#2921769 - 10/08/15 10:39 AM Driver's Side Valve Cover Breather & Oil
MM54 Offline
Loc: NE Ohio
Long story made short:
A while ago when I replaced my IACV, the old one was full of oil, and the TB and plenum also were coated. I cleaned it up a bit and found that the line leading from the driver's side valve cover to the intake was oily inside (nowhere else the oil could be coming from)
Recently I put a catch can in line with that breather, to keep oil out of the intake (I've had one on the PCV line for a while too, and it catches quite a bit).
In 150-ish miles, though, I have caught absolutely zero oil in this breather line - not even residue in the bottom of the can. In the same time, the PCV one has caught, say, 1.5 mL or so.
Is this breather really that slow, that it takes thousands of miles for any noticeable oil to get through, or is something going on and the breather not breathing? Any ideas?
-Matt
2002 P71 - 205k miles, Stage V DOWRS* - Sold 18 Sept 2019
1971 Chevrolet Chevelle - Rolling Project
1985 Mazda RX-7 - Summer Daily
1999 Toyota 4Runner - Daily Duty, P71 Replacement
*Dynamic Oxidation Weight Reduction System
Stage V: Terminal Rot
#2921775 - 10/08/15 11:34 AM Re: Driver's Side Valve Cover Breather & Oil [Re: MM54]
That makes sense if you think about it. The breather on the drivers side is the air INLET for the PCV system. Air flows into the engine thru that hose, and is sucked back out by the PCV valve on the other side. Only thing that passes thru that hose if everything is working correctly is clean air from the intake tube. Now upon shutdown, oil vapors can come back up out of the valve cover and condense in that hose and thats likely what you saw built up in it from the 177k miles your car has. If you ever remove the oil filler cap when the engine is hot, you'll likely see the same oil vapors rising out.
#2922023 - 10/09/15 08:01 AM Re: Driver's Side Valve Cover Breather & Oil [Re: MM54]
MM54 Offline
Loc: NE Ohio
The oil in the intake wasn't condensed vapors - it was (and sort of still is, I didn't get it all) coating the TB and inside the plenum, as well as all through the line to (and the inside of) the IACV - that sounds like oil coming in while the engine is running, not vapors coming in and only happening to go towards the engine, including onto the TB and plenum behind the butterfly and into and through the IACV, both of which should be closed with the engine off.
-Matt
4 registered (PaulyPeligroso, LTC_Dave, VP71, TheCableGuy), 90 Guests and 287 Spiders online.
bluejay_32 155
Old_Guy_Stu 97
a_d_a_m 94
Moby_Vic 55
DudeAbides 53
CrystalPistol 50
TheCableGuy 47
RF_Overlord 45
Rainbowpizza 39
Ponyguy 39
