#3114018 - 03/16/16 11:28 PM FORD RACING PI INTAKE??
Mw21032003 Offline
Loc: NY, NY
I'm trying to get solid information on if a Ford Racing intakes will work on a 2008 crown vic. The models I see are listed for mustangs up to 2004. I talked to one of the tech guys at summit racing and they say it won't fit without serious modification. I would rather a ford factory part than the dorman intake. Assuming someone has used this manifold but tech guy telling me it won't fit has me worried, anyone have the part number for the model they used? Also anyone have any experience using a spacer on intake? Any downside? A specifically model better than others?
#3114026 - 03/16/16 11:39 PM Re: FORD RACING PI INTAKE?? [Re: Mw21032003]
It will fit. whoever you were talking to does not know what they are talking about. The Ford Racing PI intake for a '99-'04 Mustang is a direct fit for an '01+ Panther.
#3114106 - 03/17/16 12:22 AM Re: FORD RACING PI INTAKE?? [Re: Mw21032003]
Boss429 Offline
Loc: Dayton,Ohio
The poster above is correct. We sell many at the Speed Shop here We are a Ford Racing Performance Parts dealer since their day one. (1982) a direct bolt on....
#3114186 - 03/17/16 02:57 AM Re: FORD RACING PI INTAKE?? [Re: BigMerc96]
bigROC209 Offline
Loc: Stockton, CA
The Ford Racing intake manifolds for Mustangs have the coolant sensor in a different spot. I could be wrong but I remember something about the coolant sensor being in different places on the FRIM's. If you get one designed for a Mustang I think you will have to drill and tap the hole for the coolant temp sensor.
I installed one on my 2002 Marquis. It looks a little challenging but it's not bad at all. I was able to get it installed without removing the alternator. The hardest part is getting the crash bracket that protects the fuel line off.
You can see the sensor plugged in on the old intake manifold.
2002 Marquis LS Precision Trac, new engine @ 125K, GT Wheels, HP tires, SCT Xcal 2, 91 Octane tune from BOC, Traction Locker w/Ford Racing clutches, 3.55's, Police D/S, Ford Racing IM @114K, 75mm TB, Trick Flow Plenum, Ziptube, GT MAF, P71 Rear Coils, Summit Racing UDP's, HPP Sway Bar, Gas KYB's, J-Mod, 2-1/4" Dual Exhaust, Thrush Glasspacks & 18" tips, MSD COPs, NGK TR55's & Grey Injectors, Pinstripe removed, Disc changer, 2400 watt Pioneeer amp & 6x9's, Kicker Comp VR 10" DVC subwoofers.
#3114386 - 03/17/16 10:30 AM Re: FORD RACING PI INTAKE?? [Re: bigROC209]
PB92 Offline
Loc: Communist CT
Do you think this was a worth while upgrade? My new Ford crate engine is a NPI. Did you notice anything SOTP or otherwise?
US MARINES Kilo 3/3
Modified factory CAI. Big 4 upgrade, 0 gauge highstrand. High Power Cobra 29LX highly tricked out. 200 amp alt w/overdrive pulley. New body mounts. Moroso air/oil separator. Rebuilt 8.8 axle. ARA3 PCM. High power CB'er for 35 years. GMRS Operator Midland MXT400
#3114394 - 03/17/16 10:34 AM Re: FORD RACING PI INTAKE?? [Re: Mw21032003]
Are you replacing it because the old one is broken?
#3114562 - 03/17/16 01:22 PM Re: FORD RACING PI INTAKE?? [Re: PB92]
bigROC209 Offline
Loc: Stockton, CA
If there's nothing wrong with your intake manifold then I'd leave it alone. There are other options out there if you're going for performance.
Check out the "Qualifier" intake manifolds. They're less than $300. I think one member here has one.
