  RF_Overlord
1 registered (White Falcon LS), 84 Guests and 27 Spiders online.
