#2771838 - 10/29/13 11:25 PM Oil in the intake manifold
Qball1982 Offline
Loc: Albuquerque NM
Hey guys,
About a year ago I replaced the valve cover gaskets while I was replacing the timing chain tensioners because, well I was already in there, and because I was noticing some oil seeping around the plugs and injectors. So...that didn't fix the issue..it's not as bad but still there.
Since it was time to flush the coolant, I decided to pull the intake manifold to see whats going on. I have some nasty oil build up around the gaskets and a bit of oil in the intake itself. So I was looking to see what the possible issues could be.
Some background: I change the oil every 5-6k miles with full synthetic, oil filter with every change, replaced the PCV valve about a year ago, new valve cover gaskets a year ago, and I Seafoam once a year as well.
When I put it all back together I plan on doing a compression test to see about the rings. The car is sitting at just under 172k miles
Links to pics:
Drivers side 2 front ports
Drivers side 2 rear ports
Passenger 2 front ports
Passenger 2 rear ports
Intake manifold ports
Intake manifold ports 2
Intake manifold ports 3
Intake manifold ports 4
Front outside of the intake manifold
Edited by Qball1982 (10/29/13 11:26 PM)
2002 MGM LS, ~168000 miles, MOOG front suspension rebuild, MOOG rear cargo coils, Marauder/HPP rear sway bar, Raybestos Advanced Technology QOA pads and rotors, LED interior lights, dual exhaust, 3.27 LSD, Steeda underdrive pulleys, Heinous rear control arms
#2771904 - 10/30/13 09:15 AM Re: Oil in the intake manifold [Re: Qball1982]
Bangster Online   content
Normal higher mileage vehicle from the PCV system coating. I am not sure if an oil separator in the PCV line would help or not, I am sure it would, but probably not worth the effort.
Replacing the PCV will also help, but as the engine wears, it will cause more oil to get there from the PCV and other hose from other valve cover.
#2772241 - 10/31/13 01:28 AM Re: Oil in the intake manifold [Re: Bangster]
Qball1982 Offline
Loc: Albuquerque NM
Thanks for the reply and info.
#2772289 - 10/31/13 09:53 AM Re: Oil in the intake manifold [Re: Qball1982]
Cam lobes look decent for 172k...
#2772299 - 10/31/13 10:24 AM Re: Oil in the intake manifold [Re: Qball1982]
Agreed its normal. Even at the "low mileage" of the 80k the Merc had when I did its manifold, there was a nice oil film in the intake. I did run a oil separator in the pcv line on car and it did catch a fair bit of oil, but it eventually turned its self into a vacuum leak and I removed it.
4 registered (hot__box, Old_Guy_Stu, Bangster, 1 invisible), 85 Guests and 314 Spiders online.
bluejay_32 161
a_d_a_m 106
Old_Guy_Stu 101
Rainbowpizza 37
