#2495083 - 04/04/12 01:42 PM Loose feeling coming from the rear of the car
Jarvo
Unregistered
Can someone answer what the symptoms would be with the following (including bushings/mounts);
Worn out Watt's linkage
Worn out control arms
Worn out rear sway bar end links
I'm having some kind of loose feeling coming from the rear of the car. It's not a normal bouncy feeling, but more like a sideways motion. Really hard to explain, but imagine someone is pushing your car hard from the side while you sit in it. That's what it feels like when I drive.
I recently had the car in for inspection, and they didn't notice any problems in the rear. Just that the front sway bar end links were worn out. So I replaced those, and it made it more noticable that the loose feeling is coming from the rear. Before it was kind of hard to tell where it came from.
Car has around 124k miles iirc
Edited by Jarvo (04/04/12 01:45 PM)
#2495119 - 04/04/12 02:54 PM Re: Loose feeling coming from the rear of the car [Re: ]
Augers00P71 Offline
Loc: Allenstown NH
id check my tire pressure first. any weird sounds?
My Current Panther
#7 of 9. 2000 Ford Crown Vic P71 SAP w/84k; Glasspacks, K&N Intake, 20" Wheels, Custom Paint, lowered, Jmod, 20% Rear Tint, HID's
#2495167 - 04/04/12 04:19 PM Re: Loose feeling coming from the rear of the car [Re: ]
DDK03CVPI Offline
Loc: Eastern Shore of Md.
Might help if you jack up the rear of the car,put jackstands under the frame & let the rear end hang unsupported.Then,have someone push & pull the rear wheels from side to side while you look to see if any of the rubber bushings are worn out or parts are loose.
Good luck, DDK
2004 CVPI, Dark Blue Pearl, 106,xxx mi., 3L27 Diff., '05 6cyl Mustang wheels,MaxiTrip Gauge,Putco H/L Harness,'01 Explorer AM/FM/CD,MM rear sway bar.
2003 CVPI,Performance White, 150,xxxmi.,R.I.P. 12/10/11
#2495218 - 04/04/12 05:25 PM Re: Loose feeling coming from the rear of the car [Re: ]
If its not tires, then its a bushing either in the control arms or the watts link. Push on the rear 1/4 panel while watching the wheel and tire in relation to the wheel well, there should be little to no movement between the wheel and body.
#2495412 - 04/04/12 09:59 PM Re: Loose feeling coming from the rear of the car [Re: ]
Jarvo
Unregistered
It's not tire pressure. It was the first thing I checked. And there is movement of the body in relation to the tires if I push the car sideways. Quite alot actually. I'll take a look with car jacked up when I change to my summer tires.
#2914433 - 08/24/15 01:41 AM Re: Loose feeling coming from the rear of the car [Re: ]
Brock_Samson Offline
Loc: Nor-Cal (Sac)
Have this same issue and symptoms.. I have 18s and I feel the shimmey in the rear when it shifts up under wot...
I also need the hang the rear axle and try that.
I powder coat shyt...
#2914436 - 08/24/15 02:22 AM Re: Loose feeling coming from the rear of the car [Re: ]
Ponyguy Offline
Loc: Oswego, IL
In all those cases, check the Watt's linkage, especially the pivot on the axle pumpkin.
Sig removed. Read the rules.
My transportation sources:
#2914437 - 08/24/15 02:42 AM Re: Loose feeling coming from the rear of the car [Re: ]
IPreferDIY Offline
Since you're at about 124,xxx miles, my guess is it's about time to replace the whole lot of steering and suspension joints and bushings. You can expect at least 100,000 miles out of that stuff, and how much more is a matter of luck. Age is also a factor. What year is your car?
My preference is to do everything at once to avoid multiple alignments. When my 2000 MGM needed doing, I started with the various joints in the front and learned the hard way how important the control arm bushings and stabilizer bar bushings are on these cars. After pretty much everything in the front was done (except springs and shocks, which still seem okay), I was getting an obvious swaying motion when stopped at a red light in high wind. I also felt some side-to-side motions on the highway in certain circumstances, though not as bad as I've seen others describe. All of that improved after replacing the rear arms, Watts link, and stabilizer links and bushings. It's a lot of work, but you potentially double the typical lifespan of your car.
