#2771364 - 10/28/13 03:22 PM 2005 P71 Spectra gas tank replacement
stealtreasure Offline
Loc: Wisconsin
Purchased a tank online only to find out they were using the same tank for 2005 interceptors as a 2006 on the website. Its a Spectra tank, I was wondering if anybody has any information on the differences between 05 and 06 and bottom line, can this work?
#2771377 - 10/28/13 04:04 PM Re: 2005 P71 Spectra gas tank replacement [Re: stealtreasure]
Blackcvpi Offline
Cynical Jackass
Loc: Somewhere in the CRC
As far as I know the tank design stayed the same from 98 to 2011........it could even be the same tank that's in 92 to 97 cars.
#2771388 - 10/28/13 05:10 PM Re: 2005 P71 Spectra gas tank replacement [Re: stealtreasure]
Any tank from any year box/aero should physically fit. Only things that ever changed were the fuel pumps, the various sensors/valves that sit on top of the tank, and the filler neck. AFIK, all '03+ tanks are the same.
#2771396 - 10/28/13 05:28 PM Re: 2005 P71 Spectra gas tank replacement [Re: stealtreasure]
Loc: Wisconsin
Appreciate the input. I'll try to post pics and details of this succes/debacle assuming I don't get lazy and pay someone else to do it.
#2771456 - 10/28/13 08:06 PM Re: 2005 P71 Spectra gas tank replacement [Re: stealtreasure]
hi and welcome to the site
heres some pictures for reference of a ford fuel tank.
also I highly recoment you to get the hardware and straps to make this replacement a sucess otherwise it will be a pita without this.
#2776989 - 11/11/13 01:43 PM Re: 2005 P71 Spectra gas tank replacement [Re: stealtreasure]
Loc: Wisconsin
So an update on this swap
the tank came out rather smoothly. Nothing broken,few headaches. Had go cut the wires connecting to the pump as the plug was wedged under the brake line and was unreachable, but a simple snip and splice fixed it. However, that is when I discovered the difference between 2005 and 2006 tanks
The large fuel vapor recover valve changes from a twist and lock to a push in. So the twist and lock won't work in the new tank. I'm ordering the newer part from Ford and hoping it comes with the gaskef for the push in, but it's doubtful. I cannot find a part number for the push in type gasket. This is probably going to become a make it fit problem, but I'm hoping the new part has what is needed. Updates when it comes in
The bottom line-2006 tanks fit a 2005, but there is one minor change that is a major headache.
#2776991 - 11/11/13 01:46 PM Re: 2005 P71 Spectra gas tank replacement [Re: stealtreasure]
Loc: Wisconsin
It should also be noted that this change happened in the middle of the 2005 model year. So half the 05 have different types of valves on top of the tank. Anyone doing this should check their VIN for the build date.
Edited by stealtreasure (11/11/13 01:47 PM)
#2777315 - 11/11/13 09:56 PM Re: 2005 P71 Spectra gas tank replacement [Re: stealtreasure]
yeah mid year for the 50 can be a pita as many other things also changed frown
#2779123 - 11/16/13 04:07 PM Re: 2005 P71 Spectra gas tank replacement [Re: stealtreasure]
Loc: Wisconsin
Make it fit solution: cut the old hole out, weld to the new tank. Have to cut the hole bigger on new tank. Even if you have to buy a welder to do this it's better than paying $500 for the Ford tank. Obviously it would be ideal to have a donor tank to get the 06 grommet. But I'm impatient and a bit unlucky so there it is.
#2779124 - 11/16/13 04:12 PM Re: 2005 P71 Spectra gas tank replacement [Re: stealtreasure]
Loc: Wisconsin
Here are the difference in valve. Old is green, new is tan
Literally everything else is interchangeable. This part set me back a week waiting for the new part (that didn't come with the grommet, nor could I order the grommet from my local Ford dealers or auto parts store)
#2779126 - 11/16/13 04:16 PM Re: 2005 P71 Spectra gas tank replacement [Re: stealtreasure]
Loc: Wisconsin
Finished product. Plenty of sealant on top because if it's worth doing its worth over doing. NEVER AGAIN! this tank dies with the car.
#2779134 - 11/16/13 04:40 PM Re: 2005 P71 Spectra gas tank replacement [Re: stealtreasure]
You could have coated/painted the whole tank at this point as it will rust like any other one.
the ford one was pricey but is was alredy coated.
#2779171 - 11/16/13 06:38 PM Re: 2005 P71 Spectra gas tank replacement [Re: stealtreasure]
Loc: Wisconsin
It was discussed. I get a 3 year warranty from Spectra and won't likely have the car for another 3 years. I'll risk it.
#2779173 - 11/16/13 06:43 PM Re: 2005 P71 Spectra gas tank replacement [Re: stealtreasure]
Loc: Wisconsin
Good call on the studs. Pita even with them
#2847214 - 07/08/14 01:49 PM Re: 2005 P71 Spectra gas tank replacement [Re: stealtreasure]
95p71man Offline
My tank is leaking and I'm looking to order a Spectra replacement. My build date is 02/05... is that before or after the half year change? It's a 2005 PI FYI.
1995 P71 - Sold Fall 2006
0 registered (), 43 Guests and 188 Spiders online.
CrystalPistol 330
bluejay_32 318
a_d_a_m 219
Rainbowpizza 155
DudeAbides 141
JeffBoudah 113
Moby_Vic 99
Old_Guy_Stu 82
Ponyguy 64
BigNSlow 63
