Page 13 of 13 < 1 2 11 12 13
#2833784 - 05/08/14 08:36 AM Re: The Marauder Cluster Swap... [Re: Ezbok58a]
racprops Offline
Loc: Phoenix Az
For those having to remove the pointers and remount them Mark at www.accutach.com has a page http://www.accutach.com/Pages/GeneralHowTos.aspx that shows how to use a 12 volt power supply and a wall wart power unit to calibrate your gauges...
Lots of data for gauges, and he is very helpful if contacted.
You might find my thread converting to a Mustang Cluster helpful:
https://www.crownvic.net/ubbthreads/ubbthreads.php?ubb=showflat&Number=2791245&#Post2791245
Rich
I never have enough time to do what I want to do.
2003 P71 Crown Vic, Swapped 2000 Mercury Hood doors trunk and grill header with custom lighting, 2003 Ford Explorer with 4.6. Custom Cluster.
#2833977 - 05/08/14 11:47 PM Re: The Marauder Cluster Swap... [Re: Ezbok58a]
defflepp1 Offline
Loc: Cedar Rapids, Iowa
so im looking at picking a one of these up but i dont want to if its going to be a headache to install. reading through this and some other threads its seems as though all it would be is simply splicing on the analog connectors in place of the digital ones, is that true? or is there more involved?
2003 Mercury Grand Marquis, 101,000 miles
DONE:4.10 gears, Trac-Loc, MPT 91 octane tune, K&N FIPK, 75MM throttle body, Infinity Kappa 5X7 all around, Infinity amp, Polk 12" sub in sealed box, Marauder headlights, Marauder corners
TO DO:Stainless works full exhaust, New suspension, and hopefully much more...
#2840050 - 06/05/14 04:49 PM Re: The Marauder Cluster Swap... [Re: Ezbok58a]
Florida_Mike Offline
Loc: Northeast Florida
Does anyone know of a way that I can just swap out the tach portion of the MM cluster to my CV cluster, replacing the temp and oil guages.
‘04 Ice Blue P73 (POTM Jan ‘22), MZT Mod with ADTR intake pipe, Ported Plenum, BBK 70mm TB, BOC 93 Octane Tune, Dual exhaust with Magnaflows and MM tips, Fanblades with 235/50/18 Front - 245/55/18 Rear, KYB Shocks, Adco swaybars, Marauder Rear Spoiler, Aftermarket Marauder front and rear bumpers, Bumper Tuck, blacked out headlights, Marauder corner lights, Marauder fog lights, GCC Grill, body colored mirror shells. (MM cluster waiting for install.)
#2840151 - 06/05/14 10:30 PM Re: The Marauder Cluster Swap... [Re: Ezbok58a]
Vickey2000 Offline
Loc: South Florida
Its possible as long as the MM tach pins fits into the cluster housing in place of the temp and oil gauges. T
If you have the MM tach then where is the rest of the cluster?
2000 CVPI- Matte Pine Green Metallic- Weekend Warrior
NA- 14.366 @96.83
1996 Grand Marquis- Aluminum- Daily driven
PI intake swap, marauder rear sway bar, heavy duty converter, and shift kit.
#2840243 - 06/06/14 08:59 AM Re: The Marauder Cluster Swap... [Re: Vickey2000]
I have the whole cluster, but thought it might me easier to just swap the tach into the CV cluster, Then mount an oil and temp guage into an A-pillar pod.
#2840286 - 06/06/14 11:28 AM Re: The Marauder Cluster Swap... [Re: Ezbok58a]
Ezbok58a Offline
Loc: Who wants to know...
The actual electronic back of both clusters is differently wired and routed, not sure if that'd work.
#2840460 - 06/06/14 09:21 PM Re: The Marauder Cluster Swap... [Re: Ezbok58a]
Vickey2000 Offline
Loc: South Florida
Swap the entire cluster. It will be tedious work but in the end it is definitely worth it.
NA- 14.366 @96.83
#2884423 - 02/10/15 03:58 AM Re: The Marauder Cluster Swap... [Re: Ezbok58a]
Brock_Samson Offline
Loc: Nor-Cal (Sac)
Anyone near Sacramento who can come do this with me on a weekend. Or I can pay to do it for me haha... I have a full marauder interior swap with just this and the floor shifter needed to be finished.
I powder coat shyt...
#3130370 - 03/29/16 05:16 PM Re: The Marauder Cluster Swap... [Re: Ezbok58a]
mrltd Offline
Loc: MD/OH
Quick question, on the pin swap PDF, it sways to extend 2c-5 to 1c-16 for a ground. Now, 1c-14 on the vic wiring is a ground, can that be used instead of extending the wire from the other connector?
Original Member #4 of CVN
15.02@90mph in a 4500lb wagon!!!
http://youtube.com/user/FamilyTruckster
http://jalopnik.com/337517/country-squire-autocross-madness
http://www.cardomain.com/ride/2052022
1989 Country Squire LX
1990 Country Squire LX
2004 Grand Marquis GS
#4116024 - 07/23/21 02:02 AM Re: The Marauder Cluster Swap... [Re: Ezbok58a]
Hankdow Offline
Loc: MD, USA
Alrighty then, time to bring a dead form post back to life.
So I just completed the MM cluster swap in my 02 lx sport. Speedo and fuel work fine,however the engine temp gauge pegs itself at max the moment the cluster gains power. I've tried figuring out where I went wrong but idk. Any help would be appreciated
-Hank
Ps I know about the tach I'll get to it eventually I already had one in the car, also how does one add a picture to a post?
2002 P74 Lx/Sport HPP
"Mods"
04+ cvpi airbox with 04 zip tube
smoked euro-style led taillights
Smoked headlights
Full Stainless Works exhaust
ADTR coilovers, swaybars, control arms
Comp Cams-Modular head shop stage 2 N/A cams
#4116158 - 07/24/21 08:58 PM Re: The Marauder Cluster Swap... [Re: Ezbok58a]
Bellwestern80 Offline
CVN Discord: Edsel
Loc: Evans, Georgia
To add a picture, you'll need to use an external host, like Imgur or the equivalent with direct linking for forums.
Regarding the temperature gauge, I'd verify you're hooked up (or the appropriate pin is set correctly in the connector shell) for the appropriate feed from the temperature sensor. Sounds like the feed might be grounded.
I had all sorts of weird issues when I crossed up the 'Door Ajar' input from a body ground when I did an invasive cluster swap. Having the door locks cycle with the turn signal on was a new one. smile
Definitely might be a simple fix.
My Cars:
#4116264 - 07/25/21 11:20 PM Re: The Marauder Cluster Swap... [Re: Ezbok58a]
Hankdow Offline
Loc: MD, USA
Well, I'll have to look into adding pictures at a different time. I looked over the pinout before and thought I had it right, but after reading your post I laughed and realized thats what I had done. I swapped a ground and the temp input wire pin slots, as the temp input has to cross to the other connector. Thanks for your help
"Mods"
Smoked headlights
2 registered (RF_Overlord, speedfreak), 136 Guests and 18 Spiders online.
Traffic22 15
