Page 4 of 5 < 1 2 3 4 5 >
#2358282 - 08/23/11 05:09 PM Re: crown vic headlight harness fog add made easy [Re: DavidDC114]
04clone Offline
The filthy seaman
Loc: Holiday, FL
Thanks for doing this. You may be the first person to do it.
New Ride
#2358295 - 08/23/11 05:37 PM Re: crown vic headlight harness fog add made easy [Re: DavidDC114]
DavidDC114 Offline
Loc: RI
i think i am also.. i could not find one other thread where someone succesfully installed it.. i just hope i helped.. my next electrical task is the 09 window / lock switches!!
2004 Sport - POTM March 2012 - RIP 6-15-2013
2006 P71 Sport Edition - Retired Smithfield Police Unit 603
#2358297 - 08/23/11 05:48 PM Re: crown vic headlight harness fog add made easy [Re: DavidDC114]
Blackcvpi Offline
Cynical Jackass
Loc: Somewhere in the CRC
Its been done......
https://www.crownvic.net/ubbthreads/ubbth...193#Post2326193
#2358537 - 08/23/11 11:03 PM Re: crown vic headlight harness fog add made easy [Re: Blackcvpi]
DavidDC114 Offline
Loc: RI
Its been done......
oh i know the window switches / locks have been done, i just want to do them too.. i was saying i dont think the headlight / fog switch has been done before..
#2358538 - 08/23/11 11:03 PM Re: crown vic headlight harness fog add made easy [Re: DavidDC114]
DavidDC114 Offline
Loc: RI
here is a vid of the working switch..
http://www.youtube.com/watch?v=V3_pEu2a15o
#2358700 - 08/24/11 07:16 AM Re: crown vic headlight harness fog add made easy [Re: DavidDC114]
Mr. 427
I know I already said it David, but awesome job on this install!
1964 Ford Galaxie 500 R-Code
1972 Ford Galaxie 500
2008 Ford CVPI
#2755277 - 09/08/13 02:32 PM Re: crown vic headlight harness fog add made easy [Re: DavidDC114]
JOE M. Offline
Loc: Cooperstown, NY
is there anyone who did this mod have 2 pins left over?
The best kept secret in the auto world.
2006 P-71 Six Passenger "PL" Interior Code, "DV" Paint Code. 49,000 miles,Civilian Interior, Traction Control, 3:27 w/ Trac-Lok, 17" Good Year Eagle RSA's
Former Salt Lake County Utah, D.A.'s Office Car.
2013 Subaru Outback Limited
2005 Dodge ram Quad Cab 4X4 Diesel AKA "The Beast"
#2755308 - 09/08/13 03:46 PM Re: crown vic headlight harness fog add made easy [Re: DavidDC114]
AACoPD05 Offline
I did it. I have some left over pins but if you go to a junk yard you can grab the whole headlight switch plug and use any of the pins.
#2762707 - 09/30/13 12:38 PM Re: crown vic headlight harness fog add made easy [Re: DavidDC114]
JOE M. Offline
I did the mod and it came out great and easy to do. I ordered pure white HID's from DDM. I was hoping to post the results sooner but I am still waiting for them to arrive. There shipping is ridiculous. They charged about $23 and don't tell you it is about 2 weeks from CHINA. I hope I don't have problems as I will be pissed.
#2839405 - 06/03/14 11:51 AM Re: crown vic headlight harness fog add made easy [Re: DavidDC114]
Florida_Mike Offline
Loc: Northeast Florida
So, just to be sure. I would use the same wiring set up with the two relays, even if I'm not going to use HIDs?
‘04 Ice Blue P73 (POTM Jan ‘22), MZT Mod with ADTR intake pipe, Ported Plenum, BBK 70mm TB, BOC 93 Octane Tune, Dual exhaust with Magnaflows and MM tips, Fanblades with 235/50/18 Front - 245/55/18 Rear, KYB Shocks, Adco swaybars, Marauder Rear Spoiler, Aftermarket Marauder front and rear bumpers, Bumper Tuck, blacked out headlights, Marauder corner lights, Marauder fog lights, GCC Grill, body colored mirror shells. (MM cluster waiting for install.)
#2839485 - 06/03/14 04:19 PM Re: crown vic headlight harness fog add made easy [Re: DavidDC114]
JonnyP71 Offline
Loc: NH
I'm doing this soon. Just won a mm switch on eBay for $30. Already have the fogs. Also ordered a Mach 1 chin spoiler and steeda ud pulleys. Gotta install my magnaflows as well.
2004 Crown Victoria LX Sport
Magnaflow 11224's, MZT w/ MPT Tune, SCT X4, Y2CU-BB 70mm TB, 18" Polished Bullitts.
Waiting to install: Steeda UD Pulleys, 3.5" Stainless 22" tips, Focus Fogs, Mach 1 Chin Spoiler, FRPP 3.73's, P71 D/S w/ Fabtech Spacer.
#2839490 - 06/03/14 04:29 PM Re: crown vic headlight harness fog add made easy [Re: Florida_Mike]
AACoPD05 Offline
Yes. I did not do HID and still used two relays. I used the factory Focus bulbs.
#2839646 - 06/03/14 11:42 PM Re: crown vic headlight harness fog add made easy [Re: DavidDC114]
JOE M. Offline
If I recall the pin you have to add to the harness is a ground that triggers the fog relay that will power the power the fogs. The primary battery relay allows the system to only come on when the parking are on or low beams are on. Your choice. If you chose the low beams the fogs will shut off when you activate the high beams like most domestic cars. This whole system is wired this way when you look at the back of a relay panel on any vehicle. You are only doing what didn't come from the factory.
Follow the diagram on page three for any fog/driving light install on any car.
#2839712 - 06/04/14 10:33 AM Re: crown vic headlight harness fog add made easy [Re: JOE M.]
Thanks for the info. That was my next question. Since I leave the switch in the auto position, I don't usually run just parking lights. Any one know which wire feeds the low beam?
Edited by Florida_Mike (06/04/14 10:35 AM)
#2839957 - 06/05/14 08:10 AM Re: crown vic headlight harness fog add made easy [Re: Florida_Mike]
Question: If I wanted it to operate like a factory install, meaning fog lights operated with parking lights and low beams, but shut down with high beams, would I simply install a Normally Closed relay on the line energizing the fog lights that is powered by the high beam line? So when the high beams are on that relay opens.
