#2889220 - 03/18/15 01:47 PM Coolant leak on newer 2005 intake manifold
98lx Offline
Loc: Woodbridge, NJ
Hi, I have a 2005 CV just 100k miles with coolant leaking under the thermostat housing
on the intake manifold. I had the same problem on my 98 lx .
I want to know if the Dorman intake is any good? It is much cheaper.
or can i fix the OE. seems like its leaking where the plastic meats the aluminium. has anyone had problems with these newer manifolds. I thoought they fixed this problem with this newer manifold.
Thanks everyone.
1998 Crown Victoria LX all stock except for
P235-65 tires and black grill
#2889243 - 03/18/15 04:26 PM Re: Coolant leak on newer 2005 intake manifold [Re: 98lx]
bluviclx98 Offline
Loc: Mississippi
I would use the FRPP intake below for 239$. Some have not had good results with PI Dorman. I'm sure you have checked the thermostat gasket to rule it out along with upper radiator hose connection at housing. JMO
http://www.adtr.net/store/index.php?route=product/product&path=59_70&product_id=158
Its only my opinion and worthless cept to me!
1998 Crown Vic Lx. 103,000 miles, Dual Exhaust W/ H-Pipe, Magnaflow's and 2nd Cat Delete, FRPP PI Intake, P&P Plenum, Summit 70mm TB, MTZ, BOC 93 OCT Tune, 180 stat, 22c Plugs, ADTR High Flow intake tube, Autometer Z-Series Tach in Column Mount, 2" Hitch Receiver, Previous Owner Replaced Air Suspension with Coils. BH1976 Headlight Harness, Black P71 Honeycomb Grille. (On but not shown)
#2889269 - 03/18/15 05:59 PM Re: Coolant leak on newer 2005 intake manifold [Re: 98lx]
Jacksknight Offline
Loc: Taco Bell
Yep stick with the Ford intake and skip the Dorman. While it will work you are better off with the Ford part in this case.
Here is the same part on Amazon a bit cheaper too.
http://www.amazon.com/Ford-Racing-M9424P...Ford+Racing+4.6
2003 Mercury Grand Marquis, 148k
Need a good IAC valve for 50 bucks?
#2889353 - 03/19/15 09:59 PM Re: Coolant leak on newer 2005 intake manifold [Re: 98lx]
Boss429 Offline
Loc: Dayton,Ohio
Im a Ford racing parts dealer here and just got a note from Ford saying the FRPP PI manifold (great item) is on Back order from FRPP for the near future. You might want to stock up while they are still available.
#2889401 - 03/20/15 02:36 AM Re: Coolant leak on newer 2005 intake manifold [Re: 98lx]
98lx Offline
Loc: Woodbridge, NJ
Thanks guys for your replies, thats what I was thinking.
I know its not the hose or the o ring. Again much thanks.
#2889463 - 03/20/15 12:30 PM Re: Coolant leak on newer 2005 intake manifold [Re: Boss429]
oh really ! Knowing that their intake are crap and this is a very common problem they are gonna stop selling them .. great F-word great !
#2889470 - 03/20/15 12:50 PM Re: Coolant leak on newer 2005 intake manifold [Re: 98lx]
The FRPP intake was just selling off Production stock. Now that the 4.6 is dead, the parts are drying up.
Most of the time, you can fix the leak on the updated type Ford intake You can see on this picture the aluminum crossover corrodes and causes leaks against the plastic intake, note the white line between the plastic and aluminum
Read here
https://www.crownvic.net/ubbthreads/ubbthreads.php?ubb=showflat&Number=2488212
Edited by Chevyguy (03/20/15 12:55 PM)
2004 Crown Vic LX SOLD!!
#2889509 - 03/20/15 06:33 PM Re: Coolant leak on newer 2005 intake manifold [Re: 2004_p71]
Boss429 Offline
Loc: Dayton,Ohio
oh really ! Knowing that their intake are crap and this is a very common problem they are gonna stop selling them .. great F-word great ! [/quote]The Manifold was on a list of items that Ford sent me via E-mail that would be delayed or on National back-order due to to a parts shortage of items in the intake kit...Ford said the Intake would NOT be discontinued.
#2889558 - 03/20/15 10:30 PM Re: Coolant leak on newer 2005 intake manifold [Re: 98lx]
heres some better shot of the problems on this intake.
#2889723 - 03/22/15 03:48 AM Re: Coolant leak on newer 2005 intake manifold [Re: 98lx]
98lx Offline
Loc: Woodbridge, NJ
That's what I think mine is doing. What do I need to fix the one I have? A gasket set? Thank you for mentioning that!
#2889737 - 03/22/15 10:11 AM Re: Coolant leak on newer 2005 intake manifold [Re: 98lx]
A new intake. Once the plastic supporting the seals gives up like in Pier's pictures, the intake is as good as dead. I had a Dorman fail in the same way on my Townie last summer.
#2889797 - 03/22/15 06:34 PM Re: Coolant leak on newer 2005 intake manifold [Re: 98lx]
bluviclx98 Offline
Loc: Mississippi
Whats sad is how many times they have redesigned the intake and still has problems. Sure seems like a opportunity for some aftermarket company to get it right and make some money in the process. argh
#2889836 - 03/22/15 11:27 PM Re: Coolant leak on newer 2005 intake manifold [Re: bluviclx98]
hilljack Offline
Loc: New Mexico, USA
True.
Mine was leaking a little when I got the car. Separated the water crossover from the manifold and repaired the plastic with Acraglas. Used a new manifold gasket to seal against the engine, and an old style flat gasket to seal the crossover to the repaired plastic part. After 6 months and several thousand miles, no leaks. Will see how long it lasts.
2004 Crown Victoria Sport LX
Factory Rear Air Ride/HD KYB Shocks
JMod, 3L27, MagnaFlow mufflers
04 CVPI Air Box/Zip Tube, 70 mm Truck TB, AED SC @ 6PSI
140,000 miles
#2889855 - 03/23/15 02:41 AM Re: Coolant leak on newer 2005 intake manifold [Re: 98lx]
cruz07 Offline
Loc: Dallas County, TX
When I got my 98' I was looking around and seeing how I could replace my intake with the newer style one. After a week of looking after I got the car I realized that the previous owner had already swapped out the intake. It never gave me any issues either, not even when I traded it off.
2005 P71 146,XXX SOLD 03-10-2020
2018 Chevrolet Traverse 33,XXX
X-Panthers
1997 P71 161K
1998 P71 113K
Originally Posted By Moby_Vic
Because CVN is the land of $600 cars.
1 registered (akr619), 113 Guests and 12 Spiders online.
