Page 3 of 5 < 1 2 3 4 5 >
#3909330 - 03/21/18 09:22 PM Re: Dim/Flickering Odometer Fix [Re: GM_Guy]
Plain old extra fine tip soldering iron. Its a surface mount IC, nothing special about it.
AR is setup up for this, thats all they do. They can test the full function of the cluster, check the code, rewrite the code, have access to proprietary parts, possibly even at one time where a factory authorized repair center so plenty of insider info they don't share, its one thing when you know the workings of the thing it makes it all that much faster to repair. I know for some of the stuff I repair regularily the sounds it makes, or does not make, or an extra click, etc, is my biggest diagnostic tool, you don't get there by only working on one or two of the things. But also getting up close and personal to recognize the noises it is supposed to make and for how long. No service manual teaches you that, just experience.
Alex.
#3927930 - 04/12/18 08:56 AM Re: Dim/Flickering Odometer Fix [Re: GM_Guy]
Fordiesel69 Offline
Loc: Erie, PA
So moving forward...for those of use who want to buy the resoldering equipment, it would be awsome to find out actually where these problem areas are. How we do that, Im not sure. I was considering takeing super high res photos of every joint, then sending away let it get fixed, then rephoto it again and look for the repair areas.
On a side note, I have a very high success rate with most circuit board repair from pinball machines, F-150 overhead displays, F150 odometers, etc.... Im struggling with these crown vic clusters however.
-'14 Fusion S - 160K
#3937858 - 04/25/18 10:15 PM Re: Dim/Flickering Odometer Fix [Re: Fordiesel69]
EMILBUS Offline
Loc: PA
How much $$ for AR speedometer to look at it? How quickly can they turn it around?
#3945090 - 05/04/18 06:11 PM Re: Dim/Flickering Odometer Fix [Re: GM_Guy]
4U2NV Offline
Loc: BC, Canada
the title on this thread should be UNSOLVED
#3992568 - 08/25/18 10:15 AM Re: Dim/Flickering Odometer Fix [Re: GM_Guy]
Jamesbush Offline
Loc: Florida
Sweet Wright up but the pictures are missing any way to fix that by chance
#3992608 - 08/26/18 09:46 AM Re: Dim/Flickering Odometer Fix [Re: GM_Guy]
Until the forum admin fix things, no.
#3992610 - 08/26/18 09:53 AM Re: Dim/Flickering Odometer Fix [Re: GM_Guy]
Hadn't noticed that even pictures hosted here are a victim of the [censored] by Vertical Scope
#3992614 - 08/26/18 09:56 AM Re: Dim/Flickering Odometer Fix [Re: GM_Guy]
Killed my avatar as well, had to reupload it.
#3992616 - 08/26/18 02:30 PM Re: Dim/Flickering Odometer Fix [Re: GM_Guy]
Jamesbush Offline
Loc: Florida
Dam that sucks big is they any way I could get those pics by chance need to do this fix maybe by email or messaging here my email is [email protected] any help appreciated
#3992658 - 08/27/18 05:15 PM Re: Dim/Flickering Odometer Fix [Re: GM_Guy]
Solder the connector, solder the surface mount components UNDER the odometer display, and resolder the legs of the odometer. Then eyeball the rest of the through hole components and see if they need a touch up. It'll all be self explanatory once you got it apart and looking at it.
Alex.
#3992660 - 08/27/18 05:34 PM Re: Dim/Flickering Odometer Fix [Re: GM_Guy]
Jamesbush Offline
Loc: Florida
Thanks a lot appreciate it
#3992662 - 08/27/18 05:36 PM Re: Dim/Flickering Odometer Fix [Re: GM_Guy]
Jamesbush Offline
Loc: Florida
#3997756 - 12/07/18 03:27 PM Re: Dim/Flickering Odometer Fix [Re: GM_Guy]
RdWrir Offline
Loc: IL
Thank you for this post.
#3998362 - 12/15/18 09:38 AM Re: Dim/Flickering Odometer Fix [Re: GM_Guy]
DutchYellowCab Offline
Loc: Netherlands
Hi. Pictures in top post seems to have disappeared. Is this a forum error? Can it be fixed?
I finally dare to start this adventure but not without some photo material next to me on my desk.
2006, 2009, 2011 Crown Victoria
2000, 2002 Lincoln Town Car
2003 Lincoln Navigator
#3998584 - 12/17/18 09:39 AM Re: Dim/Flickering Odometer Fix [Re: GM_Guy]
Forum issue. Looks like most every circuit board in existance. Short version: Resolder the surface mount parts under the odometer display, resolder the display standoffs, the high watt resistors and the connector.
6 registered (smokeybandit2, Hound, WSTRLNG, RipWixomAssembly, Old_Guy_Stu, 1 invisible), 69 Guests and 115 Spiders online.
bluejay_32 97
Armada Master 86
Old_Guy_Stu 74
Moby_Vic 59
Dmblanch 57
DudeAbides 50
a_d_a_m 47
SocalSam 43
Ponyguy 40
