#2892578 - 04/21/15 09:26 AM 2004 front shock swap chronicles
The front shocks on my 2004 Marauder blew out some time ago. I tried to swap em out but was unable to get the bolts off the ball joints... Many months later finally got it done
More to come
2004 Crown Vic LX SOLD!!
#2892747 - 04/22/15 08:01 AM Re: 2004 front shock swap chronicles [Re: Chevyguy]
Zaairman Offline
Loc: Wright City, MO
Wow, you really took it apart. Why did you separate the knuckle from the lower ball joint? We left mine intact when I did it. We did remove the sway bar totally as that gave us extra room.
2004 Ford F-350 Lariat FX4 CCLB Dually
- Not stock, garage queen, 42k original miles
1998 Ford Crown Vic Base
- Totaled by idiot running red light at 266k
2003 Ford Crown Vic LX
- Loaded, HPP, 185k, K&N Intake, 18" Mustang GT wheels, 1.5" Eibach lowering springs
#2892773 - 04/22/15 10:17 AM Re: 2004 front shock swap chronicles [Re: Chevyguy]
Lower ball joint was found to be just starting to get loose, so "since we were in there..."
All the fasteners on the aluminum knuckle have no taper and you have to hold the stud in place to get the retaining nuts off, even with an Impact wrench.
The lower ball joints came off easier and probably saved time vs trying to wrestle the strut out with the knuckle attached. Even with the knuckle off we still had to loosen the upper control arm bolts and swing it out of the way.
The leaky strut
The new Monroe severe service strut uses a plastic spacer to hold the pigtail end of the spring
the spring compressor worked well
The other side needed a lower ball joint too
I had pad slapped last summer and the original rotors were a mess after a few thousand miles, they were far too rusty to turn anyways...
All done
I think it's riding a bit high
Old pic
After struts
We jacked up the suspension via the lower control arm before re-torquing the upper control arms but that may not have been enough... Or the replacement struts make it ride a bit higher..
#2892971 - 04/23/15 11:50 AM Re: 2004 front shock swap chronicles [Re: Chevyguy]
This morning before loosening the upper control arms and lower shock bolts
After loosening plus I pushed down on the suspension a few times before re-torquing
Still seems high but apparently a bit lower than before??
#2892974 - 04/23/15 12:00 PM Re: 2004 front shock swap chronicles [Re: Chevyguy]
I am guessing that the aftermarket shocks have a bit less spring height, especially with the plastic spacer which takes up that notch where the bottom pigtail of the spring sits in, called the coil spring seat.
The factory struts have the seat as part of the strut, so perhaps the new struts compress the spring a bit more than stock
#2892992 - 04/23/15 02:18 PM Re: 2004 front shock swap chronicles [Re: Chevyguy]
ComputerGeek737 Offline
Loc: Tucson, AZ
Had the same issue after replacing mine, I attributed it to this...
http://imgur.com/a/LAXxT#6
Comparing to the new one...
http://imgur.com/a/LAXxT#7
Even after 25,000 miles it still rides high similar to yours
2004 MGM LS Ultimate
CVPI Front Shocks & Springs, 29mm front 21mm rear sway bars, CVPI dual exhaust added, 70mm TB, Arnott A-2220 Rear Air Bags, D2S 4.0 Headlights
#2893064 - 04/23/15 10:36 PM Re: 2004 front shock swap chronicles [Re: Chevyguy]
Wags4000 Offline
Loc: Northumberland, PA
last year i put on the same gas magnum severe service struts you did. i had the car completely on its own weight when torqueing the UCA and did not have a change in ride height. like 737 said, it could be that the bushing in the shock gave it a little more height, but without a pre vs post measurement its hard to tell how much higher yours is. unless you somehow twisted the spring 'open' a bit when installing? if you had the spring alignment slightly off when you installed the strut and had to twist it to get the bottom bolt in, you could have twisted it open slightly causing a taller spring.
