#3089921 - 02/29/16 07:04 PM
transmission issue 06 p71 4r75e
Loc: Utah, Centerville
So let me start by saying I have searched this issue on the forms. I found one post that was similar I replaced the transmission position sensor. That seemed to work for some time. Replaced the tranny fluid. Seems to have helped. Fluid does not smell burned. I changed it in July of last year. Now on hills going around 40 mph the trans.ission seems to slip out of gear or shifts out of gear. Used to just be on hills on slow turns up or down. Now just going up. the transmission will run fine when not on. A hill when pulling the dipstick I do not see any metal fragments and liquid is not brown it is still red/pink any ideas? Car has about 76000 miles on it. It was a highway patrol unit here in utah. Any ideas would be wonderful. When on flat ground transmission runs fine and does not have issues and shifts like normal.
************** 2005 P73 113xxx (sold) 2004 f150 7700 115xxx cng (sold) 2006 p71 67xxx (current car) **************
#3090129 - 02/29/16 09:05 PM
Re: transmission issue 06 p71 4r75e
[Re: bagmister]
Yes it is full. I checked it while it was hot and running.
#3090209 - 02/29/16 09:58 PM
[Re: bagmister]
Loc: Rock Island
I have to ask. Are you sure it's not just going in and out of OD?
2003 P71,3.73 Gears, T-lok, Trick flow plenum, 70mm TB, Rebuilt J-modded Trans, 2.5in X-pipe, 2012 Mustang GT Wheels, other useless misc stuff *Sold 2/10/16 1998 Mark Viii LSC, Rebuilt trans, and basically everything, Blown trans 2005 Crown Vic P73, Blown trans
#3090233 - 02/29/16 10:03 PM
[Re: CVJPMG]
That I am not sure on. I give it gas in the 40 mph range and it gives a lot of resistance towards moving but no shutter. Then goes in and out of gear. Then it's as if the car gets as second wind and then works just fine. It's really strange.
Edited by bagmister (02/29/16 10:14 PM)
#3090465 - 03/01/16 12:00 AM
[Re: bagmister]
Loc: Columbus, OH
These transmissions work well but are real picky about the fluid. You must use Mercon V or Mercon LV in your transmission. I believe for the 2006 it is still Mercon V. About the only generic fluid I would trust is Amsoil or Redline. I use Amsoil in my car with no problems. I have also used Mobil 1 Mercon V and Motorcraft Mercon V. Either of the two fluids mentioned are good fluids. Do not mix fluids between manufacturers though unless you have no choice and you are going to change it soon. The reason for this is that the additives are different between different fluids even though they meet the same specification requirements. The specification is for performance and as a result the additives between brands/manufacturers may not be compatible with each other even though the fluid itself meets specification.
Edited by stalag (03/01/16 12:01 AM)
#3090697 - 03/01/16 10:12 AM
[Re: bagmister]
4R70W rebuilder
So let me start by saying I have searched this issue on the forms. I found one post that was similar I replaced the transmission position sensor. That seemed to work for some time. Replaced the tranny fluid. Seems to have helped. Fluid does not smell burned. I changed it in July of last year. Now on hills going around 40 mph the trans.ission seems to slip out of gear or shifts out of gear. Used to just be on hills on slow turns up or down. Now just going up. the transmission will run fine when not on. A hill when pulling the dipstick I do not see any metal fragments and liquid is not brown it is still red/pink any ideas? Car has about 76000 miles on it. It was a highway patrol unit here in utah. Any ideas would be wonderful. When on flat ground transmission runs fine and does not have issues and shifts like normal. it is common for the filter to separate from the grommet that holds the filter in place, causing the filter to fall into the pan. First thing I would do is pull the pan and check filter.