#3115466 - 03/18/16 08:41 AM Re: FORD RACING PI INTAKE?? [Re: Mw21032003]
PlainMarquis Offline
Loc: Hampton Roads, VA
Just did this on my '99 with the FRPP intake. It is a very nice OEM quality piece. Fit was great. One suggestion on that crash bracket, I left the wiper stuff in place and it was a PIA to get off, but it is doable. If you want to reuse it, slot the mounting hole on the rear. It makes it that much easier to install and remove again if need be.
99 MGM, 50,000 miles, E-Van throttle body, PI intake, Navigator water pump, 'hot air' intake, dual exhauast w/pypes street flos
#3115498 - 03/18/16 10:31 AM Re: FORD RACING PI INTAKE?? [Re: Mw21032003]
kots Offline
Loc: Los Angeles, CA
It will fit. I just did this last Wednesday and also bought the exact same part from Summit Racing: http://www.summitracing.com/parts/fms-m-9424-p46
It arrived the next day here in Los Angeles shipping from Nevada.
You will have to buy a 3/8 NPT pipe plug to plug the hole for the CHT sensor and some teflon tape to wrap around the plug. The Ford Racing Intake has a hole for the CHT sensor while your original do not.
I broke my EGR tube in the process even while having the Alternator completely out for clearance. Maybe it would have been better if I have taken out the EGR valve completely from the tube. Be careful with this tube as it can be brittle/soft and may snap. I just finished the last piece of the install just last night to replace the EGR tube ordered here: https://www.amazon.com/dp/B009XR2798
It was my first time and it took me just less than an hour to get the intake manifold off. It's just the EGR tube that delayed the rest of the install. It's easily doable in 2 hours if everything went well plus 1 more hour to clean the intake off the carbon build up. Get a big empty table to line up all your parts in the order of disassembly so you know where everything belongs afterwards.
2006 Ford Crown Victoria Police Interceptor
#3115506 - 03/18/16 10:35 AM Re: FORD RACING PI INTAKE?? [Re: Mw21032003]
kots Offline
You will also need the following gasket:
https://www.amazon.com/dp/B000C2EC82
Change the o-rings while you're at it (4 order of 4 pcs = 16 pcs):
https://www.amazon.com/dp/B000C2CFE0
You will need 16 o-rings. 8 injectors x (1 o-ring on top + 1 o-ring) on bottom
Get some generic dielectric grease to grease the o-rings prior to install.
#3115794 - 03/18/16 04:49 PM Re: FORD RACING PI INTAKE?? [Re: Mw21032003]
Its an easy intake to do. It really is. After the 3rd time I changed mine in a week (thanks Dorman!!) I think I had it down to under 2 hours. Mine is a '97, so its the last year not to have that crash bracket on the back which is nice. Even without that rear bracket that rear most mounting bolt on the drivers side is a tight fit, I have to use a low-profile ratchet to fit under the wiper motor. On a whale its just easier to take the wiper assembly out, it doesn't really add much time and it makes it that much easier, plus it gives you a great opportunity to clean all the crud out of the cowling.
#3115994 - 03/18/16 06:48 PM Re: FORD RACING PI INTAKE?? [Re: Mw21032003]
Mw21032003 Offline
Loc: NY, NY
Thanks think I'll be picking up the FRPP intake. Performance isn't my prime concern it started to leak around the thermostat plastic has had it. Never had luck with dorman and wanted better. If I can get similar or slightly better performance while I'm doing it seems like win win. Does anyone have any option of the qualifier intake? I like that it's all metal construction and similar price to FRPP intake?
Edited by Mw21032003 (03/18/16 06:51 PM)
4 registered (ironmarinebill64, RF_Overlord, jimmyv1958, 1 invisible), 71 Guests and 291 Spiders online.
bluejay_32 162
Old_Guy_Stu 97
a_d_a_m 94
Moby_Vic 55
CrystalPistol 50
TheCableGuy 47
RF_Overlord 44
Ponyguy 39
