#289853 - 11/12/03 09:33 PM
Re: Carbon Build-Up
Loc: Orlando, Florida
btw - the detergents in the gas is what CAUSES soft carbon build up...
Techron will keep carbon from forming - but it will NOT remove it.
"I prefer the tumult of liberty to the quiet of servitude."
Thomas Jefferson to James Madison, 1787
2007 BBB MSRT8 2003 BBB Crown Vic Sport LX 1996 BBB Impala SS 1972 Chrysler Newport
#289856 - 11/13/03 09:12 AM
Re: Carbon Build-Up
Loc: OREGON
Ive been using http://www.buyduralt.com/ Duralt for years and this stuff works. If you run it in two tanks back to back your carbon will be gone. I usually run one treated tank through just before every other oil change.
Sig removed. Read the rules.
#289857 - 11/13/03 11:07 AM
Re: Carbon Build-Up
Loc: Motor City, USA
I found I get bad gas mileage and performance using 86, 87, and 89 octane fuel in the T-bird, E-250, and the Crown Vic.
Using 93+ octane - I get the best gas mileage. Explain the anti-knock rating all you want but 3 different engines seem to like higher octane fuel better than low octane stuff.
My Vic gets the best gas mileage using Sunoco Ultra 94 - no doubt about it. Based on what a lot of "experts" say, I would be getting the worst gas mileage with 94 octane fuel because it's highly resistive to knocking and wouldn't burn up properly, etc... but truth is, I can score 22+ mpg on the highway in my Vic w/ the 94 octane (3.55s, 2000 HPPs - werent known for the best gas mileage at all). With 93 octane and anything below that, 20-21 is the best I could do - IF THAT. 18-19 mpg was more common.
In the city, 10-11 mpg was commonplace for EASY going driving w/ 87-93 octane. 11-12 mpg is what I get with aggressive city driving (practicing launching to 40 mph at each stoplight every chance I can get, etc...) and 12-13 for easy going driving all with 94 octane fuel.
I notice the same thing with my T-bird using 87-89 octane fuel (BP, Amoco, Shell, you name it - same results) but 93 octane gives the best gas mileage.
As for carbon build-up... the T-bird DID have a problem with pinging but checking the ignition timing (and re-adjusting) as well as using Chevron Techron did the trick. The intake ports on the heads were all black but there wasn't carbon build-up (in the manner where you could grab out deposits). The tailpipes were all blackened with soot... and the cats were the originals (23+ years old) but I passed NJ emissions with flying colors. CO% was ultra ultra low and the NOx levels were obviously higher than a brand new EFI car, but they were well below the max spec for my car.
#289858 - 11/13/03 11:08 AM
Re: Carbon Build-Up
Loc: Grand Rapids, MI
If I had to guess I would say its due to the purity of the gas or the additives, not the octane rating. But like I said, thats just a guess...
Dead: 1994 Crown Vic LX/HPP... over 190,000 miles when she got totalled  Gone: 1996 Mustang GT 5spd, drop top, Bassani OR X-pipe, Dynomax Ultraflows, PI Cams, K&N FIPK, C&L Elbow and 75mm TB, PIAA 1700X... Dead: 2012 Mustang V6 Performance Package, Kona Blue with MagnaFlow "Street" catback. KIA August 2012
#289859 - 11/13/03 11:25 AM
Re: Carbon Build-Up
Loc: Austin, Texas (and Dallas, Tex...
B-12 Chemtool <3
1)The "new" 2001 p74: Silver Frost Metallic 150k; new lights and tint; full exhaust, intake and computer to come! 2)1996 p74 (p71 convert): Wedgewood Blue 250k; used up but still going 1968 Mustang Coupe: I6, Factor Specs/Original Color
oye como va
#289860 - 11/13/03 12:58 PM
Re: Carbon Build-Up
Loc: Ft. Wayne IN
I just let my engine warm up really good and then sprayed the water in the TB while reving it. I then used a vaccuum tool and hooked it up to my egr and opened it while doing the same thing. Idle seemed smoother but it could be in my head.