2003 CVLX; 312k mi (perch 103k); P74; Black Paint/Black leather; Blinking side marker mod; 2.73 open dif; Autolite Dbl Plat; General Altimax RT43; LCM Ext relay, FRPP mani; Max-Life 5w-30
03 Crown Victoria LX by Wags4000, on Flickr
2001 Merc GM LS; RIP at 340k mi (bought at 67k)-my former commuter. Finally passed on due to no one driving it and things just stopped working.
1986 Merc GM LS; 165k mi (bought at 118k)- Red with White vinyl half roof; 5.0L; RIP
87 Caprice Wagon; 356k; 5.0L(307cu) RIP
#2893105 - 04/24/15 08:06 AM Re: 2004 front shock swap chronicles [Re: Wags4000]
Zaairman Offline
I bet it's riding about a 1/4" higher in front. I put the KYB police spec shocks on my car with Eibach 1.5 lowering springs, it really lowered the car about 1 1/4". Although mine didn't have the plastic spacer, they had the metal bucket like the factory shocks. Interesting. I just put the shocks on a few weeks ago too.
#2893129 - 04/24/15 11:09 AM Re: 2004 front shock swap chronicles [Re: Chevyguy]
Chaplian Offline
Insert witty title here
Loc: Chicago, IL
They should have settled after about 100 miles of driving.
2011 Crown Vic LX- 78,xxx.
2003 Crown Vic HPP- 235,xxx miles. Retired.
1995 Impala SS- 29xxx miles. The Lovely Lady
2003 BMW 325i Wagon- 8250 RPM redline. Complete M3 drivetrain, suspension, and electronics. Taylor Swift.
2017 Mazda3 GT Hatchback- 90,xxxx miles. 2.5L, fully loaded. The Daily Grind.
#2893134 - 04/24/15 11:50 AM Re: 2004 front shock swap chronicles [Re: Chevyguy]
The ball joints don't have tapered studs? That could make separating them without damage a lot easier. My buddy's '03 is getting new front shocks in the very near future and that was something I was worried about since as far as we can tell, the ball joints are in good condition still.
#2893150 - 04/24/15 03:52 PM Re: 2004 front shock swap chronicles [Re: Chevyguy]
Just use good allen key sockets to hold the ball joint stud in place while you remove the bolt.
I did confirm from my pictures that indeed my original lower shock eyelet was sunken off the centerline while the new shock was in the middle, looked just like the pictures that Computer geek had posted.
Plus since the strut is used for other applications the distance of the spring perch from the lower mount is probably a bit longer as well. For the average joe they won't sweat a few MM of extra ride height....
These QA-1 struts would fix that problem
#2893152 - 04/24/15 03:55 PM Re: 2004 front shock swap chronicles [Re: Wags4000]
We fiddled quite a bit to get the springs lined up right, we did twist one side a bit but we rotated the upper mount and the springs were nice and flush against both notches.
#2893233 - 04/25/15 11:08 AM Re: 2004 front shock swap chronicles [Re: BigMerc96]
Zaairman Offline
If the car has any mileage at all on it, I'd replace the ball joints while I was in there. But, I don't like doing things twice.
#3154946 - 04/13/16 02:48 PM Re: 2004 front shock swap chronicles [Re: Chevyguy]
Bumping my thread, forgot to add the part numbers.
Rockauto.com:
monroe#550018---rear(gas magnum severe service)
Monroe#553001---front(gas magnum severe service)
Moog#80668---front springs to go with #553001 (I used my original MM springs, but if you need new ones that's then one you want)
I can report they feel just as good as when I put em on last year. The Front end has settled back down somewhat too!!
#3157018 - 04/14/16 09:38 PM Re: 2004 front shock swap chronicles [Re: Chevyguy]
CrownVic1978 Offline
Loc: Missouri
How do they compare to stock shocks?
I need to this to my 11 cvpi, the drivers front squeaks when hitting bumps.
