#2942202 - 12/01/15 11:55 AM Need PCM wiring diagram for 2008
Fordiesel69 Offline
Loc: Erie, PA
On my dads 08', there is a cut wire on the center plug of the PCM. It is a yellow wire with a black stripe. Everything seems to work so I do not want to fix it without knowing what it is. I am thinking it was cut for a reason!!!!!
-'14 Fusion S - 160K
#2942354 - 12/01/15 01:26 PM Re: Need PCM wiring diagram for 2008 [Re: Fordiesel69]
Bangster Offline
There are multiple yellow/black stripe wires to the PCM, here are 2 from the 07 EVTM (it is the 07-08 DVD but only has 07):
#2942562 - 12/01/15 04:21 PM Re: Need PCM wiring diagram for 2008 [Re: Bangster]
Fordiesel69 Offline
Loc: Erie, PA
Does ford tell you what the center plug is on the PCM?
#2942634 - 12/01/15 05:59 PM Re: Need PCM wiring diagram for 2008 [Re: Fordiesel69]
You should be able to identify it in the pictures by the wires, check wire #1 and it should be different on each plug.
#2942962 - 12/01/15 10:19 PM Re: Need PCM wiring diagram for 2008 [Re: BlackVic_P71]
Fordiesel69 Offline
Loc: Erie, PA
Good idea! Will report back my findings.
#2943074 - 12/01/15 11:18 PM Re: Need PCM wiring diagram for 2008 [Re: Fordiesel69]
Bangster Offline
The third plug is C175E, I didn't see a yellow with black tracer in it, but will check again. If you figure out which one it is, I can post the destination diagram as well.
#2943914 - 12/02/15 11:12 AM Re: Need PCM wiring diagram for 2008 [Re: Bangster]
Fordiesel69 Offline
Loc: Erie, PA
Its the center MIDDLE plug on the PCM.
4 registered (GMUE03, bobb, LTDteether, BlackNFast), 107 Guests and 240 Spiders online.
bluejay_32 198
Old_Guy_Stu 107
BigMerc96 91
a_d_a_m 76
Ponyguy 60
Moby_Vic 60
2008interceptor 47
Bangster 43
2004_p71 42
124neta 42