1995 Town Car, flowmaster 50's, gutted cats, gutted evap system, cold air tube, MMairbox & 80mm maf, K&N air filter, DR chip, 180 thermostat, 22pp plugs, Steeda underdrive pulleys w/gatorback belt, transgo shift kit, cross-drilled rotors w/performance friction pads, addco swaybars front and rear, poly bushings, edelbrock IAS shocks all around, deleted mechanical fan, Kenwood MP4028 w/kenwood 6x9's and 6x8's and more to come
1982 Crown Vic LTD 2dr No air pump or cats, cragar ss's, dual exhaust, tach, volt, oil, temp gauges.
#289861 - 11/13/03 01:39 PM
Re: Carbon Build-Up
My buddy had this done by the ford dealer on his wifes '98 Vic, he swears by it.
He says his mileage has gone up and car is a much "faster" off the line and overall.
I've been considering this since I drove his wife's car, it's real smooth.
scorer75@aol.com1996 PI Stock Daily Driver Bilstein Shocks Air-horn Strobes Previously K-9 car
#289862 - 11/13/03 01:59 PM
Re: Carbon Build-Up
Us old farts just get on the freeway and let 'er rip. You'd be amazed to see how much crud gets blown out the exhaust.
I've used a water setup that was permanently installed on a truck I had...but that engine kept blowing the heads off, and it may have been due to the water injection.
I'd agree with some of the suggestions above, using one of the additives to help clean up your carbon (if you really have any.) Remember, it's nearly impossible to see the 'inside' of a cylinder through the plug hole. About all you could see would be the top of a piston, and even then you couldn't tell how thick the carbon was.
You might ask around and see if anyone has a borescope you could borrow. That would let you inspect the inside of your cylinders/pistons/valves without tearing the engine down.
Good luck!
1997 P71 with 73K miles - SOLD
Meddle Not In The Affairs Of Dragons, For Thou Art Crunchy And Taste Good With Ketchup!
#289863 - 11/13/03 03:02 PM
Re: Carbon Build-Up
I've also heared that ATF fluid will remove carbon build-up. Anyone else hear of this working ?
Dan...
1993, P71 Police intercepter X-CHP West Valley commanders vehicle Accel "Kool Blue" hi-performance air filter 5% tint all the way around 190.000+ miles Vhf Motorola Spectra radio w/ DES-XL
A well regulated Militia, being necessary to the security of a free State, the right of the people to keep and bear Arms, shall not be infringed.
U.S. Bill of Rights, Amendment II, September 25, 1789
#289864 - 11/13/03 03:46 PM
Re: Carbon Build-Up
Loc: MCO
Yes, but you have to spray it VERY lightly into the throttle body. You don't want to just pour it in. A spray bottle would work.
Log off life.
#289865 - 11/13/03 04:46 PM
Re: Carbon Build-Up
Loc: Atlanta, GA
Thanks for all the suggestions. For right now I am going to use the Lucas treatment every other fill-up for about 3-4 tanks. At the same I am going to take this diagnoses as permission to go WOT a little more often  In the near future I am going to try and find a shop with a Motovac that knows what they are doing. After reading about it on the SS forums and elsewhere it looks legit enough to try. I may also give the water process a go.
 '99 Grand Marquis LS w/ HPP+ABS/TC 35% Tint All Around Flowmaster Delta Flow 50's Genuine Marauder Tips CV Sport 17" Wheels Pirelli P-ZeroNero's
#289866 - 11/13/03 09:29 PM
Re: Carbon Build-Up
Loc: Behind you
hawkzone, listen to me very carefully. There is one product and one product only that you should ever put into your gas tank. That product is called Sea Foam.
If you want to nix the carbon deposits, first pour two cans into a half tank of gas. When you've run through that gas, suck another half can through your PCV valve at high idle until the engine stalls. Wait five minutes and turn her over, and you'll find it runs better than you had ever imagined.
#289867 - 11/13/03 09:31 PM
Re: Carbon Build-Up
Hawkszone...
I believe if you look at that thread - one of the Gassit members (the guys who put on SSH3) does the MotorVac in his shop...
Name is Scott = goes by atlSS96 and he is near Atlanta.
