Page 7 of 9 < 1 2 3 4 5 6 7 8 9 >
#2778916 - 11/15/13 09:46 PM Re: DBW intake mods (straight business) [Re: Black_Sunshine]
Black_Sunshine Offline
Finally, officially finished this project today.
Wednesday when I left work I had a little problem. A vacuum problem. She was really sucking wind. I took a look and I think the PCV was loose from the back of my Accufab. I need to use some RTV to glue it in or something.
It reminded me that I still need to fix the evap line. When I installed the Accufab I just used a piece of injector line to replace the nice pre-bent evap line.
My plan was to use the plastic tube from the evap return to make a a custom line for the vacuum side of the evap.
If your vacuum side on your evap is rotted out you could make a new one this way too. It'll last longer than the original too.
Here's the salvaged return tube and some fresh salvaged connectors.
The kinked up, offending hose, that my friend so eloquently said looks like 'death'.
I cut the plastic tube into two good pieces to use for the bends. I needed a way to bend it with out collapsing it. I came up with a mandrel bending system. I shoved piece of coaxial cable in it. Then hit it with a heat gun. Then I bent it and waited for it to cool. It didn't bend as pretty as I hoped it would but I know that it's open because the wire held it open.
I thought that I would put clamps on the hose but it was hard as hell to shove in there. Even with WD40 and the heat gun. I got it in there about 1/2". Then I wanted to make the bends look less like death. So I covered the connections with heat shrink.
Here's the finished product.
The installed product photo came out terrible so I'll get another tomorrow.
75mm DBW TB
� hood ornament
� c-pillar emblems
� LS style body side moldings
CarDomain
Facebook
#2779026 - 11/16/13 08:00 AM Re: DBW intake mods (straight business) [Re: Black_Sunshine]
wayfastwhitey Offline
Loc: Dfw, tx
well done sir.
and I have stared death in the eyes, I think your line looks fine.
Current ride :
flip flops
Previous panthers:
92 lincoln town car signature series - murdered out
95 lincoln town car signature series - lets just say, yeah, I know what the pit can do to the front of a car...
97 Lincoln town car signature series - paid 625 and due to some unfortunate circumstances I had to sell it
#2807912 - 02/07/14 04:25 AM Re: DBW intake mods (straight business) [Re: Black_Sunshine]
SocalSam Offline
banned
Loc: SFV, Calif.
I would never have considered a DBW car until I saw Black_Sunshine's GM at the last So Cal JMOD meet. So, I gave up looking for a low mileage '04 CVPI and bought a '08 CVPI. I intend to make my setup look as stock as possible so that means staying with the stock intake plenum (which will be ported and polished, of course.) This thread and your experience are much appreciated.
70mm MAF is not a dead end. I adapted a CVPI box and snorkel to the 70mm in my LX Sport and it works great. There is definitely a lot more flow. I've added the CVPI snorkel to two '99 NPI's with similar results. No tune needed. One NPI had a misfire on light load which I suspect was caused by spark plug gap being too narrow. (It did not misfire with the trumpet snorkel.) Plug change cured it.
Edited by SocalSam (02/07/14 04:28 AM)
2004 CV LX Sport #2
#3098049 - 03/05/16 10:49 AM Re: DBW intake mods (straight business) [Re: Black_Sunshine]
PI46interceptor Offline
Loc: iowa
what year 3v f150?
#3098105 - 03/05/16 11:19 AM Re: DBW intake mods (straight business) [Re: PI46interceptor]
Originally Posted By PI46interceptor
what year 3v f150?
Should be all.
#3099081 - 03/05/16 09:51 PM Re: DBW intake mods (straight business) [Re: BlackVic_P71]
what year 3v f150?
Should be all.
Looks like 2004-2008:
https://en.wikipedia.org/wiki/Ford_Modular_engine#3-valve_2
75mm DBW TB
� hood ornament
� c-pillar emblems
CarDomain
Facebook
#3106626 - 03/10/16 10:26 PM Re: DBW intake mods (straight business) [Re: Black_Sunshine]
Loc: iowa
anyone else done this with out a tune? its a minor change that the computer should be able to learn.
#3106706 - 03/11/16 12:26 AM Re: DBW intake mods (straight business) [Re: Black_Sunshine]
09mnsp Offline
Loc: Minnesota, U.S.
a few people have without a tune. I switched from a 75mm to a twin 60mm and didn't alter my tune. My shift strategy seems the same. According to my wideband, a/f is the same at part and wot.
09 P71
#3107658 - 03/11/16 09:40 PM Re: DBW intake mods (straight business) [Re: PI46interceptor]
It's a minor change because, ultimately, the MAF is measuring the air in front of it. It makes the car drive different because less throttle lets more air in. Sure it can let more air through overall but that's not necessary for very many N/A 4.6L mod motors.
75mm DBW TB
� hood ornament
� c-pillar emblems
CarDomain
Facebook
#3107698 - 03/11/16 09:51 PM Re: DBW intake mods (straight business) [Re: Black_Sunshine]
Also you can find an X3 tuner used and get a good tune from MPT on the cheap. That's what I've done.
75mm DBW TB
� hood ornament
� c-pillar emblems
CarDomain
Facebook
#3108098 - 03/12/16 08:52 AM Re: DBW intake mods (straight business) [Re: Black_Sunshine]
Tcruarceri Offline
Loc: Ny
I thought these were permanently married to the car they were hooked into, you can reset and change the vehicle?
05 p71 - 18 2015 Mustang Wheels, SCT X4 With Moe's custom tune. Dynomax Mufflers. Rusty Passenger Side Floor (or emergency exit?)
#3108626 - 03/12/16 05:01 PM Re: DBW intake mods (straight business) [Re: Tcruarceri]
Once you remove the tune(return the car to stock), the tuner can be used on another vehicle.
#3109298 - 03/13/16 10:35 AM Re: DBW intake mods (straight business) [Re: Black_Sunshine]
Loc: iowa
thanks everyone. I picked up a throttle body for $60 of an 05 f150 5.4 3v w/24k miles and the elbow is coming from amazon for $76 so not too bad. out of curiosity has anyone done a before/after dyno run? MPT as in morepowertuning.com? Are you guys running the stock 65mm electronics on the 75mm tb or are you using the f150 electronics?
#3113962 - 03/16/16 10:44 PM Re: DBW intake mods (straight business) [Re: Black_Sunshine]
Loc: iowa
mpt says they don't do crown vics anymore suggestions?
#3114050 - 03/16/16 11:55 PM Re: DBW intake mods (straight business) [Re: PI46interceptor]
Strange. Must be fed up with mine. I'll have to ask them if they want to talk about it. They still had them listed on their site last week.
Mo's Speed shop has been getting really popular. They don't have an online store. You have to deal with them through email.
75mm DBW TB
� hood ornament
� c-pillar emblems
CarDomain
Facebook