2000 Grand Marquis LS HPP, a hand-me-down in 2008 with 128,000 km; 180,000 km as of May 2015
mods: air filter box 'tuba', headlight relay harness, J-mod (around 186,350 km), 70mm throttle body, KYB Gas-A-Just shocks, aluminum driveshaft, ARA3 PCM
#2914459 - 08/24/15 09:43 AM Re: Loose feeling coming from the rear of the car [Re: ]
BlueFusion Offline
Loc: /root
Ive had that issue if I put my tire pressure up too much. I'm running Perellis good up to 51psi. If I go above 44psi, the rear end feels all over the place.
#2914501 - 08/24/15 04:42 PM Re: Loose feeling coming from the rear of the car [Re: ]
First questions is What year is the car?? There were big changes in the rear suspension in 1998.
2004 Crown Vic LX SOLD!!
#2914699 - 08/25/15 05:04 PM Re: Loose feeling coming from the rear of the car [Re: Chevyguy]
DudeAbides Offline
Loc: California, Uber Alles
The OP is from 4/4/12.
Originally Posted By 73vwTodd
That's a stretch to suggest he got T-boned because he didn't stay home.
2008 P71: Dual spot lamps & a Marauder spoiler; business up front, party in the back.
How will I laugh tomorrow, when I can't even smile today?
#2914706 - 08/25/15 05:58 PM Re: Loose feeling coming from the rear of the car [Re: ]
achinaghost52 Offline
Loc: Central Missouri
Lol, he might not be checking back too often in that case.
2008 Evo X Martian Blue, 330whp/wtq
2009 CVPI HMS Relentless, Arizona Beige, former Iowa State Police, 147k.
Mods: K&N Panel, Hawk HPS + SS Caliper->Body Lines, Nenno center console, 400mm Broadway, Headunit, CB + 5ft Firestick, Open H-pipe
Future: Limited slip diff, sway bars, push bar, flat bottom
#2915500 - 08/30/15 09:35 AM Re: Loose feeling coming from the rear of the car [Re: achinaghost52]
Merc1973 Offline
Loc: MI
This is still a helpful thread to me. I also have some looseness and a shaking with highway speed corners.
[img]https://imgur.com/a/Y8I4i3r[/img]
2001 Grand Marquis GS, Tropic Green, 150k, 17mm Sway bar, Bilstein shocks, Torq Thrust AR wheels, Tork Tech kit with m112 blower, 2.93 upper pulley, glowshift gauges, JMod, 2300-2500 monster trans TC, deleted unmentionables, aluminum driveshaft, 3.73 rar with LSD. 10 PSI screamer!
might know me on Discord as nowen97
#2915550 - 08/30/15 04:48 PM Re: Loose feeling coming from the rear of the car [Re: ]
Wildabeast Offline
Loc: Fairfield, CA
As an owner of two CNG cars, my 2003 with extended tanks is solid as a rock. All the bushings etc look fine.
My 2000 LX was wobble crazy, with only four tanks. I replaced the sway bar and added ES bushings, new Bilsteins and new Moog cargo coil springs. Still wobble-wobble. Lifted my rear end off the ground and "twisted" my control arms with my had. The bushings were like marshmallows. I ordered some control arms from CHE Performance....WOW! Wobble was reduced significantly and the ride was a lot better. However, I think with an upgraded Watts link, that'll finish it off.
#2916924 - 09/09/15 02:42 PM Re: Loose feeling coming from the rear of the car [Re: ]
Loc: Nor-Cal (Sac)
So yeah so if i wanted to do everything back there..
watts-link assembly? or just a bushing for it?
control arms same thing bushings? or complete replacement?
Also is there Polyurethane options?
4 registered (ironmarinebill64, RF_Overlord, jimmyv1958, 1 invisible), 71 Guests and 291 Spiders online.
bluejay_32 162
Old_Guy_Stu 97
a_d_a_m 94
Moby_Vic 55
CrystalPistol 50
TheCableGuy 47
RF_Overlord 44
Ponyguy 39