2011 P7B - retired Jay county Indiana Sheriffs car2003 Lincoln Town Car Signature - 3.27 RAR, dual exhaust and J-mod - SOLD 09/201189 Crown Victoria LX- HPP Box - SOLD 09/201088 Grand Marquis LS - The original - Totaled 5/2006I rebuild AODE/4R70W/4R75E Transmissions, check out my Facebook page for my latest project; https://www.facebook.com/Ford-transmission-repairs-Jmod-348414635312478/
#3090801 - 03/01/16 11:56 AM
[Re: 88grandmarq]
Loc: Erie, PA
So let me start by saying I have searched this issue on the forms. I found one post that was similar I replaced the transmission position sensor. That seemed to work for some time. Replaced the tranny fluid. Seems to have helped. Fluid does not smell burned. I changed it in July of last year. Now on hills going around 40 mph the trans.ission seems to slip out of gear or shifts out of gear. Used to just be on hills on slow turns up or down. Now just going up. the transmission will run fine when not on. A hill when pulling the dipstick I do not see any metal fragments and liquid is not brown it is still red/pink any ideas? Car has about 76000 miles on it. It was a highway patrol unit here in utah. Any ideas would be wonderful. When on flat ground transmission runs fine and does not have issues and shifts like normal. it is common for the filter to separate from the grommet that holds the filter in place, causing the filter to fall into the pan. First thing I would do is pull the pan and check filter. +1, have seen this many time on my cars. Another note, is 05+ uses throttle by wire (TBW), for whatever reason this makes you perceive the tranny is slipping but in reality it is just in 3rd gear unlocked or 2nd gear unlocked. The PCM will then adjust the throttle plate microscopically to get you the best performance for the gear you are in. I will admit embarassment when I first aquired my 07. I thought there was a problem that there wasn't.
******Need your heater core replaced? Click Here****** -'99 Crown Vic Police Interceptor (SAP), 3.55 Trac-Loc(DK), Cloth Interior, Black Honeycomb Grill, Black PI Trunk Bezel, Silverstars, 183K-'00 Crown Vic Police Interceptor (SAP), 3.55 (R2), Cloth Interior, Black PI Trunk Bezel, 03+ Full Wheel Covers, Silverstars, 115K-'08 Crown Vic Police Interceptor (SAP), 3.27, Cloth Interior, Smokestone Metallic, 96K / 249 Hrs-'08 Crown Vic Police Interceptor (SAP), 3.27, Cloth Interior, Black, 133K / 1643 Hrs-'08 Crown Vic Police Interceptor (SAP), 3.27, Cloth Interior w/ Carpet, Norsea Blue, 157K / 597 Hrs-'07 F-150 4x4 - Extended Cab, 3.55's, White w/ Grey interior, 167K-'14 Fusion S - 160K
#3091145 - 03/01/16 03:27 PM
[Re: Fordiesel69]
4R70W rebuilder
So let me start by saying I have searched this issue on the forms. I found one post that was similar I replaced the transmission position sensor. That seemed to work for some time. Replaced the tranny fluid. Seems to have helped. Fluid does not smell burned. I changed it in July of last year. Now on hills going around 40 mph the trans.ission seems to slip out of gear or shifts out of gear. Used to just be on hills on slow turns up or down. Now just going up. the transmission will run fine when not on. A hill when pulling the dipstick I do not see any metal fragments and liquid is not brown it is still red/pink any ideas? Car has about 76000 miles on it. It was a highway patrol unit here in utah. Any ideas would be wonderful. When on flat ground transmission runs fine and does not have issues and shifts like normal. it is common for the filter to separate from the grommet that holds the filter in place, causing the filter to fall into the pan. First thing I would do is pull the pan and check filter. +1, have seen this many time on my cars. Another note, is 05+ uses throttle by wire (TBW), for whatever reason this makes you perceive the tranny is slipping but in reality it is just in 3rd gear unlocked or 2nd gear unlocked. The PCM will then adjust the throttle plate microscopically to get you the best performance for the gear you are in. I will admit embarassment when I first aquired my 07. I thought there was a problem that there wasn't. correct, scan for stored trouble codes, then do a throttle relearn
#3091841 - 03/01/16 10:16 PM
[Re: bagmister]
So the car is not giving any codes. I ended up Trying to drive in overdrive and not in overdrive. The transmission acted normal when overdrive was off. I am thinking the overdrive band may be faulty. I took it to the stealership to have them look at it. But all issues went away after overdrive was turned off. It was strange even tried driving aggressive. Worked just fine with over drive off. Mercon v is in the car.
